02-25-2011, 09:39 AM
#1 | | Site Sponsor
| Install of the Boss 302 intake manifold!
The 2012 Boss 302 Intake Manifold has been THE talk of the town since it was first spotted in the photos released by FoMoCo. Then we got another dose of it in the FRPP catalog wearing part # M-9424-M50BR. Then came all of the controversy on the interwebs all over the forums over availability. Well, all BS aside, we have them in the warehouse & we put one on a car. Scott's Race Red Brembo Package 2011 5.0L Mustang GT to be exact. Surprisingly, despite how it looks initially, it really went quite smoothly & quickly. Scott & I were recapping after the install & we both agreed that putting this intake on a 5.0L Coyote was vastly simpler than installing an intake on a venerable pushrod 5-oh. Enough of the appetizer, lets get to the meat & potatoes!
Oh, on a side note, you'll be getting several first looks at the all new Nitrous Outlet Plate Kit Nitrous System designed specifically for 2011-2012 5.0L Mustang. And yes, it does fit with the Boss Intake just fine. A full install write up will be coming up soon on this Nitrous System.
First, remove your intake cover. This is done by simply pulling up on the cover & unsnapping it.
Second, remove your inlet tube. This Mustang was already equipped with a Steeda CAI, so we simply loosened a couple of clamps, disconnected the sound tube & PCV tube, & pulled it free of the car. Just to get the PCV tube out of the way, we removed it from the valve cover as well.
We then removed the breather tube that runs from the RH valve cover to the intake manifold.
After that, we pulled the throttle body loose & let it hang out of the way. You can fully remove it from the car, but because of the nitrous system on this one, we just let it hang out because it looked comfortable.
Next, we pulled the purge valve off of the intake. This is the part that requires all the Boss specific stuff to properly locate. Well, at least that is what was being said. No says I. We'll cover the cheap fix here in a bit.
On each side of the intake you'll see 2 nuts holding down plastic brackets, & on the drivers side, the brake booster vacuum tube. Remove those & set the brackets to the side & pull the vacuum tube free.
Once those are out of the way, grab 2 sets of pliers & a friend to remove the booster vacuum hose from the intake manifold. The 2 clamps are connected with a metal strap, so they don't move independently.
Then you can remove the foam sound deadener from both sides of the fuel rails.
Now, remove the 4 fuel rail retaining bolts & set them to the side. Unplug all the fuel injector electrical connectors. Using a 3/8" fuel & a/c line disconnect tool, disconnect the fuel feed line. Wrap the fitting with a rag to prevent gas from going everywhere. (its still a safe bet to have your safety goggles on) Remove the fuel rails from the car by gently pulling up & releasing the injectors from the intake, & set them to the side.
You are now left with 6 bolts holding the intake to the heads, 3 on each side. They are located front corner, dead center, & rear corner. Fully loosen all 6 of these. They will not come out of the intake, so don't spend too much time trying. Once you're done with that, lift up on the manifold & slide it forward slightly. On the very back there are 4 wiring harness retainers that need to be pulled free from the intake.
Pull that stock intake out of the way to make room for better looks & more power!
Here is a better look at the 4 wiring harness retainers. Also, that is oil on Scott's finger & there was more in the intake. Probably a good excuse to add an oil separator. |
02-25-2011, 09:40 AM
#2 | | Site Sponsor
| Re: Install of the Boss 302 intake manifold!
Compared side by side, you'd pick the Boss 302 Intake all day long based on looks alone! You can also see the locations of the retaining bolts in these pics. Admittedly, we got in a hurry & forgot to check the inlet opening sizes, but we'll get that info for you soon.
Okay, stop staring at the intake & get ready to put it on. Set the fuel rails in to place on the Boss intake & engage the injectors in to their respective ports. As you can see, the stock fuel rails clear just fine. This also illustrates the vast difference in the intakes, as the front crossover tube used to be above the throttle body!
The new intake comes with gaskets already installed, so all you have to do is set the Boss Intake on the heads & finger tighten the 6 retaining bolts. At the back of the intake, only the outer 2 of the 4 wiring harness retainers have a spot to attach, go ahead & affix them to the intake.
Slide in the 4 fuel rail retaining bolts & finger tighten those as well. Torque the 6 Intake bolts to 89in-lb using the following sequence.
Torque the 4 fuel rail retaining bolts to 89in-lb using the following sequence.
Plug in all the injector electrical connectors, connect the fuel supply line, & reinstall the foam sound deadeners. Set the booster vacuum tube in to place & reinstall both plastic heater hose brackets.
