Eibach Pro-Kit Springs - Mustang Evolution
Old 05-30-2011, 01:07 PM   #1
poloka's Avatar
I purchased my first mod for my Mustang and wanted to know if anyone had some tips for installation? And roughly how long it took for the install?
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 05-30-2011, 01:19 PM   #2
Kpd3014's Avatar
It usually takes about 2 hours if you are familiar and take your time. If you have access to aloft it makes it 10 times easier.
The back is the easiest, takes about 10 minutes. Drop the lower shock bolt ensuring you have something supporting the rear end. Once they are disconnected lower the rear slightly and pull both springs out. Replace and reinstall.
The front once you get the front brakes hanging off the rotors and take off the top for strut assembly bolts and lower shock bolts be careful when compressing the springs. Pretty easy stuff really. Made even easier if you have impact tools.
If this link works it's a great install how to from another mustang forum. Even though it's an 05-09 the steps are the same overall.
http://www.google.com/m/url?client=s...3xk1HgPAJiWLkw
2012 GT500 PP, NAV, SSW exhaust, BMR lowering springs
Kpd3014 is offline   Reply With Quote
Old 05-30-2011, 01:40 PM   #3
poloka's Avatar
What about cam bolts? Ive heard I may need some for alignment. Should I bring my own or do dealers have 'em?
Old 05-30-2011, 02:15 PM   #4
Kpd3014's Avatar
I bought the BMR lowering springs and the cam bolts. I installed the springs an when I took it to get the alignment done I gave the bolts to the guys and they installed them with the right amount of camber/caster. I was going to buy the full caster plates but the guy here said they werent that far out.
Old 05-30-2011, 02:49 PM   #5
Loc: Austin,TX
Re: Eibach Pro-Kit Springs
If your jack is placed under the front lower control arm, this will slightly compress the spring and allow removal of the upper strut nut without movement of the spring.
LRS has a great write up and its what I used to walk me through.
2011 Mustang GT 5.0 Ford Racing Lowering Springs Install - LRS Blog - Read Here Shop Here
Old 05-30-2011, 02:55 PM   #6
poloka's Avatar
Thanks! I ran across that blog. Just been so used to breaking out the strut coil compressor. Most likely will take care of this next weekend. That is if my springs come in the mail before Friday.
Old 05-30-2011, 03:33 PM   #7
gtstyles2's Avatar
Are you only changing the springs? I don't know mustangs well, but wouldn't it be harsh ride if you don't also change the struts/shocks?? I plan to do a eibach pro kit upgrade in the future as well but I don't want to lose the ride
Old 05-30-2011, 03:49 PM   #8
poloka's Avatar
I'm going to find out. My Ford Racing expert at the dealership informed me that the stock struts are okay for now but don't 'need' to be upgraded and my ride should be about the same. If I went with the sportline kit things would have been rough. But once I pick a suspension package I'll be replacing everything.
Old 05-30-2011, 03:51 PM   #9
Loc: Austin,TX
Do you expect it to ride like a cadillac?
Old 05-30-2011, 03:53 PM   #10
Send a message via Skype™ to Texastboneking
Mine rides like a caddy, with bad shocks and struts and springs
Texastboneking is offline   Reply With Quote
Old 05-30-2011, 03:56 PM   #11
poloka's Avatar
Nope. But since I'm just toying around I figure I'll find out. Now if it is an extremely rough ride in comparison to stock then yeah, I'm going to have some beef with my dealer cause i'd swap out the strut while I've got it out. But if I have to go back in after it's no big deal. Trial and error on what I like.
Old 05-30-2011, 04:34 PM   #12
Loc: Austin,TX
Its not that bad unless ur a old fart with arthritis.
Old 05-30-2011, 05:28 PM   #13
gtstyles2's Avatar
I went through alot with dropping in the past with my older cars.... It's best to do the full spring/shock setup from the beginning so u won't go thru more headaches later
Old 05-30-2011, 06:07 PM   #14
LSUstang's Avatar
Send a message via AIM to LSUstang
+1
-2004 Mach 1 "Natasha"- JL Audio W6 w/ custom box, 8000K HIDs, Sequential signals, StangHi tune, Borla Stingers with catted X, deck lid & lower valence, C&L intake package, H&R Super Sports
-2001 White Vert V6- Sold
LSUstang is offline   Reply With Quote
Old 05-30-2011, 06:11 PM   #15
Kpd3014's Avatar
I can tell you on the 05 i had the pro kit installed with just the springs and the ride definitely suffered. I went with the sportline on my wife's and the ride was stiff also. I have found that with eibach you should change both at the same time if you really care about the ride. If you don't mind feeling the bumps, and just want the stance then don't worry about the shocks.
Old 05-30-2011, 07:15 PM   #16
poloka's Avatar
What shocks would you pair with the pro-kit?
Old 05-30-2011, 07:36 PM   #17
poloka's Avatar
I guess to work best I should get the pro-dampers to work with the springs. I'll get those. First I want to feel the ride differences. I'll let you know my thoughts.
Old 05-30-2011, 09:22 PM   #18
Kpd3014's Avatar
Cool good luck
Old 05-30-2011, 09:29 PM   #19
gtstyles2's Avatar
Definitely let us know how the ride is, I wouldn't just change the springs only. My last car I finally did it correct, I had the eibach pro-kit paired with KYB struts on a Maxima and I was very happy with it... It took 3 overhauls to finally learn that u should do the whole setup at once. I just want to know what shocks/struts are good on mustangs since this is my first mustang.
