Lowering - Mustang Evolution
Old 08-19-2011, 05:51 PM   #1
gtstyles2's Avatar
Lowering
Just ordered the eibach pro kit with dampers, and also the BMR adjustable polyurethane panhard bar.... Can anyone tell me if I need anything else for a correct drop?? I want to do this right the 1st time, and I don't want to go crazy and replace my whole suspension... Just enough to have a good ride.
---------- Post added at 04:51 PM ---------- Previous post was at 04:50 PM ----------
Do I need a strut mount??
Old 08-19-2011, 08:44 PM   #2
Loc: Austin,TX
Re: Lowering
Some have used the GT500 strut mounts but thats all up to you.
Old 08-19-2011, 09:14 PM   #3
gtstyles2's Avatar
I've heard about them, are they ok to use on eibachs?
Old 08-19-2011, 11:56 PM   #4
Re: Lowering
YOU will most likely need camber plates. To correct the camber in the front.
As far as the strut mounts you will not need them unless you are changing shocks as well. This is what I have seen from most.
Old 08-20-2011, 12:20 AM   #5
secomejia's Avatar
If u want to go the right way get the c/c plates and the isolators!!!!
secomejia is offline   Reply With Quote
Old 08-20-2011, 06:04 AM   #6
gtstyles2's Avatar
I am getting the shocks as well, I'm trying the stage 2 kit eibach pro with dampers.... If I get the CC plates, I won't need camber bolt??
Old 08-20-2011, 01:39 PM   #7
Re: Lowering
If I am trakcing right you will not need the camber bolts with the camber plates. They give enough adjustment.
With the shocks you will want to GT500 strut mounts. Best price I have seen was on AM with the discount. That or Latemodelrestoration.
Old 08-20-2011, 02:18 PM   #8
gtstyles2's Avatar
Ok cool I figured that's what I need, so the GT500 mounts are ok with the eibach struts and springs?
Old 08-20-2011, 03:14 PM   #9
Re: Lowering
Yes. It is the way they they sit. The 5.0 ones are different then the GT500 ones. It is what every one is switching to.
lowering springs secomejia 1996-2004 Mustang GT 2 08-15-2011 10:51 AM
Lowering springs Mineralgreygt 1996-2004 Mustang GT 9 08-07-2011 06:58 PM
Mustang lowering Jesse Bach General Car Discussion 4 08-01-2011 12:09 PM
Lowering a 01 gt with 18" rims??? Mxrider General Mustang Discussion 5 07-16-2011 06:11 PM
I need help installing lowering springs on 94 mustang gt 94 GT 1979-1995 Mustang GT 1 07-12-2011 07:30 AM
02:27 AM
