373 gear estimate - Mustang Evolution
Old 09-02-2011, 04:03 PM   #1
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
373 gear estimate
So I have decided its time for the 373s to go into my car and I am looking to maintain the warranty in the car which leads me to ford dealers only. The estimate I received from the dealer was 1200 bucks? I have never had an estimate done on gears so is that a middle of the road deal? Or am I getting straight up ripped off?
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 09-02-2011, 04:09 PM   #2
Re: 373 gear estimate
RIPPED OFF!
I bought FRPP 4.10's and had installed and only paid 500 total. I t hen also sold the 3.73's I had stock for $130. They had less then 300 miles on them.
Also why 3.73's? Best gear is really 3.90's from what I have found. I will be going to 3.90's. Out with the 4.10's. Also they will never really know you changed gears.
Old 09-02-2011, 04:11 PM   #3
gregtommy's Avatar
Well as far as I know they will based off the fact u have to get a tune to get it to read out right on the speedo and a tune voids the warrenty
MOTM DEC 2011
Old 09-02-2011, 04:13 PM   #4
True. But if that worried about voiding warranty why mod at all?
1200 is way to much for a gears. I would find another dealer if you really want the dealer to do it.
Old 09-02-2011, 04:14 PM   #5
gregtommy's Avatar
I have heard great things about the 373s and I don't want to go bigger without feeling how it pulls off the line something tells me my lead foot would be going through tires like crazy if I went deeper
MOTM DEC 2011
Old 09-02-2011, 04:19 PM   #6
With 3.73's your 1st will be short. I ripped my 3.73's out and went 4.10's BUt as mentioned I am going to 3.90's now. 3.73's don't let me pass the traps in 4th gear in the rpms I want need.
Also you do have a manual correct?
Old 09-02-2011, 04:22 PM   #7
gregtommy's Avatar
Yeah I do have a manual did u tune urs to get ur speedo reading correctly?
MOTM DEC 2011
Old 09-02-2011, 04:26 PM   #8
Yes...My car is way way from just gears though..
But with gears they should be able to hook up and just go in and change the settings. You really don't even need a full tune. That is all ford is going to do.
Old 09-02-2011, 04:27 PM   #9
gregtommy's Avatar
I will have to ask some local shops if they are capable of doing it
MOTM DEC 2011
Old 09-02-2011, 04:31 PM   #10
I would...WHat else do you plan to do with the car? Do you plan to drag race it? Blower? N/A?
Old 09-02-2011, 06:03 PM   #11
gregtommy's Avatar
Well eventually blow it when it is no longer my daily driver and it's more of a show car. Long story short I made a mistake when I checked the gear ratio myself. I thought they were 355 and the dealer I bought my car from ran the code for my rear axle and I do have 373s. *forum members enter insults here
MOTM DEC 2011
Old 09-02-2011, 07:58 PM   #12
dolfin13's Avatar
373s are the way to go, unless your gonna race all the time then go with the 410s. if u do alot of highway drivin 410s are no good
dolfin13 is offline   Reply With Quote
Old 09-03-2011, 12:34 AM   #13
SO how are 4.10's no good on the highway? I have them and it is just fine. I knwo guys that DD with 4.30's in their 5.0. These are not 5 spd tranny's. That extra gear helps a lot. And for a manual car the 3.90's have shown to be the best for this tranny for drag racing. Combined with a 28" DR or Slick. It keep you in 4th gear and in the upper rpms. 3.73's keep you in 4th gear but lower in the rpms. 4.10's on the other hand have you shifting to 5th.
Now since you already have 3.73's You will not want to move to a diff gear since you want a blower. You most likely will want to go with a 3.55 once you get a blower. Use the Money you was going to spend on gears and get a clutch and flywheel.
Old 09-03-2011, 05:14 AM   #14
Filibuster
No insult ever!...but did you check your gear ratio by jacking up your car and counting drive shaft rotations by any chance!...
XXSTEVEO66 is offline   Reply With Quote
Old 09-03-2011, 05:45 AM   #15
Also I knwo mine came with a sticker on the rear diff that had the gear ratio. HAd a bar code for scanning and everything.
Old 09-03-2011, 07:54 AM   #16
gregtommy's Avatar
Yeah that's exactly how I did it while holding one wheel stopped and a friend turning the other wheel I thought I saw 3 1/2 turns
---------- Post added at 06:54 AM ---------- Previous post was at 06:52 AM ----------
I will look into that my next step is to finish up my front end with the Cali special front valance and a trufiber venom hood
MOTM DEC 2011
Old 09-03-2011, 11:37 AM   #17
Filibuster
I had only figured that because if you think you see that extra half rotation its a 3:55 or was it a 3 1/4 turn now its a 3:73!!...lol...
The only other way to know for sure is by counting the teeth on the ring and pinion...