Re-attach the throttle body. Doesn't that Nitrous Plate just look baller? Nitro Dave & the crew & Nitrous Outlet take their nitrous seriously.
In its stock orientation, the brake booster hose won't want to cooperate when trying to attach it to the Boss Intake.
Twist it around like so & it will go on kink free. Remember to have you 2 pair of pliers & a friend ready for this step.
Re-attach the breather tube. See that loose connector hanging there in the breeze? That is for your purge valve, which we'll cover next.
The purge valve. Its purpose is to vent fuel tank vapor in to the intake manifold during certain operating conditions. All we've seen on the 'net so far is that one company left it dangling. Well, that is an option. You car does not need it to run. However, in my experience, this will cause the check engine light to illuminate. On the stock intake, the purge valve attached directly to the intake behind the throttle body. On the 2012 Boss 302, the purge valve is located on the driver side rear of the intake & it is plumbed a little differently. You can get the correct Boss hoses, purge valve & bracket for just under $200 when they are available, but they are not currently available. Plus, you'll still have to lengthen your wiring harness to reach the new purge valve on the other side of the motor. While this is the most correct way to complete the install, it didn't help us at all right now. So good old southern ingenuity kicked in & we determined that if we made a run to the parts store to acquire an M8x1.25 bolt with some washers, 2 feet of fuel/emissions hose, & some hose clamps, we'd be in business & functioning as intended. So here is our fix. Is it ideal, no, but there is nothing wrong with it either. It gets the job done for now until something new comes about.
Squeeze on the 3/8" fuel/emisson hose. It is a tight fit, but apply a little lube & it will go on. Put on a clamp & tighten it down.
Remove the rubber insulators as they won't be needed. Using a bolt, a flat washer, & a lock washer (the lock washer goes between the head of the bolt & the flat washer) attach the purge valve to the engine block. It was kind of hard to get a good pic of this, but hopefully you get the gist. Plug the electrical connector back in & re-connect the purge line.
Run the fuel/emission hose under the neck of the intake & connect it to the remaining open port on the driver side of the intake, clamping the connection.
It has been widely reported that the Steeda cold air intake will not fit with the Boss 302 manifold, but I'm happy to report that it darn sure will. Now don't get me wrong, it's not a slide it on & done type of deal, but you can make it fit. We didn't even cut anything. Yes, there is a .75" nitrous plate installed on this car, but I can't help but think that only made the fitment a bit more difficult, if anything. Take your time & have an extra set of hands around to help tighten clamps or hold the intake in place. Supposedly the JLT CAI fits a little better, we'll be finding out for sure soon.
Oh, & don't even bother trying to re-use your stock strut tower brace. We'll be trying several different varieties & listing which ones fit in the description of the Boss Manifold.
Because of the difference in airflow this intake provides, a custom tune will be necessary. We do have the required tune available as we speak, so no worries there! Load you new custom tune in your Mustang & start it up. It will sound a little angry at first as she re-learns everything, but it'll smooth right out & you'll be on the road enjoying your newfound power! Speaking of power, we we're unable to get to the dyno, but we'll be posting #s as soon as we have the ability to do so.
We offer the intake by itself: 2011-2012 Mustang 5.0L Ford Racing Boss 302 Intake Manifold, M-9424-M50BR
or with the required custom tune: 2011-12 Mustang 5.0L Ford Racing Boss 302 Intake Manifold M-9424-M50BR With BBR Custom Tune
Don't forget to paint your coil covers, or replace them with the Blue FRPP Coil Covers to complete the Boss 302 appearance!
02-25-2011, 10:03 AM
#3 | | 15.3 Second V8 Killer Yo
Great information. Stickied.
"When I know more, I'll be forthcoming. Or I won't be forthcoming, and I'll be honestly deceptive." - Les Miles |
02-25-2011, 10:05 AM
#4 | | Terminator Owner
very nice post thanks for the time/effort to post it!
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
02-25-2011, 10:16 AM
#5 | | Senior Member
Thanks for the info!
__________________ |
02-25-2011, 10:17 AM
#6 | | Site Sponsor
No problem guys. Car is a beast.
02-27-2011, 01:06 PM
#7 | | Registered User
That's awesome. Can't wait to see dyno numbers. Good thread and write up guys.
2010 GT Premium Red, 5spd Manual, 3.73 rear
2010 Ford Raptor Blue, 5.4 |
03-02-2011, 08:32 AM
#8 | | Registered User
Wow-I'm salivating..!  And thank you-and do post those dyno numbers-please!
