Which supercharger? - Mustang Evolution
Old 06-10-2011, 06:51 AM   #1
Kpd3014's Avatar
Which supercharger?
Ok so exterior of my car is finished. Time to force feed the girl. My question is simple, which systems do people already have and what are your true thoughts. I have had a procharger on my 05 and still have my 04 with a procharger so that is what I am familiar with. I am wondering if the Ford Racing kit is worth the warranty?
2012 GT500 PP, NAV, SSW exhaust, BMR lowering springs
Kpd3014 is offline   Reply With Quote
Old 06-10-2011, 07:01 AM   #2
Send a message via Skype™ to Texastboneking
Honestly go for a roots supercharger. Your low rpm torque will be much higher with one. Like a factory 03 04 cobra
Texastboneking is offline   Reply With Quote
Old 06-10-2011, 07:02 AM   #3
Re: Which supercharger?
hmm good question, a single turbo will make the most power per psi... but a twin screw will give you the best street car driver (low end)
A centri is easy simple and it works... as far as brands whipple for roots (ford racing has one), or paxton/procharger for centri.
Old 06-10-2011, 07:04 AM   #4
I think it all comes down to what you want. Both PD and Centri blowers have pro's/con's.
The roush blower seems to be the real top dog right now as far as track times. Least with it being a shop car. But the Procharger/Paxton seem to be making the most power. The guys with them just haven't really been hitting the track. No matter what every blower is in the 10s.
I will be going with a procharger stage 2 with upgraded blower. Goes great with the Boss intake and great power for track and street. Plus the building of boost lets me not worry about traction when on the street.
Old 06-10-2011, 07:05 AM   #5
Thers a few that have warranties. Frpp and edlebrock have powertrain warranties. If I rmember correctly others just warranty the supercharger. Other than that, there are a pretty good mix of what people are getting. I personally like twin screws and will probably go with kenne bell or edlebrock for their warranty.
klisetron is offline   Reply With Quote
Old 06-10-2011, 07:08 AM   #6
With good is that much higher tq if you are spinning the whole time. Also I know a bunch 03-04 cobra's that have went turbo or centri.
Old 06-10-2011, 07:11 AM   #7
Only the FRPP 525 kit comes with warranty.
The Edlebrock only keeps warranty is nothing else is done to car. Exhaust or anything. Soon modify it from stock car with just the SC on it you lose the warranty.
I have looked into both kits and warranty.
If you are worried about warranty go with the FRPP 525hp kit or just don't get a supercharger.
Old 06-10-2011, 07:11 AM   #8
Kpd3014's Avatar
If memory serves correctly you work at a dealership? When the ford racing supercharger kit is installed at the dealership does it still void the regular warranty and they only warranty the supercharger work or what?
Old 06-10-2011, 07:14 AM   #9
I would not go with a roots blower, if you go with a positive displacement blower go with a twin screw (roots is not the same as twin screw)
Old 06-10-2011, 07:16 AM   #10
Kpd3014's Avatar
The warranty isn't a real big issue for me. With that being said the other half of my household prefers to maintain some type of safety clause or warranty if I upgrade. I am curious to know but will make the ultimate decision on overall value.
I guess I should also mention I don't run the car and only get the supercharger for daily driving fun or "merging into traffic when I need it" as I often tell the wifey.
Old 06-10-2011, 07:16 AM   #11
Oh my bad? What's the difference?
Old 06-10-2011, 07:17 AM   #12
True bad they wanted more power than the supercharger put out. He want a supercharger. Not a turbo
Old 06-10-2011, 07:17 AM   #13
this has good info http://www.kennebell.net/techinfo/ge...romcatalog.pdf
Old 06-10-2011, 07:20 AM   #14
Correct. Or at least that is how it is here. You are putting strain on all the components (engine transmission rear diff driveshaft.) that the car was not designed for. Now you can check with your dealer. They might do it differently. And you might be able to talk about warrantying it with them
Old 06-10-2011, 07:22 AM   #15
Thanks. That helped. Didn't realize the difference.
Old 06-10-2011, 07:22 AM   #16
I belive the supercharger retains the 3 yr/36k if installed by ford and the tune is not changed~
Old 06-10-2011, 07:23 AM   #17
Kpd3014's Avatar
Great link that helps alot.
Old 06-10-2011, 07:54 AM   #18
thanks -----> is located just a bit to the right lol
I personally think a twin screw is a great setup for a street car vs centri, you dont get the noise though~
Old 06-10-2011, 08:16 AM   #19
If just want a street car I would probably just go with the FRPP 524ho kit. Maintain full warranty if ford dealer installs it. Plus still have about 450whp to get up and go when need it.
Old 06-10-2011, 08:35 AM   #20
... Not on the iPhone...
Old 06-10-2011, 09:57 AM   #21
wereKEV's Avatar
mine has a vortech supercharger seems to work quite well but don't have the whine the twin screw has.
wereKEV is offline   Reply With Quote
Old 06-12-2011, 05:58 PM   #22
Stupidfast5.0's Avatar
I have a procharger. I don't care for PD blowers.
2011 Mustang GT Premium, M6, Procharged.
Stupidfast5.0 is offline   Reply With Quote
Old 06-12-2011, 07:35 PM   #23
Kpd3014's Avatar
Ok been reading the thread about the Hellion kit and I was considering getting that one. Price and power seem to be a little better than a supercharger and from what I gather of I decide to go more than 9psi all I need to do is upgrade internals. True or false and thoughts?
Old 06-12-2011, 07:54 PM   #24
Turbo>*
But, the hellion kit is pretty much crap. You have exhaust pipes running under your k member, a pointless intercooler, a lawn mower air filter, and a turbo that will be glowing 1" from your plastic bumper assembly. Don't be the first one to buy it.
It's cheap because it's cheap. If you want a turbo you would be better off having one built for you, which isn't cheap.
Old 06-12-2011, 08:30 PM   #25
Kpd3014's Avatar
Cool thanks
Old 06-12-2011, 10:17 PM   #26
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Any of the well known, proven names are worth your time and $$$....Procharger, Vortech, Whipple, etc...
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-13-2011, 12:03 AM   #27
Originally Posted by Stupidfast5.0 View Post
Turbo>*
Not only does it run under the K member it runs threw it. Guy on modularfords is installing a kit and mentions ho wit still runs threw it. I know i don't like that idea
I have a friend who has had nothing but issues with his Hellion kit on his 08. He finally said F' it and ripped it off and went with a KB. He also has a 302 crate engine in it and not the 4.6.
Old 06-13-2011, 12:14 AM   #28
Kpd3014's Avatar
Thanks guys, guess I'll keep looking.
Old 06-13-2011, 06:51 AM   #29
Pushrod or modular?
-Will
Waffles
Need a supercharger 2002roushstang 1996-2004 Mustang GT 6 02-03-2011 03:58 PM
supercharger chris purcell Pre-2005 V6 Mustang 17 01-31-2011 02:35 AM
Supercharger help Max420 2005-2010 Mustang GT 26 02-16-2009 01:00 PM
Supercharger ridenmystang 1996-2004 Mustang GT 36 07-25-2006 09:28 AM
gt or supercharger....? chevykiller Pre-2005 V6 Mustang 13 08-14-2004 04:41 PM
11:41 PM