Old 09-03-2011, 11:45 AM   #18
gregtommy's Avatar
I believe it was 3 1/4 it would have to be because the code on my door shows up in fords system as 373s. Yeah thats one of those times I was too smart for my own good thought I knew something and come to find out i should have just gone to the dealer to begin with
Old 09-04-2011, 07:14 PM   #19
avengnd's Avatar
I did 3:73 on my 04 GT Auto and cost me $575 and that was with the tuner (I got to keep). I hope that it doesn't cost 1200 for gears, I have a 2012 now and want to change the gears out. As far as the warranty I don't understand why people just out right think that it will void the warranty. It only voids the warranty of that part/s that were broke caused by the mod. Just my two cents from experience and working with my Ford dealer. Ask yours. Yes others might disagree. I would also look into a local shop.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 09-04-2011, 07:33 PM   #20
gregtommy's Avatar
Yeah come to find out bud I already have 373s so no worries and I appreciate ur input ford dealers always charge twice as much for maintenance
MOTM DEC 2011
Old 09-04-2011, 07:39 PM   #21
avengnd's Avatar
Sweet...
2014 Shelby GT500
Old 09-04-2011, 07:47 PM   #22
gregtommy's Avatar
Originally Posted by avengnd
Sweet...
What gearing do you have?
MOTM DEC 2011
Old 09-04-2011, 07:48 PM   #23
avengnd's Avatar
Whatever is stock. my 5.0 didn't come with 3:73.
2014 Shelby GT500
Old 09-04-2011, 07:56 PM   #24
gregtommy's Avatar
Be careful 373 is a package available through for ford do u have an auto or manual
MOTM DEC 2011
Old 09-04-2011, 08:15 PM   #25
avengnd's Avatar
MT, yeah I know, I would have gotten it, but they didn't have any 5.0 available with them at the time.
2014 Shelby GT500
Old 09-04-2011, 08:24 PM   #26
gregtommy's Avatar
Damn ok so do u have a 3.55? Or ate u not positive
MOTM DEC 2011
Old 09-04-2011, 08:26 PM   #27
avengnd's Avatar
I'm not positive, but if that is stock then that is what I have. I didn't bother to ask since I wasn't going to get 3.73 with the car. I knew that I would have to get them on my own.
2014 Shelby GT500
Old 09-04-2011, 08:50 PM   #28
gregtommy's Avatar
Tell me the gear code on the inside of your driver side door it will say axle or gear code
MOTM DEC 2011
Old 09-04-2011, 09:07 PM   #29
avengnd's Avatar
GG
---------- Post added at 03:07 AM ---------- Previous post was at 02:58 AM ----------
Originally Posted by avengnd View Post
GG
BB - 3.73 ratio
CC - 2.73 ratio
DD - 3.55 ratio
GG - 3.31 ratio
YY - 3.15 ratio
Sad, they should make the 3.73 standard with the GT.
2014 Shelby GT500
Old 09-04-2011, 09:09 PM   #30
gregtommy's Avatar
You have 331s bud I was told by a wise person if u want to force induct 355s otherwise 373s r the way to go
---------- Post added at 08:09 PM ---------- Previous post was at 08:08 PM ----------
GG
BB - 3.73 ratio
CC - 2.73 ratio
DD - 3.55 ratio
GG - 3.31 ratio
YY - 3.15 ratio
Yeah the should have but there r a lot of guys on here that got it done for a fair price post a thread and guys will come out of the wood work to give u ideas on where to go
MOTM DEC 2011
Old 09-04-2011, 09:32 PM   #31
avengnd's Avatar
Yeah I'll make change soon. Thanks for the help.
2014 Shelby GT500
Old 09-04-2011, 09:43 PM   #32
gregtommy's Avatar
Yeah I am here when I am not stuck at work so feel feel to ask bud
MOTM DEC 2011
Old 09-05-2011, 02:29 AM   #33
GG
BB - 3.73 ratio
CC - 2.73 ratio
DD - 3.55 ratio
GG - 3.31 ratio
YY - 3.15 ratio
If you are going with a blower later. Wait on gears. Most find the 3.73's and steeper to much with the blower. You have that one or two people that don't mind having no 1st gear at all.
Old 09-07-2011, 11:36 AM   #34
The Darkside's Avatar
OMG thats RAPE! yooooooi paid $400 all together lol dont do it brotha
---------- Post added at 01:36 PM ---------- Previous post was at 01:35 PM ----------
Originally Posted by wnt2gofst View Post
RIPPED OFF!
yo you got 4:10s?? how do you like them? i know you drive a manual so i was wondering how shifting is.
does having 4:10s void your warrenty?
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 09-07-2011, 04:19 PM   #35
Originally Posted by Ken Cheema View Post
OMG thats RAPE! yooooooi paid $400 all together lol dont do it brotha[COLOR="Silver"]
Ya 4.10's might just void it. Depends on the dealer. MIne was cool with it. Even a tune/of road x pipe/cold air when tranny went out.
I will say 4th gear is pretty short. I will most likely be going to 3.90's.
« 550 hp | new hood »
What size gear for rear end? BlackBeauty01 1996-2004 Mustang GT 21 09-02-2011 08:00 PM
New gear install prices XXSTEVEO66 1979-1995 Mustang GT 10 09-02-2011 11:59 AM
1996 mustang GT rear end gear change soldierdude28 1996-2004 Mustang GT 6 08-24-2011 03:15 PM
gear help CancerBoi69 Pre-2005 V6 Mustang 5 08-15-2011 05:05 PM
timing gear drive peoblem? C4king 1979-1995 Mustang GT 8 08-09-2011 08:54 PM
03:54 PM
