Front Tire Size - Mustang Evolution
Old 07-29-2011, 06:36 PM   #1
poloka's Avatar
Front Tire Size
Now that I've figured a rear size I planned to run 255/35R20 on the front until I noticed the GT500 has 265/40R19 on the front. 20's on rear but 19's on front. Odd look but it works. So I wondered if I could stuff a 265/35R20 up front rather than a 255/35R20 without rubbing issues with my pro-kit lowering springs? Anyone have thought or concerns?
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 07-29-2011, 06:44 PM   #2
Loc: Austin,TX
Re: Front Tire Size
What's the reason for stepping the front tires up?
Old 07-29-2011, 10:53 PM   #3
poloka's Avatar
More grip? Was more curious than really thinking about it. It was interesting to see the gt500 with the 265 up front. I know more rubber == more weight. So wondered what you guys thought. If I recall correctly most are 255.
Old 07-29-2011, 11:17 PM   #4
Loc: Austin,TX
Re: Front Tire Size
If you arent gonna be doing Auto X I personaly dont see the point in going any wider. Bigger in the rear...yes,to plant that power to the ground but a 255 up front is just fine IMO. I mean if you arent gonna take advantage of it whats the point. Amrite?
Old 07-30-2011, 02:15 AM   #5
Re: Front Tire Size
This. No reason to have huge tire in front.
Old 07-30-2011, 02:17 AM   #6
bbunt302's Avatar
I would try to go with the same size all around so you can rotate your tires.
Scary stuff.
Old 07-30-2011, 03:06 AM   #7
Re: Front Tire Size
WHAT? No way..what good is a 255/265 out back?
Old 07-30-2011, 04:18 AM   #8
zombiesl4sher's Avatar
Re: Front Tire Size
I have 275 front and rear on 18" rims,roush spec's!!
zombiesl4sher is offline   Reply With Quote
Old 07-30-2011, 04:25 AM   #9
Re: Front Tire Size
Its slowing you down.
Old 07-30-2011, 06:52 AM   #10
Re: Front Tire Size
yeah,makes the steering heavy too,plan to change soon.
Old 07-30-2011, 07:32 AM   #11
poloka's Avatar
True. Hence why I asked the question on here. I'll stick with 255's. Thanks!
Tire Advice WolfLust 2005-2010 V6 Mustang 10 08-01-2011 06:57 AM
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
Pipe size for exhaust zrider07 1996-2004 Mustang GT 1 07-26-2011 12:25 AM
Unusual wear on inside wall of front tires Hm3grant 1996-2004 Mustang GT 18 07-24-2011 09:15 PM
11:10 AM
