Roush CAI vs. stock air box w/ drop-in K&N - Mustang Evolution
Old 06-16-2011, 07:26 AM   #1
meast553's Avatar
Hello everyone! I am new to these forums after finally getting back in the game with my 2012 Mustang GT/CS. I previously had several trucks in between owning a 1999 Mustang GT 35th anniversary edition.
I have been checking the forums for a few days now looking for answers regarding the Roush CAI but havn't had much luck. Hopefully someone can point me in the right direction.
First of all, does the Roush CAI perform reasonably better than the stock airbox with a K&N drop-in filter? Roush advertises that it does not require a tune and it is like a factory fit. Will the computer automatically adjust for the small amount of air flow change or will there be problems with it running lean? I don't want to go so far as to change the tune in it just yet but wanted to do some minor mods/upgrades to increase the performance.
Thanks for any insight you can provide!
meast553 is offline   Reply With Quote
Old 06-16-2011, 08:15 AM   #2
austinknoll's Avatar
I think the 2010+ mustangs all have learning computers so I don't think you would need a tune
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 06-16-2011, 08:20 AM   #3
Send a message via Skype™ to Texastboneking
They learn to an extent. You cant drop cams in it and expect it to learn how to run with them. It depends on what your budget is. If you really don't have money and your lookin for power I don't think a cai is going to impress you. They just don't do much. I say get the drop in filter. The high flow filter is where you are going to see most of the gains from a cai.
Texastboneking is offline   Reply With Quote
Old 06-16-2011, 09:33 AM   #4
Re: Roush CAI vs. stock air box w/ drop-in K&N
My input is... if its an 05+ and the intake does not require a retune then its probably not doing nearly good enough of a job. Get one that requires a tune and get much more performance.
Even if you want to maintain warranty (no tune) and you buy one that does not require a retune I HIGHLY recommend getting it dynoed to check and make sure your car is safe.
Old 06-16-2011, 12:46 PM   #5
I think one issue is no one is running the Roush cold air. Most people went with Steeda/JLT/C&L. Which all them require a tune.
Now there has been several threads on other mustang forums if the cold air is worth it. Many say yes many say no. But few have switched it at the track and seen no gains with the cold air from the few that do not require a tune. Airraid/C&L has optional no tune one.
Others with ones that need tune claim it was tune that made difference, while others say it was a combo of both.
There is guys that have ran 11.8's with tune only while others went 11.8 with tune and Cold Air. It is all really hard to prove what one was better since ran different tracks.
Dyno shows they pic up power. But They was all also all Dynoed with a tune at same time.
Old 06-16-2011, 12:48 PM   #6
I like you! Someone actually researched instead of going with what the websites claim! Awesome! No one else will search they just think "modification gives more power"
Old 06-16-2011, 01:04 PM   #7
stangaroo's Avatar
Anyone under 12 is running with radials or slicks. I saw someone run 12.2 with only radials, no weight reduction and no other mods...
The intake/tune combo isnt doing much IMO.
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual and I still get over 26 mpg
stangaroo is offline   Reply With Quote
Old 06-16-2011, 01:24 PM   #8
you dont always need non street tires, suspension matters a ton as well as does track prep and other conditions
Old 06-16-2011, 01:30 PM   #9
meast553's Avatar
Thanks for the input guys. I like the look of the Roush kit and wasn't expecting alot of hp gains with it. Had a cai on my old stang with no issues, just wanted to see if this one would cause any problems other then no real hp gain.
Old 06-16-2011, 07:57 PM   #10
Stupidfast5.0's Avatar
A drop in filter is a waste of money. They offer zero gains.
Werd. If it doesn't require a tune it's not doing much.
2011 Mustang GT Premium, M6, Procharged.
Stupidfast5.0 is offline   Reply With Quote
Old 06-16-2011, 09:45 PM   #11
Loc: Austin,TX
+1
Old 06-16-2011, 11:35 PM   #12
stangaroo's Avatar
Originally Posted by DDTCM
+1
+2
The only reason I am considering the drop in is for the sake of not buying the paper ones over and over
Old 06-16-2011, 11:37 PM   #13
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Get it, it'll look better and it won't hurt.....it'll help if anything
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-17-2011, 08:08 AM   #14
+2
amsoil is now making oil less filters you just rinse them and dry I think, its a good way to go for a drop in or any filter
Old 06-17-2011, 09:48 AM   #15
jimbullit's Avatar
If it "breathes better", it will perform better. You would move more air with the K&N, than the stock paper element. Are you going to "feel" this in the 'seat of the pants'..? Perhaps-very slightly?
