What's Next? - Mustang Evolution
Old 02-02-2011, 10:31 PM   #1
JDwoodman's Avatar
Send a message via Skype™ to JDwoodman
What's Next?
Hey guys, I've been building up my 2010 V6 bit by bit for the past year but I've finally reached a point where my car knowledge won't get me any farther. I want to know what I can do to get more performance out of my engine from this point on for under $1000. (meaning no turbo's or super's) =(
I've been looking at NOS kits but I worry about negative effects to my engine over time so if you have any info on that as well please share it with me.
Currently these are the mods I'm running with:
K&N CAI, Superchips Cortex Tuner, Shelby Strut Tower Brace, True Dual Magnaflow X-Pipe Exhaust, BBK 70mm Throttle Body w/ Spacer, 3.73 gears.
Thanks in advance!!!
(Current)2012-Black 5.0 Premium Whipple 2.9L Supercharger Stage 2 Kit, ID1000's, JMS BAP, GT500 Six piston Brembo Brakes, Boss 302 front and rear diffusers, GT500 Spoiler, Ford Racing 3.73 gears, and Boss 302 oil cooler.
(SOLD)2010-Sterling Gray V6 Pony Package (too many mods to list)
JDwoodman is offline   Reply With Quote
Old 02-03-2011, 12:24 AM   #2
meteorachick's Avatar
Re: What's Next?
you have a decent about of mods, maybe headers? i'm honestly not really sure what you should do next
Modified 2004 V6
Old 02-03-2011, 01:03 AM   #3
Nitrous...I have a zex dry kit with all braided line and bottle bracket however no bottle. Dry need to be introduced right into the manifold to mix with fuel. I bought a zex wet and the gent I bought it off threw in the dry kit because he had no use. Nitrous is safe and a tune isn't needed for under a 75 Hp shot....I have friends who have been spraying 150 on stock block and internals for years with no ill effects. If not tuned properly it can go boom tho...125.00 plus shipping if interested and then you just need the fogger plate or however you want to inject it...am extra 75 bucks and I will toss in the purge kit too
Old 02-03-2011, 01:42 AM   #4
Re: What's Next?
Nitrous is just as safe as forced induction if used properly. A wet kit would be the way to go if you were going to do it. I've had a couple of cars with nitrous and never had any ill effects!
93CobraGuy is offline   Reply With Quote
Old 02-03-2011, 07:41 AM   #5
Re: What's Next?
Nitrous is something I would avoid for a few reasons. Mainly its not legal on most roads if hooked up (thus useless while not on the track) and it can be more expensive than you thinks. It is also a hassle to have to fill up all the time.. and you can only enjoy the power when spraying.
Old 02-03-2011, 08:42 AM   #6
Get lowering kit and headers
sno4life is offline   Reply With Quote
Old 02-03-2011, 08:44 AM   #7
I agree. A lowering kit most definitely.
Old 02-03-2011, 12:05 PM   #8
Titus Wadicus
svtlx's Avatar
Re: What's Next?
can you get a cam for it? im not totaly on the n.o.s. bandwagon either. but everyone has their preferences....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-03-2011, 09:13 PM   #9
JDwoodman's Avatar
Re: What's Next?
Ok, can you PM me with exactly what I'll get with the kit? Sounds fantastic.
Old 02-03-2011, 09:16 PM   #10
JDwoodman's Avatar
Re: What's Next?
They have some forged cams in a fast ford's mag I saw for like $600.00 Are the power gains worth that cost?
Old 02-03-2011, 09:20 PM   #11
JDwoodman's Avatar
Re: What's Next?
haha Ok, votes on this part anyone?
Or other suggestions?
Eibach Pro Kit Spring Set (05-10 GT & 2010 V6) at AmericanMuscle.com - Free Shipping!
Old 02-04-2011, 06:54 AM   #12
I have the pro-kit on my 04 and I love it.
Old 02-06-2011, 09:39 AM   #13
Titus Wadicus
svtlx's Avatar
Re: What's Next?
your guesse is as good as mine...your asking the wrong person on that one. that's alota money just for cams, but you may get a decent power gain with everything you already have plus the cams...
with everything you said you have, cam just seemed like the natural progression, that's y i suggested it.
Old 02-06-2011, 10:44 AM   #14
Trade it in on a gt.
Alscobra is offline   Reply With Quote
Old 02-06-2011, 10:55 AM   #15
JDwoodman's Avatar
Re: What's Next?
Shoulda seen that one coming
Old 02-06-2011, 10:56 AM   #16
JDwoodman's Avatar
Re: What's Next?
Alright thanks!
11:47 PM
