Voiding the Power train warranty - Mustang Evolution
Old 07-10-2011, 05:41 AM   #1
dailey's Avatar
If i put this Boss Intake on my car, I will have to buy a custom tune that will void the power train warranty. If i were to ever have a problem with the power train...and had to take it to a dealership...if i had the original in take put back on and loaded the factory tune back in the car....could the dealer tell i did it?
dailey is offline   Reply With Quote
Old 07-10-2011, 07:57 AM   #2
Re: Voiding the Power train warranty
Yes. New computers basically hold all information. If you flash the computer back to stock the computer will tell them you recently flashed the computer.
Old 07-10-2011, 11:36 AM   #3
Stupidfast5.0's Avatar
Why do you need a custom tune with the boss intake? If you are worried about breaking the car then you don't need to rev it past 7k rpm anyways. The car will run fine with the factory tune.
2011 Mustang GT Premium, M6, Procharged.
Stupidfast5.0 is offline   Reply With Quote
Old 07-10-2011, 01:46 PM   #4
dailey's Avatar
the dealer and ford racing told me I had to have a tune... are you saying I don't?
Old 07-10-2011, 01:52 PM   #5
Jamesgt08's Avatar
You do need a tune for the boss intake.
Jamesgt08 is offline   Reply With Quote
Old 07-10-2011, 02:31 PM   #6
Nope. Pull the negative terminal during installation, install the intake, put everything back together, let the car idle for 10 minutes with the a/c off, then 5 minutes with the a/c on and enjoy. Car will behave just like it did before the intake, with the exception of a noticeable loss of streetable power.
You only need to tune when adding forced induction, changing the maf housing size or location, or various electronics systems.
Again, no tune is required when adding the boss intake manifold when it is mated to the factory intake tube. If you have a aftermarket "tune required" CAI, then you already have a tune, so no update is required. Simply up the rev limiter to take advantage of the right shift in the power band.
No, you don't. I can swap between the two intakes on the same tune. I can add longtubes on the same tune. I can swap pulleys the same tune. I can spray a dry shot on the same tune. The AFR will always stay in check as long as you have enough fuel available.
Ford Racing Power Pack MALS Marine 2005-2010 V6 Mustang 7 06-30-2011 09:07 PM
09:54 AM