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
03-02-2011, 08:41 AM
#9 | | Site Sponsor
Dyno numbers will be posted just as soon as we get them. Hopefully in the coming weeks.
05-23-2011, 02:04 PM
#10 | | Registered User
i cant wait for the dyno numbs, that is sick!
05-23-2011, 02:09 PM
#11 | | Site Sponsor
Dyno numbers have been all over the place with this. Still do not have any numbers with the N20 yet, but without it we were able to lay down 420/379. I have seen it as high as 441/400.
08-09-2011, 10:03 PM
#12 | | Registered User
I just followed this guide for my Boss 302 Intake Manifold install, and there are a couple of concerns/issue that I would like to bring up.
1. You should not install the fuel rails until the intake manifold has been seated and the bolts torqued. There is no way to get a straight socket onto the front bolts with the the fuel rails in place. This prevents you from accurately torquing the bolts to spec. It is very easy to put the fuel rails on with the manifold on the heads.
2. Ensure that you depressurize the fuel system. No matter what anyone tells you, it WILL shoot all over the place and wrapping a towel around it is not sufficient.
3. The stock airbox and tube DO NOT WORK with the Boss intake manifold. I was not able to find this information anywhere prior to my install, so perhaps I am the first person to try it, but it just isn't possible. After screwing with if for about an hour and a half I was able to get my hood shut, but it's not pretty and putting a lot of stress on the hood and intake, as well as a part of the intake is being shoved into a metal part of the cooling system and was already starting to melt after a 10 min drive.
I will post pictures tomorrow illustrating why the stock intake does not fit, and what I had to do as a temporary fix (my Mustang is grounded until I get a CAI, I'm not comfortable squishing the intake and putting undue stress on the hood/latch).
08-18-2011, 01:20 PM
#13 | | Registered User
has anyone else installed the intake with no problems? or does anyone know anyone?
08-18-2011, 01:32 PM
#14 | | Registered User
I didn't have any problems, unless you consider not having the appropriate intake a problem.
08-31-2011, 04:24 AM
#15 | | Evolution's Finest
Wow, What a great walk through.
~ Alan 2012 GT 5.0 Powered by Ford Racing March 2012 Mustang of the Month Garage; Videos: Dyno Track Exhaust (40 Series Flowmasters)
09-12-2011, 07:33 PM
#16 | | Registered User
I agree great walkthrough this will help me do my own install. You guys are so much help thanks!
10-01-2011, 02:49 AM
#17 | | Registered User
I was chatting with a guy from Lethal Performance (Lethal Tim I believe) and he actually advised AGAINST the Boss 302 Manifold, said it was more or less a waste of money UNLESS you changed the heads and cams as well, apparently the Boss 302 has different heads and cams than our 5.0's. Dont shoot me, but I have to listen to a guy who makes commission off of his sales when he says its a waste of money.
10-01-2011, 04:52 AM
#18 | | Registered User
Now u tell us .
10-01-2011, 05:34 AM
#19 | | Registered User
| Re: Install of the Boss 302 intake manifold! Quote:
Originally Posted by blackhawk 1 Now u tell us . |
Sorry, I just joined the site today.... if nothing else it LOOKS cool...lol
10-01-2011, 05:52 AM
#20 | | Do The Evolution
| Quote: |
Originally Posted by M3to5.0
Sorry, I just joined the site today.... if nothing else it LOOKS cool...lol | You speak the truth! In my circles their is a kid who spent about $2k getting that Boss intake installed on his '11 5.0 and I still ran him down from a rolling 30mph. Maybe his tune was wack or maybe he can't shift for **** but I would've expected him to at least have the edge.
10-02-2011, 01:08 PM
#21 | | Registered User
The boss shows gains from 5000 to 7800 and if u have a good tune it's definetly worth it. My boss is only going to cost me 400$ as I am going for full bolt on and need all the other mods anyway. And custom dyno tune is the way to go to maximize your gains!
10-02-2011, 02:12 PM
#22 | | Registered User
| Quote: |
Originally Posted by Ken Cheema has anyone else installed the intake with no problems? or does anyone know anyone? | Very easy to do
Brett the best Greene |
10-02-2011, 02:35 PM
#23 | | Do The Evolution
| Quote: |
Originally Posted by Benzo The boss shows gains from 5000 to 7800 and if u have a good tune it's definetly worth it. My boss is only going to cost me 400$ as I am going for full bolt on and need all the other mods anyway. And custom dyno tune is the way to go to maximize your gains! | When do you plan to do it? I've seen the write up on it, it's something I could do myself but I need to see some solid numbers and a good tune before I void my warranty for it.
