Post dyno problem - Mustang Evolution
Old 04-27-2011, 10:24 AM   #1
LaFlamaBlanca's Avatar
Post dyno problem
Ok so I got my dyno and it was lower than I expected....whatever. What pissed me off was that right before I got home the car died....twice! Had a battery light and the oil light (the one that looks like a gravy boat). turned the key off and it started up tho. Checked all connections. None seemed to be loose. Pushed on all relays and fuses but nothing seemed loose. What happened? I have a Jon Lund tune in it right now that I tuned last friday and the sct tuner I have lost the vin and my car wouldn't start at all after. Couldn't even re stock it.
LaFlamaBlanca is offline   Reply With Quote
Old 04-27-2011, 08:17 PM   #2
389.73rwhp 378.32rwtq on the dyno today
Old 04-27-2011, 08:18 PM   #3
Las0mbra's Avatar
Who knows though, some dynos are weird. You might make 410hp on another one
Old 04-27-2011, 08:37 PM   #4
This one was a dyno jet. If I went to the mustang dyno I think it would have been higher
Old 04-27-2011, 09:30 PM   #5
Re: Post dyno problem
Mustang dyno typically reads lower than dynojet...if you're just wanting numbers then tell the operator to change variables and make the numbers you want.
I would recommend contacting the person who tuned the car and explain to them the issues you are having.
Old 04-27-2011, 10:15 PM   #6
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
So is it not running now? I hope you get it figured out. That could be bad.
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-28-2011, 02:54 AM   #7
-Will
No its running. It started up each time it died. Kinda seems like the engine just stalled out. I was slowing to a stop and put it in neutral like I always do and as I turned the corner to give it gas I realized it was not running. I had the radio on loud so I wouldn't have heard it die.
Old 04-28-2011, 09:34 AM   #8
jimbullit's Avatar
...and this could be the 'down side' of monkeying/modifying /programming the stock ECM.. (`Not that I am 'wishing' problems on anyone -nor, am I advocating just leaving a vehicle stock, either...) That's a bummer. I would also be questioning the 'source'/tuner, and give them an 'earful' , regarding your experience(s)..!!
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Reputation Feature: Like someones post or hate it? Rate their post. Brent ME Site Help & Announcements 15 03-21-2006 08:14 PM
Went to the Dyno BirminghamStang Pre-2005 V6 Mustang 2 12-10-2005 10:54 PM
NE DYNO DYNO DAY 11/8 BlueDonkey Regional Mustang Discussion 9 11-13-2003 01:51 PM
going to dyno mheath Pre-2005 V6 Mustang 0 08-16-2003 02:23 PM
03:02 AM
