Hellion Powered 2011 5.0L Mustang GT - DRAG STRIP VIDEO - Mustang Evolution
Old 07-25-2011, 07:01 AM   #1
7.01@100mph 1/8th mile
1.55 60' (spinning through first)
110° air temp
130+° track top temp (according to one of the staff members)
Not too shabby for my first time out with the new combo.
2011 5.0L Mustang GT 6R80 Transmission
Hellion Single 67mm Turbo System
Roush Axleback
3.55 Gears
Eaton Tru-Trac
Circle D Converter
Racestars fronts & backs
BFG Comp T/A 275-60-15 Drag Radials
3800 lbs. give or take a cheeseburger
JohnnyMustang is offline   Reply With Quote
Old 07-25-2011, 10:06 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Hellion Powered 2011 5.0L Mustang GT - DRAG STRIP VIDEO
o my gosh... if that thing coulda hooked up outa the hole... o boy!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-25-2011, 11:24 AM   #3
yeah... 1.55 60' spinning... When it hooks, it'll hang the wheels for a good distance.
Old 07-25-2011, 11:49 AM   #4
Titus Wadicus
svtlx's Avatar
there is no dought in my mind....
Old 07-25-2011, 01:17 PM   #5
Loc: Austin,TX
Nice,sounds awesome!
Old 07-25-2011, 07:58 PM   #6
Stupidfast5.0's Avatar
Pretty good mph for that heat.
2011 Mustang GT Premium, M6, Procharged.
Stupidfast5.0 is offline   Reply With Quote
Old 07-26-2011, 08:41 AM   #7
jimbullit's Avatar
Great video clip! What kind of horsepower is your car putting to the ground? When are you going to post a 1/4 mile timeslip?!
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 07-27-2011, 01:03 PM   #8
Thanks!
Car made just shy of 600hp and 640tq on the dyno, but with that heat, I'm sure it was less.
Once I get some better air quality, I'll make a full pass and post up some 1/4 mile times.
Old 07-27-2011, 03:18 PM   #9
Every one check this out about this car.kit..Some good info/speculation/questions, etc etc
BBR's Hellion Powered 2011 5.0 AUTO
Old 07-27-2011, 04:00 PM   #10
LOL at that thread. It's the same 3 people that always start **** on that board. Modular Fords has become a joke.
Old 07-27-2011, 04:19 PM   #11
Hate it or love it. It has some good points and questions about the kit. As in why such low shift points? Why no dyno pulls over 6500ish rpms?
Why you didn't run a full 1/4 pass, same questions over and over being avoided. All about the kit, its power, limits, etc etc.
Old 07-28-2011, 06:34 AM   #12
I've answered those questions there, but I'll answer here too.
Shift points are at 6800 b/c that is where I want them. The power begins to nose over around 7100 and I want to stay in the power band, so I have it set to shift early to come right in to the peek power and pull through the gears constant and hard.
I didn't make a full 1/4 mile pass b/c it was HOT as hell there and I never made a pass in the car before with this setup. I wanted to datalog the first pass 1/8th mile and then go back out there for a full pass, but unfortunately, Fastlane wrecked their X275 car and the track was shut down until damn near 11pm, so I never got that chance.
As for the kit, the kit fit perfectly fine on my car, it went on in 4 hours and I have no issues with fitment or rubbing. I'm not sure of the limits on this kit, b/c I'm only running 10 psi and I'm nowhere near maxing out the potential of this kit. I don't think any stock motor 2011+ will do that. That Precision 67mm turbo is good for over 1000. As for pipe diameter, like that was stated over there, there are outlaw cars running as small as 2.25" turbo piping and making 3,000 hp, so the sizing is just fine on this car. Lots of people think bigger is better... That's not always true.
I hope that cleared up some stuff for you.
Old 07-28-2011, 07:58 AM   #13
skyline247's Avatar
110° air temp
Roush Axleback
3.55 Gears
Eaton Tru-Trac
Circle D Converter
Very nice!
1988 GT - Stock
*SOLD* 2012 GT Premium, Black on Black, 3.55 Axle, HID and Security Package, Pypes Pype Bomb Axle Backs
skyline247 is offline   Reply With Quote
Old 07-28-2011, 01:46 PM   #14
Vinny just ran a mid 10 in 87* weather with a Hellion kit but the upgraded turbo. That more what I expect and also a 6.8 1/8 mile. Manual car.
Also what about power falling off up top? Do you think the boss would be a plus with this kit?
Old 07-28-2011, 02:21 PM   #15
drusmith's Avatar
Send a message via Yahoo to drusmith
Johnny,
Good points! Don't let people get in your head. you have a bad *** car! This is another reason why i want to get ride of my 2.2l KB for a Turbo!
drusmith is offline   Reply With Quote
Old 07-28-2011, 02:27 PM   #16
Las0mbra's Avatar
Originally Posted by drusmith
Johnny,
Do it! I have a friends stepdad making 750hp with 16 psi...
Old 07-28-2011, 03:19 PM   #17
I'm not sure. I want to see what I can do first with the stock manifold... then I'll add the BOSS manifold on there and see if there are any track gains. I'm not to worried about hp numbers. I want to see that ET and MPH.
Old 07-30-2011, 04:18 PM   #18
I'm debating pulling the trigger on one of these kits next week, already have the Boss intake.
Audidog is offline   Reply With Quote
Old 08-01-2011, 12:29 PM   #19
I love the Hellion system.
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
09:55 AM
