2011 GT Random starting problem - Mustang Evolution
Old 02-14-2011, 05:55 AM   #1
My 2011 GT has a starting problem, sometimes. When I turn the key to start position sometimes it just keeps cranking the engine over but doesn't start. I have to turn the key to off and restart it. Its like it gets stuck in the start position and cranks but doesn't start. and i have to turn the key to off to stop it from cranking or it would just crank and not fire up. Any one ever have this happen?
ray bouquet is offline   Reply With Quote
Old 02-14-2011, 06:24 AM   #2
leo289's Avatar
Re: 2011 GT Random starting problem
Are you holding the key in the start position? I did that when I first got mine and had the same issue. Once you move it to the start position you let it go immediately and it will turn until it starts. I had the same issue but since i quit holding it in start have not seen the problem
leo289 is offline   Reply With Quote
Old 02-15-2011, 06:07 AM   #3
I will release the key and it continues to crank like I would be holding the key in the start position.
Old 02-15-2011, 07:10 AM   #4
leo289's Avatar
that is the way it works. Freaked me out at first also. It should turn over until it starts
Old 02-16-2011, 08:17 AM   #5
Kpd3014's Avatar
I have had the same issue and actually was freaking out too. You guys are the first I have heard talking about it.
So if I follow correctly, just place the key in start and let go. If i keep twisting forward I am manually causing the problem?
2012 GT500 PP, NAV, SSW exhaust, BMR lowering springs
Kpd3014 is offline   Reply With Quote
Old 02-16-2011, 04:23 PM   #6
leo289's Avatar
Correct. Once you get used to it its pretty cool
2011 gt
03 starting problem GatorBen Pre-2005 V6 Mustang 3 07-22-2010 07:47 PM
Random Problem wjred2002 General Mustang Discussion 5 11-06-2008 02:45 PM
Starting problem bobroloff 1996-2004 Mustang GT 6 07-18-2008 10:49 AM
Weird starting problem... lowflyn Pre-2005 V6 Mustang 13 10-28-2005 08:20 PM
08:33 AM
