dealership trying to rip me off - Mustang Evolution
Old 02-10-2011, 04:03 PM   #1
i went to my dealership today to find out how much it would cost install my roush axle-back and they told me it would be $300. thats CRAZY!!! for a little over an hours work. their site even says 1 hour to install
ROUSH Performance: 2011 Mustang Exhaust Kit with Round Tips
how much did u guys pay for your roush axle back to be installed? or any other axle back exhaust. i would do it myself but i dont have a lift.
mylilpny is offline   Reply With Quote
Old 02-10-2011, 04:11 PM   #2
06mustangmike's Avatar
Re: dealership trying to rip me off
there in it to make money, and yes they suck
06mustangmike is offline   Reply With Quote
Old 02-10-2011, 04:36 PM   #3
Do you really need a lift? Jack that thing up and set it on some jackstands. You should be able to change it out like that. I've done countless transmissions this way, having to remove the exhaust is part of that job. If you don't have any jackstands, they definitely won't cost as much as the dealer is trying to F you for!
93CobraGuy is offline   Reply With Quote
Old 02-10-2011, 04:39 PM   #4
i agree
Old 02-10-2011, 04:39 PM   #5
Titus Wadicus
svtlx's Avatar
a rack is helpful. but you dont have to have a rack to install one. just a willingness to get dirty and be super uncomfortable for a couple hours..if it takes you that long.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-10-2011, 04:50 PM   #6
Buy jackstands. You are gonna use em again... Tools are always a good investment
Old 02-10-2011, 05:17 PM   #7
i have some but i didnt think id be able to get under there and do it myself like that. and considering its winter here right now id hate to be out in the cold for so long =/ but as long as its possible to do that maybe ill give it a try
Old 02-10-2011, 05:22 PM   #8
Titus Wadicus
svtlx's Avatar
get the big jack stands...not the small ones. get the big hydraulic jack...not the lil one. it will make your life easier than in more ways than one.
Old 02-10-2011, 05:25 PM   #9
It's either that or $300 less to spend on more mods!
Old 02-10-2011, 05:27 PM   #10
Titus Wadicus
svtlx's Avatar
im sick and damn tired of you making good valid points and dispensing informative opinions...who the fuk do u think u r anyway?
Old 02-10-2011, 05:29 PM   #11
lol i could really use some lowering springs....
but i know those will be expensive as **** to install. def not gonna install those myself.
Old 02-10-2011, 05:33 PM   #12
bbunt302's Avatar
Springs aren't that bad to install, at least on the 94-04 cars. I've never done it on a 05+. It should be about the same though.
Scary stuff.
Old 02-10-2011, 05:34 PM   #13
Your'e just mad cause I get to those points before you have a chance to!
Old 02-10-2011, 05:36 PM   #14
Springs are pretty easy. I wouldn't imagine them being any harder to install than any other year mustang.
Old 02-10-2011, 05:37 PM   #15
Titus Wadicus
svtlx's Avatar
i saw a video on utube on how to install springs on 05 and up...pretty straight forward...only main thing i could see different was the rear sway bar links...but again, straight forward work.
Old 02-10-2011, 05:40 PM   #16
Titus Wadicus
svtlx's Avatar
awww schucks bud...u got me...lol
Old 02-10-2011, 05:41 PM   #17
bbunt302's Avatar
The only thing that would worry me would be the front springs. On my Fox, I ended up having to drop the A arms in order to change the springs because I couldn't get a spring compressor on them. That was a total pain in the ***.
I've helped change springs several times on 94+ cars and never had the same problem though.
Scary stuff.
Old 02-10-2011, 05:43 PM   #18
Titus Wadicus
svtlx's Avatar
how did u do it on the other cars?
Old 02-10-2011, 05:45 PM   #19
bbunt302's Avatar
The dangerous way. One person stands on the A arm and the other wrestles the bastards out.
On the 94-04s though it's really not that dangerous because the front sprints are nowhere nearly as compressed.
Scary stuff.
