Tire size - Mustang Evolution
Old 04-27-2011, 09:53 AM   #1
Tire size
Hey guys I'm new to the forum and I just ordered my new 5.0. I've been looking at wheels and tires and I just had a quick question. If I put 305's in the rear will it fit? Also I did a few searches about 20's and of course everyone has a different opinion. So my other question is do I go with 20x8.5 front and 20x10 rear or just go 18x10 all the way around? Thanks for any advice.
Dbsaints is offline   Reply With Quote
Old 04-27-2011, 12:16 PM   #2
Twrangham's Avatar
19s IMHO
Twrangham is offline   Reply With Quote
Old 04-28-2011, 04:44 AM   #3
Stupidfast5.0's Avatar
Re: Tire size
18's. Better selection.
Stupidfast5.0 is offline   Reply With Quote
Old 04-28-2011, 08:17 AM   #4
Loraco's Avatar
Send a message via Yahoo to Loraco
You don't want to go to big if you ever plan on lowering it! Wouldn't go any bigger then 18
APRILS MOTM to drive is the reason the destination is just the excuse.
Loraco is offline   Reply With Quote
Old 04-28-2011, 08:51 AM   #5
Loc: Austin,TX
Re: Tire size
^^False information......
Its a matter of opinion on which size in particular you should go with.19s tend to be more expensive for tires because it is not so common. 20s are a dime a dozen a can often be cheaper than 19" tires because in this day and age 20s are everywhere and are in demand.18s cheaper yes but IMO don't look as good as 20s on a S197 (that's all individual opinion) As far as lowering goes with 20" wheels you will be fine,it just depends on how big of a drop you want (again this is all individual opinion) A 1.5 drop on a 20" wheel with a 30 or 35 sidewall will work just fine.
On my 07 I ran 20x9s with F:255/35 R:255/35 and it was perfect. On my 2011 I am running 20x8.5 255/35 up front and 20x10 285/30 in the rear (KDW2) and will be installing FRPP K springs this weekend......and yes 305s will fit but if its not gonna be a track car I would do 275 or 285 in the rear.
Old 04-28-2011, 08:52 AM   #6
Thanks for the advice. I've been looking at some pictures online and the 20's make the rotors look tiny too. So could I go 18x10 all the way around or do I need to go thinner in the front? What's the widest tire I can safely run up front?
Old 04-28-2011, 08:55 AM   #7
Ok thanks. I was thinking of going with 305 cuz it's just a weekend toy and I plan to make some trips to the strip.
Old 04-28-2011, 08:58 AM   #8
Loc: Austin,TX
Re: Tire size
I wouldn't worry about rotors being to small,you can always fix that later and if you aren't running at the track all the time then the brakes will be just fine.If you run a 10 up front it more than likely rub and IMO look weird. The widest up front I would go would be a 9 with a 255 or a 275.
Old 04-28-2011, 09:03 AM   #9
Again guys thanks for all of the advice. I think ive finally picked out everything I want. Now just need to find the best deals.
Old 04-28-2011, 09:20 AM   #10
jimbullit's Avatar
Re: Tire size
I am a fan of 'same size'-all four corners -as I rotate `em every 3500 miles... I installed 18x9.5s on my `08, and had very satisfactory results/looks/performance.
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 04-28-2011, 09:21 AM   #11
Las0mbra's Avatar
+1 to that. You'll want to rotate them sometime.
Old 04-28-2011, 10:40 AM   #12
Re: Tire size
for a 2005+ 20 inch rims look perfectly fine, do NOT go any less than 18s.. and even they look to small.
Old 04-28-2011, 02:24 PM   #13
soccerfreak2143's Avatar
+1
soccerfreak2143 is offline   Reply With Quote
Old 04-28-2011, 04:05 PM   #14
Do the 20's fill the wheel wells or would I need to lower it some?
Old 04-28-2011, 04:31 PM   #15
Loc: Austin,TX
Re: Tire size
Yes,You will need to lower it to close up the gap otherwise it will look funny like a 4x4. Well worth the effort though.
Here is a pic of my 07 with 20x9s and 255/35/20s on all 4 corners with the FRPP 1.5 drop.It closes up the gap very nicely.
The other pic is my 2011 with 20x8.5 up front with 255/35 and 20x10 in the rear with 285/30s. No springs installed as of yet so you can see the gap in the wheel wells.
Hope this helps.
Old 04-28-2011, 05:09 PM   #16
Still looks good but I see ur point. Are those foose wheels?
Old 04-28-2011, 05:13 PM   #17
Loc: Austin,TX
Re: Tire size
Shelby Razors on the 07 and Boss 338s on the 2011.
Old 04-29-2011, 07:29 AM   #18
Re: Tire size
lowering is a GREAT change in looks, springs are cheap and easy to install on 05+ cars. Just need an alignment check after and your good. Eibach prokit is not bad for the money the sportlines are to low though IMO.
Old 04-29-2011, 08:02 AM   #19
Loc: Austin,TX
Re: Tire size
+1 Spec is right. Lowering any vehicle gives it a totally different appearance. More aggressive and sleek.
Old 04-29-2011, 09:44 AM   #20
So if eibach is not bad and sportlines are too low then what is the best?
Old 04-29-2011, 09:48 AM   #21
Re: Tire size
the eibach prokit seems to be what many 05+ owners go with. The eibach sportlines are just really low~
Old 04-30-2011, 06:05 PM   #22
Just curious as to why you say it would be better to run 285 than the 305?
Old 05-04-2011, 07:45 PM   #23
Bump
I'm real curious to know before I make the purchase.
Old 05-04-2011, 08:33 PM   #24
Loc: Austin,TX
Re: Tire size
Because its gonna cost more for a 305 vs a 275,285 or a 295.If you aren't a serious track car then why waste the money?
New Tire size help. explicitrock Mustang Wheels & Tires 11 03-07-2011 12:30 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
tire size cas1 General Car Discussion 1 01-01-2008 09:32 AM
What tire size? StangGt804 Mustang Wheels & Tires 14 04-03-2005 10:41 PM
Need a tire size horess05 Mustang Wheels & Tires 10 05-21-2004 08:41 AM
08:54 PM
