2011 Mustang 5.0 #8 Cylinder Problem - Mustang Evolution
Old 08-05-2011, 08:54 PM   #1
LaFlamaBlanca's Avatar
so I finally found forums and posts on this issue and I'm scared to admit that I myself may be experiencing this issue...am I to understand that this will not be covered under the warrantee?
LaFlamaBlanca is offline   Reply With Quote
Old 08-05-2011, 10:12 PM   #2
If your car is unmodded, it would have to be covered.
Old 08-05-2011, 10:14 PM   #3
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Re: #8 cylinder problem
what tell tale signs are you admitting that you might be experiencing right now with your car??
gregtommy is offline   Reply With Quote
Old 08-05-2011, 10:27 PM   #4
definitely modded :/
---------- Post added at 12:27 AM ---------- Previous post was at 12:26 AM ----------
wierd rattling that I thought was my exhaust needing to be torqued but it also stalls when idling sometimes...
Old 08-05-2011, 10:44 PM   #5
gregtommy's Avatar
do you have a random check engine light pop on and off? Try flashing the stock tune back into it and see if it has the same problem of stalling when its idling. Sometimes a tune can be slightly off causing a stalled idle. This happened to me back in the day with a crown victoria police interceptor. Who is your tuner through?
Old 08-06-2011, 03:31 AM   #6
WHat tune do you have. A iffy tune can cause it to stall also. I know my last BBR tune made mine idle horrible, and it would almost die when just sitting there. New tune from some one and it is perfect.
Old 08-06-2011, 08:31 AM   #7
its actual physical damage I think caused by the tune... and excessive rpm's according to what I've been reading
Old 08-06-2011, 09:03 AM   #8
The number 8 issue is a blown engine caused by #8 failing.
How long you had tune in? How long been doing what doing?
Old 08-06-2011, 09:17 AM   #9
Loc: Austin,TX
Where are you hearing the rattling coming from? Does it sound like sputtering?
Old 08-06-2011, 09:58 AM   #10
well the car is still running...just had the wierd noise...i'm sure it will get worse if not checked tho. I've had the car tuned since I got it but its had a few different tunes so that probably hasn't helped. its been doing this for like a month and a half
---------- Post added at 11:58 AM ---------- Previous post was at 11:58 AM ----------
sounds like the engine and its a ticking sound
Old 08-06-2011, 10:29 AM   #11
Loc: Austin,TX
Some of the 2011s have had a "Tick" issue like the Termis had. This could possibly be what you are hearing,doesnt sound like a #8 issue.
Old 08-06-2011, 10:38 AM   #12
its still stalling randomly in neutral tho...
---------- Post added at 12:38 PM ---------- Previous post was at 12:37 PM ----------
i'm gonna go get it checked soon. dont wanna blow the engine...better safe than sorry
Old 08-06-2011, 11:56 AM   #13
Loc: Austin,TX
Stalling will have to do with the tune like said above. Where are you gonna take it to be looked at,Ford? If so,as soon as they see you loaded a aftermarket tune the warranty is done....over.....cashed out.
Old 08-06-2011, 12:00 PM   #14
well the car was working fine with tunes until the day I had it dyno'd. that was the first time it stalled out and has done about 15 times since then...as far as the warrantee, I chose not to pay the extended warrantee since I was going to be modding and tuning so I know there will be no warrantee...oh well
Old 08-06-2011, 12:01 PM   #15
Loc: Austin,TX
What tune do you have in there now?
Old 08-06-2011, 12:02 PM   #16
a Jon Lund 93 street tune
Old 08-06-2011, 12:10 PM   #17
Loc: Austin,TX
Have you contacted them about it?
Old 08-06-2011, 12:11 PM   #18
I doubt JL would do anything for me. I'm pretty sure I wouldn't get my money back
Old 08-06-2011, 12:38 PM   #19
Loc: Austin,TX
He would probably ask you to do so data logging and send it to him. They all do that.
Old 08-06-2011, 12:39 PM   #20
would he fix the tune and resend it?
Old 08-06-2011, 12:45 PM   #21
Loc: Austin,TX
More than likely yes. You need to go to this site.....
WWW.S197FORUM.COM - Powered by vBulletin
It is very informative for us S197 owners. You have to register to view any threads though. Post your tune question issue over there and you will get a ton of response.
Old 08-06-2011, 12:46 PM   #22
I am a member...forgot about that forum til you just reminded me lol. thanks for the advice
Old 08-06-2011, 12:54 PM   #23
Loc: Austin,TX
Dont forget to come back,lol.
Old 08-06-2011, 01:35 PM   #24
I won't...i like this forum too much. and I have the phone app
Old 08-06-2011, 10:18 PM   #25
gregtommy's Avatar
Re: 2011 Mustang 5.0 #8 Cylinder Problem
good luck i am sure it will be a speedy resolution
Old 08-06-2011, 10:28 PM   #26
I hope so
Old 08-07-2011, 06:58 AM   #27
I do think that multiple tunes in these is a issue. But should not blow engine though. I have seen few people mention the ticking., Some said noticed after headers and stuff. So who knows.
Old 08-11-2011, 06:18 PM   #28
dealer will be taking a look at it tuesday....
Old 08-11-2011, 08:42 PM   #29
Msoler's Avatar
Did you contact JL yet? I'm interested to know how that turned out as I also have recently purchased a JL tune. Aren't you worried about the dealer seeing all of the tune's you loaded?
Msoler is offline   Reply With Quote
Old 08-16-2011, 04:36 PM   #30
so I left it at the dealer today...i just picked it up. they said they couldn't find anything wrong with either the engine or tranny. however my after market exhaust is riding on my rear axle/differential. perhaps that was the source of the rattling :/ I can only hope lol. as far as the stalling I am as we speak re-stocking my ecu and then re-flashing with the original 93 tune I had...hopefully that resolves that issue.
Old 08-16-2011, 04:47 PM   #31
Loc: Austin,TX
How many tunes have you had on that car?
Old 08-16-2011, 05:11 PM   #32
more than I should lol. only 3 dif ones but I went back and fourth a couple times.
Old 08-19-2011, 03:02 AM   #33
I'm done with email tunes tho forever. gonna get a pro tune with dyno when I get back from Florida.
Old 08-22-2011, 09:27 AM   #34
The Darkside's Avatar
let me know how that works out, cause thats the route id like to take
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 08-22-2011, 10:46 AM   #35
Why so many different tunes?
2011 mustang
Will a Manual tranny off of a 5.0 Mustang Fit my 1997 Mustang GT (v8)? BrKu789 1996-2004 Mustang GT 1 08-03-2011 04:35 AM
Hellion Powered 2011 5.0L Mustang GT - DRAG STRIP VIDEO JohnnyMustang 2011-2014 Mustang GT 18 08-01-2011 12:29 PM
10:12 AM