10-02-2011, 05:33 PM
#24 | | Registered User
| Quote: |
Originally Posted by primer2tone
When do you plan to do it? I've seen the write up on it, it's something I could do myself but I need to see some solid numbers and a good tune before I void my warranty for it. | The week of the 10th but not going to dyno tune till around December. Stage 3 motor sports is going to send me some tunes when I order my sct tuner and JLT cai. These tunes I will run until I do my custom dyno tune. Cuz after I install the boss and jlt I'm going to still need to install my LT's and o/r xpipe.
10-02-2011, 06:53 PM
#25 | | Registered User
Originally Posted by Benzo The week of the 10th but not going to dyno tune till around December. Stage 3 motor sports is going to send me some tunes when I order my sct tuner and JLT cai. These tunes I will run until I do my custom dyno tune. Cuz after I install the boss and jlt I'm going to still need to install my LT's and o/r xpipe. | What LTs and X are you going with? ---------- Post added at 08:44 PM ---------- Previous post was at 08:43 PM ---------- Quote:
Originally Posted by primer2tone When do you plan to do it? I've seen the write up on it, it's something I could do myself but I need to see some solid numbers and a good tune before I void my warranty for it. | Vanessa's Vaughn Gittin Jr. 2011 Mustang 5.0 - YouTube ---------- Post added at 08:53 PM ---------- Previous post was at 08:44 PM ---------- Also, here's AMs car which has the following mods - Boss 302 Intake Manifold
- 4.10 Gears
- Off-road X-pipe
- cat-back
- sticky tires
2011 Mustang GT 5.0L 4V Runs 10.43 @ 130 MPH with Boss Intake Manifold - YouTube
This is an AUTO and put down 404/355 and did 11.64 (before the juice).
10-03-2011, 09:54 AM
#26 | | Senior Member
Originally Posted by primer2tone You speak the truth! In my circles their is a kid who spent about $2k getting that Boss intake installed on his '11 5.0 and I still ran him down from a rolling 30mph. Maybe his tune was wack or maybe he can't shift for **** but I would've expected him to at least have the edge. | 2K for it and install. He got ripped off. YOu can buy the Boss intake for $389 shipped.
A tune is key to maximize the Boss. If you are not revving it to 7800 rpms with a manual you are wasting money doing it. If you do not have 3.73's gears with it you are wasting money doing it. ---------- Post added at 10:54 AM ---------- Previous post was at 10:52 AM ---------- Also here is my car dyno. 464whp. My car just ran a 11.4@119 with the DA still 1500. It has bottom 11's in it with cooler weather. It is worth it if you have some supporting mods to go along.
10-03-2011, 10:13 AM
#27 | | Do The Evolution
That's what I'm looking for! I wanna run the steeda cai but will I need a tune for that as well or will the Boss tune accommodate the cai also? I've never installed a tune in a car before, so I'm a little confused.
10-03-2011, 10:14 AM
#28 | | Site Sponsor
We can get you a tune with the CAI. If you buy it all at once, then thats even easier for me.
10-03-2011, 11:16 AM
#29 | | Evolution's Finest
AM sells the intake, CAI, and tuner as a kit probably the best route to go and of course life tine tunes. This will be the route I go if I go with the Boss 302 intake.
Link http://www.americanmuscle.com/boss-p...ck-1112gt.html
10-03-2011, 11:19 AM
#30 | | Registered User
The AM/Bama tune is pretty conservative. I'm not saying that's bad, just keep in mind that there may be bigger gains from other tunes at the cost of pushing your engine farther toward the limit.
10-03-2011, 11:21 AM
#31 | | Site Sponsor
Originally Posted by avengnd AM sells the intake, CAI, and tuner as a kit probably the best route to go and of course life tine tunes. This will be the route I go if I go with the Boss 302 intake. | We also offer the same thing. Free tunes for life program. I can get it for you with the JLT or the Steeda CAI.
10-03-2011, 11:33 AM
#32 | | Evolution's Finest
| Quote: |
Originally Posted by Jarrod@LRS
We also offer the same thing. Free tunes for life program. I can get it for you with the JLT or the Steeda CAI. | You match or beat the AM price?
10-03-2011, 11:47 AM
#33 | | Site Sponsor
PM me or call me and we can work it out.
10-03-2011, 11:49 AM
#34 | | Registered User
| Quote: |
We also offer the same thing. Free tunes for life program. I can get it for you with the JLT or the Steeda CAI. | Random question... Who does your tuning?
10-03-2011, 11:55 AM
#35 | | Site Sponsor
Chris from BBR