Old 02-10-2011, 05:47 PM   #20
Yup, had to do the same thing when I put the pro kit on my '85.
Old 02-10-2011, 05:52 PM   #21
Titus Wadicus
svtlx's Avatar
o...ok. installed v8 springs on the rear, and left the front 4cly springs in for weight transfer on my notch. but ima lower front and rear on my 97, so i wanted to make sure i wasnt missn out on any trade secrets..
Old 02-10-2011, 07:30 PM   #22
jfrullo's Avatar
no stands just a floor jack took less than an hour
piece of cake
can anyone tell me why my rear axel is rusted already the car was built on 12 20 2010 and i installed the the roush axel back exhaust on jan 7th 2 days after i got the car home it has never seen any rain or snow and i dont believe the dealer washed under the car during there vandelizing paint option that cam with the car.
jfrullo is offline   Reply With Quote
Old 02-10-2011, 07:41 PM   #23
Titus Wadicus
svtlx's Avatar
piece of cake
dude if u get under cars without a jack stand you fukn crazy... do u know how many ppl have lost their lives by trusting floor jacks?
Old 02-10-2011, 07:42 PM   #24
piece of cake
They do that.
Old 02-10-2011, 09:02 PM   #25
jfrullo's Avatar
what rust
or dealer installed paint scratch option
Old 02-10-2011, 09:04 PM   #26
Either, or if you are lucky, both!
Old 02-10-2011, 09:13 PM   #27
jfrullo's Avatar
being i could fit under the back end of it and didnt even lift the wheel of the ground i didnt think i was risking death. sorry if i might of given some unsafe info.
Old 02-10-2011, 09:16 PM   #28
jfrullo's Avatar
well i know i will never let the dealership wash my car again
Old 02-10-2011, 09:18 PM   #29
The suspension will also compress and bounce if the car falls off the jack. I won't get under a car without stands.
Out of the 15+ years of working on cars, I have only had a car fall off a jack one time, and that's because I trusted that my buddy set the ebrake on his car. I was doing his brakes, and he was parked on a slight incline, we opened the hood, and just the pressure of doing that rolled it right off the jack.
Not trying to bust balls or anything, just making a point for safety!
Old 02-10-2011, 09:19 PM   #30
You can take a wire brush to it and then get some good rattle can spraypaint after it. That's what I have done to all my axles. Makes it look a helluva lot cleaner under there!
Old 02-10-2011, 09:36 PM   #31
jfrullo's Avatar
one of my next projects
i will have to get Some jack stands
i dont think i can drive upon my ramps
Old 02-10-2011, 09:43 PM   #32
Loc: Austin,TX
If you can change your own oil then you can install axelbacks.Super easy and takes bout a hour max.Spray some wd40 on the rubber hangers to make the job easier and use some jackstands.....$300 axelbacks aren't worth losing a limb or having your chest caved in.
Old 02-10-2011, 10:33 PM   #33
Titus Wadicus
svtlx's Avatar
you can jack the car up...slide the ramps under the wheels then back it off later..ive done that back when i had ramps.
Old 02-11-2011, 04:40 AM   #34
Alright im convinced to install the axleback exhaust myself. It came with instructions and when i read them it looked so easy and simple to do. Thanks for all your helpful advice everyone
Old 02-11-2011, 06:47 AM   #35
ponyboy94's Avatar
i did a full true dual and i got it for like $120 at my friends shop
ponyboy94 is offline   Reply With Quote
pics at the dealership soccerfreak2143 Pictures and Videos 14 01-21-2011 08:18 PM
Went to my local Ford dealership.... Seph The Bar 24 09-05-2006 05:51 PM
the car dealership rocks Kyle The Bar 12 06-09-2005 11:32 AM
my car is at the Ford dealership... jimmy_beaner The Bar 87 05-13-2005 11:38 PM
My Suspension Adventure at the Dealership. Tin Kicker Pre-2005 V6 Mustang 12 01-29-2004 06:55 PM
03:59 PM
