Need help hooking up.. - Mustang Evolution
Old 08-28-2011, 01:49 AM   #1
11stangGT's Avatar
Region: Arkansas
You may have seen in another thread where I mentioned going to the dragstrip this last Friday night.. And you may have also seen where I BLEW my tires off and really couldn't get in it till 3rd.. SO besides tires, springs, and rear LCAs is there anything else I need to help me get some grip off the line an drop those 60ft times? I've got the brembo pkg with 3.73s and the pirelli p zero summer tires (w 10k on them) .. And also wanting some opinions on the best brands.. Planning on frpp k springs..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 08-28-2011, 01:59 AM   #2
Loc: Austin,TX
Re: Need help hooking up..
Some sticky tires and dont go full throttle into second.
Old 08-28-2011, 02:04 AM   #3
11stangGT's Avatar
Region: Arkansas
I was shifting out at about 5-5500 in first.. Couldn't give it full throttle or there went the tires. Second had to shift at about 6 or third gear shift would break loose again.. I made like 15 passes (too many) lol so I had time to toy w it... 60ft times were AWEFUL lol..
Old 08-28-2011, 04:00 AM   #4
15x10 race stars, 295/55/15's LCA relocation bracket. Was good enough for 1.6 60fts on stock suspension for me. That was with nothing else done to that car as well.
Old 08-28-2011, 09:50 AM   #5
Beav's Avatar
Tires can make a big difference...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 08-28-2011, 01:09 PM   #6
Titus Wadicus
svtlx's Avatar
drop air pressure to 28-25psi
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 08-28-2011, 07:59 PM   #7
11stangGT's Avatar
Region: Arkansas
I'm thinking bout getting a set of 17x10.5s and 315/35s or 18x10s w some 305s... Any suggestions?
Old 08-28-2011, 11:51 PM   #8
11stangGT's Avatar
Region: Arkansas
Also found that i can get some steeda rear LCAs for $180 through my work... I'll be hooking up in no time!
Old 08-29-2011, 12:36 AM   #9
Brett Greene's Avatar
Learn to drive? Hahaha jk. I literally just put MT streets on mine Friday and I can still burn first and a bit second on the street.
I have them on my 95 to and it's my track car on my 60 ft times are ridiculous with this tires ( and a good driver)
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 08-29-2011, 12:49 AM   #10
11stangGT's Avatar
Region: Arkansas
Lol real funny.. I promise I did the best I coulda possibly done.. I was also hot lapping it so I'm sure if I had given it a cool down I coulda gotten in the 12s.. But as I said in my other thread, this was my first trip to the track w a manual car.. So there was definitely a learning period... But I'm a quick learner and did pretty decent after a few passes..
---------- Post added at 01:49 AM ---------- Previous post was at 01:48 AM ----------
What size did you go with?
Old 08-29-2011, 01:01 AM   #11
305s on booth cars. Haven't took my new 5.0 to the track on them though
Old 08-29-2011, 01:10 AM   #12
11stangGT's Avatar
Region: Arkansas
Wheels and size?
Old 08-30-2011, 09:46 PM   #13
11stangGT's Avatar
Region: Arkansas
So if I buy a set of rear wheels and tires for track use only (+1.5 hour drive to track) would it be better to get racestar 15s and 325/50s or would it be just the same as going w a 17 or 18 with 315s or 305s? Or does having the bigger sidewall help with ur traction and transfer of motion more that the 315/35-17s and 305/40-18s? I realize these are all different widths and sidewall heights...
» Members Mustangs
STANG GT
jeno
skully
skully
Add your Mustang
12:38 AM
