More horsepower? - Mustang Evolution
Old 05-22-2011, 01:58 AM   #1
IHBA's Avatar
More horsepower?
Got 2010 gt 4.6.. has basanni exhaust and that's it. I want to increase power what is the first thing to do?
IHBA is offline   Reply With Quote
Old 05-22-2011, 08:36 AM   #2
06mustangmike's Avatar
Re: More horsepower?
depends on how much you want to spend and how much hp you want?
06mustangmike is offline   Reply With Quote
Old 05-22-2011, 10:52 AM   #3
wereKEV's Avatar
yuponey talks and bs walis.
wereKEV is offline   Reply With Quote
Old 05-22-2011, 01:07 PM   #4
Intake and tune is a great place to start. If you want to go big or go home bolt up a supercharger
2005 Redfire GT - Mac LT's/prochamber, Pypes mid muffler, FRPP hotrods, 4.10's, Steeda tri-ax, JLT CAI, Bama tuned, Nitto nt05's 333/327 dynojet A little go go juice too
Southern stang is offline   Reply With Quote
Old 05-22-2011, 07:08 PM   #5
Titus Wadicus
svtlx's Avatar
+1...go big or go home!!!!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-23-2011, 11:45 AM   #6
wereKEV's Avatar
I go big or get a loan.
Old 05-23-2011, 12:21 PM   #7
Titus Wadicus
svtlx's Avatar
Old 06-03-2011, 09:40 AM   #8
Region: Arkansas
If your just looking for seat in the pants faster, I would say toss some gears in there because it is relatively cheap.
HIS: "Night-Mare": 2012 Mustang GT/CS, Black on Black, MT, 3.73 Gears, HID's, Security/Comfort/Electronics Packages. #2 of ????
HERS: "Blue Steel": 2012 Mustang V6, Kona Blue, AT.
Gconn007 is offline   Reply With Quote
Old 06-03-2011, 10:31 AM   #9
wereKEV's Avatar
gears is about the fastest and cheapest thing to get for some more speed.
My horsepower is faster than your horsepower Lalayla The Bar 24 03-17-2011 10:12 PM
Horsepower SportySpice Pre-2005 V6 Mustang 2 01-05-2011 07:37 PM
more horsepower 1997mustang New Member Introductions & Greetings 7 09-03-2010 06:02 PM
Horsepower JAYS MUSTANG Pre-2005 V6 Mustang 9 11-12-2006 07:36 PM
5-8 horsepower for only 4.99!!! Zim The Bar 18 06-09-2006 02:41 AM
09:00 AM
