Clunking Gear Shifting - Mustang Evolution
Old 06-02-2011, 06:37 PM   #1
poloka's Avatar
Something I've noticed is when at low speeds and low rpms that It is almost like i hear the gears grinding. And if I am slowly moving say under 5 mph in first gear up a slight incline and then push in the clutch I hear a clunk. Not sure how to describe it but after reading about a 5.0 engine blowing up because the clutch bolts came out I wonder if the sounds I'm listening to is normal?
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 06-02-2011, 07:30 PM   #2
Stupidfast5.0's Avatar
Re: Clunking Gear Shifting
There is a TSB for both problems you are mentioning. No, the sound is not normal, but it is normal on these cars. You need to let the transmission warm up before rowing gears at low rpm. If you have an early build car and the bolts do back out, there is no way that it could possibly cause you to blow your engine.
You said you are going to replace it with a boss engine if it blows under boost anyways, so who cares?
2011 Mustang GT Premium, M6, Procharged.
Stupidfast5.0 is offline   Reply With Quote
Old 06-02-2011, 08:00 PM   #3
poloka's Avatar
Good point on the replacement.
Clunking? ColeJohnson 1996-2004 Mustang GT 8 03-29-2011 11:25 AM
Clunking noise when shifting Halyssvt 1996-2004 Mustang GT 7 03-08-2011 12:48 PM
shifting into gear, axle noise audio75 Pre-2005 V6 Mustang 9 07-18-2010 11:08 PM
Clunking sound coming from rear?? ricklmesa Pre-2005 V6 Mustang 6 11-14-2006 09:36 PM
drove to ATL, clunking the whole way..funny story tedness The Bar 32 09-27-2005 05:38 PM
02:32 AM