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 06-18-2011, 08:33 AM   #16
+10000.
All the Cold airs that have claimed big gains require a tune. It needs a tune cause of the tube size being changed. Simply put.
If you can fee 4whp(if lucky) then you have to baddest butt dyno in the world.
Also there has been cars run low 12s with nothing done to the car. Yes it was with great air. But it has been done.
Best bone stock manual is 12.22@115, best auto 12.37@XXX. Both was run at the same track. Cecil and the crazy great DA they have there.
Old 06-18-2011, 11:09 PM   #17
Resident Saint's Avatar
I have the roush CAI. It was an easy fit and hasn't caused any problems. But like everyone has said, didn't make much of a difference. I added roush exhaust, so i just went ahead and put the CAI on too.
Resident Saint is offline   Reply With Quote
Old 06-19-2011, 07:28 PM   #18
Link to Amsoil filters?
-Will
Waffles
Old 06-20-2011, 09:01 AM   #19
jimbullit's Avatar
I "stand" by what I said.
I also wasn't saying that one would be able to"feel" a difference-so much as the filter will pass more air and the engine will breathe better.
Old 06-20-2011, 09:19 AM   #20
AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases
Old 06-20-2011, 11:10 PM   #21
So, you think that putting a K&N filter into the stock airbox will increase your trap speed?
Old 06-20-2011, 11:12 PM   #22
come on stupidfast! beat him down! beat him down good! do what you do best!!!
Old 06-20-2011, 11:13 PM   #23
It's a question. How is that a "beat down?"
Old 06-20-2011, 11:16 PM   #24
cause i know where your gonna go with it. your gonna let him try to explain then your gonna tell him he is wrong and that he should do research. its a trend you have in every thread you ask someone a "question"...
Old 06-20-2011, 11:19 PM   #25
your>you're
If a drop in filter made more power it would increase your trap speed. Correct?
Old 06-20-2011, 11:23 PM   #26
your>you're
thank you spelling police! i sure hope my old English teacher dont (i mean don't) see that!
and the filter dont (again i meant don't) make the power. the extra air (and possible debris) that it allows through it lets the engine breath better. so a slight increase is expected but not always given. depends on the original filter size and micron rating. as he said you wont be able to "feel" the difference...
Old 06-20-2011, 11:28 PM   #27
If you can't feel a difference, and it makes no noticeable difference on a dyno, and it doesn't increase trap speed....what difference did it make?
Old 06-20-2011, 11:31 PM   #28
ill say it again... it depends on the original filter and how restrictive it is. if its a filter with a large filtering area then no a drop in filter is useless. but if its a small filter like in the 06-07 focus then you can get a little benefit from the drop in filter.
Old 06-21-2011, 02:58 PM   #29
I will say the drop in K&N filter does jack & ****!. Its a waste of $50+. Seen to many people have one in numerous cars and make no difference how fast the car trapped/ET'd.
Old 06-21-2011, 04:38 PM   #30
jimbullit's Avatar
It's comforting to be 'surrounded by' so many experts..
Old 06-21-2011, 09:29 PM   #31
Am I included in the experts?
Old 06-21-2011, 09:55 PM   #32
My drop in K&N netted 8 HP with a tune
-Will
Waffles
Old 06-21-2011, 10:00 PM   #33
Originally Posted by Knight F Mohawk View Post
My tune netted 8 hp.
-Will
Fixed
Old 06-21-2011, 10:36 PM   #34
Fixed
Nope, tuner said it was all the filter
-Will
Waffles
Old 06-22-2011, 07:15 AM   #35
pre 05's didnt gain nearly as much with intake/filter the 05+ make a bigger difference (with tune)
cai
K&N drop in air filter Everett Mustang Parts for Sale and Wanted 7 02-23-2011 11:40 PM
2010 mustang Gt stock cai vs aftermarket cai godsdisciple85 2011-2014 Mustang GT 1 02-03-2011 07:49 AM
fs: 2 jl 10" subs, 500w mono amp, custom box & wall tedness Mustang Parts for Sale and Wanted 3 05-12-2005 10:42 PM
k&n air filter PN to fit a 99+ mac cai tire Pre-2005 V6 Mustang 6 11-26-2003 01:57 PM
11:50 PM
