LT Headers and catted X - Mustang Evolution
Old 02-19-2011, 06:41 AM   #1
LbarJ's Avatar
Just got Dynatech Longtube Headers and Catted X Installed at Woodbine Motorsports sounds absolutly brutal with my muffler deletes and ...
making max power = 400.84 and Torque = 364.90 To the WHEELS
Proably could have got more with an off road mid but dont wanna fuss with emissions testing . bottom line --- the car is a powerful beast now pulls and pulls and pulls.
LbarJ is offline   Reply With Quote
Old 02-19-2011, 09:02 AM   #2
Titus Wadicus
svtlx's Avatar
Re: LT Headers and catted X
congrats!!!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-19-2011, 09:11 AM   #3
stampde's Avatar
nice / never heard of that header brand before , you like ?? fit well etc ...
2011 GT Auto
Old 02-19-2011, 09:29 AM   #4
Loc: Austin,TX
Maybe I am reading your post wrong and I'm definitely not trying to burst your bubble but there are stock 5.0s making 360+whp. With those mods you should be in the 420ish whp range.
Old 02-19-2011, 10:29 AM   #5
jimbullit's Avatar
...alas-"the bubble hath bursteth", anyway..
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 02-19-2011, 10:38 AM   #6
Loc: Austin,TX
Lol Jim,I totally didnt mean it like that LbarJ. Ive seen those headers you are running and them seem to be pretty good. Do you have a dyno tune? Its just that Ive seen guys with CAI,tune and axelbacks hitting 400whp already so Im not sure I would do the LTs considering the stockers flow pretty good already.Although I did see a thread on S197forums where a guy had CAI,tune,LTS and off road x putting down 424whp.....thats awesome!
Old 02-20-2011, 08:49 AM   #7
LbarJ's Avatar
My bubble is not burst thank you very much ! those numbers you quote are from guys running off road X pipes, removing the cats on these cars does result in higher power numbers . However I knew going in I would not see those #'s as I choose to run a catted X . ++ dyno numbers can be all over the place different dynos etc - the results are fantastic where it counts on the street ! And I love the way Long tubes and X pipes sound - extreme musclecar . Lets see those dyno queens at the track eh ?
Going to the spring 5.0 shootout ? MIR 3/28/11 , I am .
Old 02-20-2011, 08:55 AM   #8
LbarJ's Avatar
Excellent product fit finish quality stuff , less expensive that the Kooks .
Old 02-20-2011, 09:51 AM   #9
Loc: Austin,TX
I think I will do the OR H and keep a tune ,for catted and OR so I can swap them out for inspection. Did the LTs help with any low end torque?
Old 02-21-2011, 11:27 AM   #10
LbarJ's Avatar
@ DDTCM 60 + hp for intake , headers , tune ? a tad optimistic !
anyhow yes it was pulling like mad put ya right back in the seat even down low so torque was great , I do have a Bama tune with my cai however I did not think a Catted X needed a revised tune well it does today check engine light and down on power on the way to work The folks at SCT said I should order a tune for my new mods - so I'll do that and perhaps I'll pick up more power as well as getting rid of the CEL.
Old 02-21-2011, 12:34 PM   #11
stampde's Avatar
thanks ....... looking for headers for my Mach 1 , I'm going to check into them
2011 GT Auto
Old 02-21-2011, 02:27 PM   #12
Great headers, they have had great results with GT500 owners as well.
When I get to that point, I will also be looking at getting Dynatech headers.
2008 GT500 Coupe with a few mods here and there
gtcpa is offline   Reply With Quote
Old 02-21-2011, 03:51 PM   #13
LbarJ's Avatar
FYI - Check engine light may come on even with catted X and long tubes
pulled my codes - p0420
p0430
insufficient catylist effiency ( or something like that )
in essence the pcm senses the high flow cats are not the same as stock
plus the O2 sensors are relocated further " downstream " in the exhaust path - I suspect the pcm tries to compensate enriching the fuel mixture hence loss off pep
Old 02-21-2011, 05:37 PM   #14
Loc: Austin,TX
Intake,tune,LTs,OR X and axelbacks......its already been done so its not really optimistic.
Old 02-24-2011, 08:02 AM   #15
Jmeo's Avatar
p0430
This is something an experienced custom tuner can fix with no problem. When I put Long Tube headers and catted X pipe on my 05 I had the same issue. Dez Racing here in MA threw it on the dyno and corrected the problem. 2 issues, hi flow cats are noticed by computer as not being the same and the delay of the signal from the 02 sensors being milliseconds further away will throw a code. Completely fixable by any reputable custom tuner.
Jmeo is offline   Reply With Quote
Old 02-24-2011, 08:34 AM   #16
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
tuner makes those lights go away
Chick Nasty is offline   Reply With Quote
Old 02-24-2011, 08:49 AM   #17
jimbullit's Avatar
+1-on the 'reputable tuner' fix.
Catted H Pipe Stang23 2005-2010 Mustang GT 9 12-24-2010 11:52 PM
Pypes Catted X Pipe Stang23 2005-2010 Mustang GT 2 12-21-2010 01:08 PM
New exhaust video. Pypes Catted X gmantheman 2005-2010 Mustang GT 1 03-19-2010 08:55 PM
FS: MAC LT Headers and catted H-pipe KyleUSAF Mustang Parts for Sale and Wanted 20 12-15-2006 04:43 AM
My little pony with a catted X-pipe NorwegianMustang Pictures and Videos 4 08-17-2005 07:25 PM
» Members Mustangs
13savage6
Sally
RobSCV6
Add your Mustang
11:14 PM