Old 05-31-2011, 01:48 PM   #20
FireRescueBRFD's Avatar
I would not do it myself, I did it on my 2001 Gt it's easier on the newer mustangs but it's not worth it IMO 3 hours of labor couple hundred dollars or so and it's professionally done your axles is still centered u don't mess anything up and can get alignment done immediately just my two cents
FireRescueBRFD is offline   Reply With Quote
Old 05-31-2011, 07:28 PM   #21
poloka's Avatar
It was a debate. But now adding the shocks I'll save what I'll pay for an alignment. Good thing the dealer is less than 5 miles away so shouldn't chew up the PZeros. Need to find a good site to get the shocks.
Old 05-31-2011, 08:19 PM   #22
Kpd3014's Avatar
http://www.latemodelrestoration.com/...-And-Strut-Kit
Old 05-31-2011, 08:25 PM   #23
poloka's Avatar
Damn, bought springs for $200 but struts alone are $500. Could have saved $50 with the kit. Oh well. Thanks for the link!
Old 06-01-2011, 04:04 PM   #24
poloka's Avatar
Tried ordering the shocks/struts today and seems the pro-dampers are popular and out of stock till 22nd. Found them at AutoAnything for under $400. Once I get them ordered I'll get them on and give my evaluation.
Old 06-26-2011, 08:45 AM   #25
poloka's Avatar
Installed my new springs w/o new shocks cause tired of waiting for them to be in stock. Ride feels same. Lucked out on alignment that the caster was in spec. For some reason even though a 2011 mustang the vin brought up a 2010 alignment specs. Kind of odd. Is this an issue to be concerned with? Even my title notes 2011. And does the rear numbers look good? Since a solid rear nothing to change.
ID:	28377   Click image for larger version
Old 06-26-2011, 09:53 AM   #26
gtstyles2's Avatar
Cool, so the ride wasn't even a bit stiffer? I guess these new mustangs already have sport tuned dampers.... Hopefully over time the new height won't wear out the dampers out prematurely... This is most likely the next mod I wanna do cuz I hate the gap in rear wheels... I just don't want to ruin the ride and keep changing things, I just want to do it one time the right way!! Would u be able to post pics of the new stance??
Old 06-26-2011, 10:40 AM   #27
poloka's Avatar
Wasn't stiffer which I was surprised. Ride felt good. I'll pull some corners to see if any sway when I take it back out later plus get a full shot. Forgot to take a good before side pic. As for dampers, figure I planned to replace the shocks anyways so if they wear out early... oh well. And as easy as it was to get them out w/o spring compressor it shouldn't be an issue to go back in. Literally, I had each front wheel off then back on in under 30 minutes with using a stand and jack. Hardest part was realizing I didn't have the 21mm 1" drop wrench. Had up to 20 in one set and another started at 22. Wasn't happy and couldn't find a shop around that carried one. So I'll order my two missing wrenches. The standard 21mm was too fat to get down and hold the tower bolt while turning the 13mm strut top.
ID:	28379   Click image for larger version
Old 06-26-2011, 11:37 AM   #28
gtstyles2's Avatar
Lol must suck not to have the exact socket u need, especially once your into the job... But at least u got it done, plus its good to know the work wasnt extremely difficult the but the drop is perfect I can't wait to do mine, which dampers were u trying to get? I guess if the stock dampers wear out quick, I guess I wont notice right away since this isn't my daily driver
Old 06-26-2011, 12:51 PM   #29
poloka's Avatar
Being my daily driver I'll find out how quick they do wear. I was looking at Eibach's pro dampers. But I like the Roush suspension upgrades. I'd like to see how the stage 3 suspension feels. Figure it would be more rigid but don't know until you try or know someone with the upgrade.
Old 06-26-2011, 01:05 PM   #30
gtstyles2's Avatar
That's exactly what I was looking at... The stage 2 kit, I figure if I take the plunge, I might as well go for that setup. But I havent seen any reviews on it... That's why I'm taking my time on what to pick... Money is tight, so I wanna do it the right way the 1st time
Old 06-27-2011, 07:44 PM   #31
poloka's Avatar
Well, with recently paved onramps around my area I pulled some hard turns. No roll. Feels good and tight so impressed with the springs. Wish I had a G gauge like the vette but either way felt good and solid on very hard cornering. Next I'll upgrade to solid control arms and urethane bushings.
Old 06-27-2011, 08:00 PM   #32
Loc: Austin,TX
Car looks good Polka,that drop really changes the look of the car. Might wanna look into a adjustable panhard bar due to the rear end shifting over just a tad. It just drives some people crazy but I barely notice it and will get the adjustable panhard a little later down the line. I think some LCAs are next on my list.
Old 06-27-2011, 09:41 PM   #33
poloka's Avatar
To driver or passenger side? Guess I should just get under there and look to which way it would push. Is it trial and error for getting an adjustable right or do the bars come with recommendations on settings per spring setup? What bar is recommended?
Old 06-27-2011, 10:49 PM   #34
Loc: Austin,TX
No need to crawl underneath it. You can look at the rear tires one at a time and you will see that one side will poke out a litte further than the other. Any brand will do just get a quality adjustable panhard bar.
Here is a tech write up for the install.
http://mustangforums.com/forum/2005-...on-w-pics.html
Old 06-28-2011, 08:02 AM   #35
poloka's Avatar
So you'd recommend steeda over a ford racing or BMR panhard bar and brace? Just wondering what my options are and is there really a difference in them?
FS: Eibach Pro-Kit DarkShadows Mustang Parts for Sale and Wanted 7 06-16-2009 11:32 AM
frpp c or eibach pro kit carlosc Pre-2005 V6 Mustang 7 01-19-2009 09:18 AM
Eibach Pro kit SVT_99_Cobra Mustang Parts for Sale and Wanted 2 06-09-2005 12:05 AM
eibach pro kit springs cagedthought Pre-2005 V6 Mustang 4 01-25-2005 09:33 PM
02:38 PM
