Brembo pkg - Mustang Evolution
Old 08-22-2011, 09:34 AM   #1
11stangGT's Avatar
Region: Arkansas
Brembo pkg
Ok I have the brembo pkg on my car and want to know if anyone can tell me for sure what exactly it entails? I know obviously front brakes wheels etc... But have heard that it also come with diff rear pads.. Bigger sway bars... Diff break lines.. Etc.. Curious to know what it really has other than just hearsay.. Also plan on installing frpp k-springs and have noticed that people with the brembo pkg have been able to install them w/o the need of gt500 upper strut mounts and dampers as it calls for per American Muscles site... So does the brembo pkg already have these? Basically just want to know the exact specs of the entire pkg...
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 08-22-2011, 09:42 AM   #2
Re: Brembo pkg
From what i knew it was just different brakes, wheels, and lines. Nothing else special. Same sway bars, strut mounts etc.
Old 08-22-2011, 10:09 AM   #3
The Darkside's Avatar
Re: Brembo pkg
from what i know the package also includes 3.73 gears and a better differential.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 08-22-2011, 10:21 AM   #4
11stangGT's Avatar
Region: Arkansas
Forgot to mention that..
---------- Post added at 10:21 AM ---------- Previous post was at 10:15 AM ----------
Then why can I change over to frpp k-springs WITHOUT getting new strut mounts and dampers? It would seem to me that would mean they are diff than the standard gt pkg strut mounts right?
Old 08-22-2011, 10:28 AM   #5
Re: Brembo pkg
[QUOTE=11stangGT;947047]Forgot to mention that..[COLOR="Silver"]
QUOTE]
lol that was the most important part to me lol hahah
i bleed Race fuel!
Old 08-22-2011, 10:48 AM   #6
11stangGT's Avatar
Region: Arkansas
Ya i love the 3.73s!
Old 08-22-2011, 11:05 AM   #7
gtstyles2's Avatar
I'm in the process of dropping as well, I just call CJ Pony Parts and talked to someone and they told me if your car is lowered u need new strut mounts... The GT500 strut mounts are part of the track pack and it's ok to use on aftermarket setups... I just ordered the mounts today
Old 08-22-2011, 11:45 AM   #8
Re: Brembo pkg
The differential is the same. I bought a base model with 3.73's in it. Only one comes with a different diff is the Boss. And its actually the clutches inside that are different.
Old 08-22-2011, 11:50 AM   #9
11stangGT's Avatar
Region: Arkansas
Does anyone know a way to find out FOR SURE.. Not that I don't believe anybody just a lot of hearsay though.. I want some hard facts.. Like if there's anywhere that Ford would have the brembo pkg specd out...
Old 08-22-2011, 11:53 AM   #10
Re: Brembo pkg
Ask the dealer, look at spec sheets,
Old 08-22-2011, 12:23 PM   #11
11stangGT's Avatar
Region: Arkansas
MOST dealers have no clue... Where can I find a spec sheet?
Old 08-22-2011, 01:20 PM   #12
Brett Greene's Avatar
You do need new strut mounts I lowered my car. I used the GT 500. Nice smooth rise actually. Not like my 95
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 08-22-2011, 01:46 PM   #13
11stangGT's Avatar
Region: Arkansas
Not if you have the brembo pkg..
Old 08-22-2011, 01:49 PM   #14
avengnd's Avatar
Re: Brembo pkg
Ford – New Cars, Trucks, SUVs, Hybrids & Crossovers | Ford Vehicles gives the package details, still vague...
about the suspension it just says "aggressive supension tuning"
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 08-22-2011, 01:50 PM   #15
11stangGT's Avatar
Region: Arkansas
Thanks I'll check that out..
Old 08-22-2011, 01:55 PM   #16
Loc: Austin,TX
Re: Brembo pkg
Used stock strut mounts.
Old 08-22-2011, 01:56 PM   #17
11stangGT's Avatar
Region: Arkansas
You don't have brembo do you?
---------- Post added at 01:56 PM ---------- Previous post was at 01:56 PM ----------
Do you have brembo?
Old 08-22-2011, 02:59 PM   #18
Re: Brembo pkg
My car is lowered and do not have new strut mounts. No issues at all with out them. Springs sit just fine.
Old 08-22-2011, 09:41 PM   #19
201150300A's Avatar
Re: Brembo pkg
Besides the Brakes and Wheels, THE BREMBO BRAKE PACKAGE COMES WITH:
Different Springs (131lbs Front / 167lbs Rear)
Different Struts/ Shocks (retuned for spring rates)
Different Sway Bars ( 35mm Front/ 24mm Rear)
Recalibrated Advance Trac, Traction Control, Anti Lock Brakes Settings
Different Strut Bar Brace
GT-500 Rear Lower Control Arms ( Higher Durometer Rubber)
If you have a 3:73 with the Brembo you should have carbon plates in the differential also.
Ford downplayed all the stuff because they wanted people to focus on the BOSS 302.
Also you DO NOT NEED DIFFERENT STRUT MOUNTS just to change springs. That is only needed if you do the STRUTS. That's until shock companies start making 2011 specific struts and shocks.
2011 Mustang GT - 5.0 - Black/Black -300A - Brembo Brake Option (55D) - 6-Speed - 3:73 (457) Under 30K & Fast as Hell! The way a mustang should be! Performance Parts: SCT Tuner, K&N Filter, Grabber Pony Black Cue Ball Shifter, Ford Racing SVT GT500 Axle Back Mufflers. Route 66 Speed Shop 55D Spring Kit http://www.Brembo50.com
201150300A is offline   Reply With Quote
Old 08-22-2011, 11:44 PM   #20
stangaroo's Avatar
Wow... That's a little more than just brakes lol, damn good deal for the price
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual and I still get over 26 mpg
stangaroo is offline   Reply With Quote
Old 08-24-2011, 08:11 AM   #21
Napoleon85's Avatar
Re: Brembo pkg
I wish this thread would have existed before I bought my '11. I could have probably found one with the brembo package!
Old 08-24-2011, 12:55 PM   #22
Re: Brembo pkg
lol thats why i started the boss or 5.0 thread lol everyone on this forum is always such a help in making the righ choice and thank you again for posting those parts.
you have completely flipped my mind and im going to try to get a boss!
i bleed Race fuel!
Brembo package Vs. After market products STONE47 2011-2014 Mustang GT 43 08-08-2011 04:26 PM
Brembo painted wheels 11stangGT 2011-2014 Mustang GT 0 07-15-2011 02:37 AM
11:50 PM
