Sct flash fail - Mustang Evolution
Old 04-22-2011, 11:59 PM   #1
LaFlamaBlanca's Avatar
Sct flash fail
So I recently got 2 tunes from THE Jon Lund and I got a 93 street tune and a 93 street cammed tune. The cam tune worked fine but I tried re flashing with the regular street tune and now my car won't start. It says incorrect vehicle when I try to load another tune and I can't re stock it either. Will detaching the negative battery lead help? Any advice will be appreciated.
LaFlamaBlanca is offline   Reply With Quote
Old 04-23-2011, 12:46 AM   #2
Loc: Austin,TX
Re: Sct flash fail
Can you reload the cammed tune and it will start and run fine?
Old 04-23-2011, 12:48 AM   #3
Nope. I tried everything I had on the tuner. I'm gonna try to disconnect the negative lead and let it sit for like 30 minutes
Old 04-23-2011, 12:51 AM   #4
stangaroo's Avatar
Damn... Sounds like the SCT device got corrupted if it won't let you change tunes all of a sudden and doesn't recognize the vehicle.
Worst case scenario borrow an sct that isn't vin locked and grab a stock tune from another 5.0 or load your lund cammed tune since that one works.
Sct should replace yours since it sounds like that's the issue and not the tune itself, I'd contact both vendors though. If it IS the tune (doubt it) they can send you a new one.
Makes me want to stay stock to be honest...
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual and I still get over 26 mpg
stangaroo is offline   Reply With Quote
Old 04-23-2011, 12:57 AM   #5
Loc: Austin,TX
Re: Sct flash fail
Let us know how it goes.
Old 04-23-2011, 12:57 AM   #6
I have emailed jon lund AND sct but I won't hear back till at least monday...i hope the battery disconnect works.....
Old 04-23-2011, 01:02 AM   #7
stangaroo's Avatar
Plug the sct back into your computer and see if it communicates with that, at least it might narrow down the issue. If it seems fine the battery disconnect might work, then check that the connections are fine when you plug back into the car
Old 04-26-2011, 09:13 PM   #8
Sct remote accessed my device through my laptop this morning.....works like a charm now! Be sure u guys have that latest firmware updated on your tuners AND flash the ecu when sct is open lol
Old 04-27-2011, 10:23 AM   #9
Ok so I got my dyno and it was lower than I expected....whatever. What pissed me off was that right before I got home the car died....twice! Had a battery light and the oil light (the one that looks like a gravy boat). turned the key off and it started up tho. Checked all connections. None seemed to be loose. Pushed on all relays and fuses but nothing seemed loose. What happened? I have a Jon Lund tune in it right now that I tuned last friday and the sct tuner I have lost the vin and my car wouldn't start at all after. Couldn't even re stock it.
Fail Pictures wiarumas The Bar 5 03-01-2009 08:11 PM
SCT chip or SCT Programmer? ninty6stang 1996-2004 Mustang GT 7 07-02-2008 11:57 AM
Sct Flash Tuner or JET Power Module Chip PB&J Pre-2005 V6 Mustang 3 11-21-2006 07:30 PM
01:42 AM
