Changing wheels? - Mustang Evolution
Old 09-02-2011, 08:33 PM   #1
brickcart's Avatar
Changing wheels?
When going from 19" wheels to 18" on 2012 gt how is speedo calibration done?
brickcart is offline   Reply With Quote
Old 09-02-2011, 09:49 PM   #2
Re: Changing wheels?
As long as you keep the tire diameter the same you will need no recalibration.
Tire size calculator
Go to that link and type in your factory tire size and the new tire size you are wanting to go with, then look at the tire diameter and attempt to get as close as possible.
Post up your factory tire size and we'll help you get as close as possible.
Old 09-07-2011, 11:44 AM   #3
The Darkside's Avatar
bro as far as i know you dont have to recalibrate anything when changing wheels and tires. I guess you could if you wanted too but the diff would be so suttle it would make no sense.
but hey i could be wrong.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 09-07-2011, 12:32 PM   #4
Napoleon85's Avatar
You don't HAVE to, but it's a good idea to. I know it will make your Spedo be off, and I suspect that it could make your tcs/esc a bit wonky ...
Old 09-07-2011, 12:41 PM   #5
interesting stuff. thanks
i bleed Race fuel!
Old 09-07-2011, 05:37 PM   #6
... did anyone read my answer above?
---------- Post added at 06:37 PM ---------- Previous post was at 06:33 PM ----------
Factory tire size = 255/40-19
New tire size = 255/45-18
If you go with that new size your tires will be EXACTLY the same size, meaning absolutely no difference in speed, tcs, abs, or any other thing you think might change.
Old 09-07-2011, 08:38 PM   #7
11stangGT's Avatar
Region: Arkansas
When you order the tire just check the specs vs your factory tires... Just make sure that tire diameter is the same or close (prolly won't be exact) or figure it yourself... 255/40-19= width is 255.. The 40 means 40% of the tire width (255).. That gives you how tall your sidewall is which in this case is 102mm... Then multiply by 2 bc there is a sidewall on top and below the tire.. 204mm converted to inches is 8.03 in.. Add to 19 inches and that's your factory tire diameter... 27.03in The latter is slightly more difficult and time consuming lol.. That is assuming your factory size is 255/40-19s.. Different brands and different styles will be slightly off on that bc of diff tread depths, sidewalls, etc.. A 245/45-18= 26.68in.. Your gonna have to be off by more than an inch or two b4 it's gonna noticeably affect your speedo..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 09-07-2011, 11:22 PM   #8
Dam that's complicated lol
i bleed Race fuel!
Old 09-07-2011, 11:29 PM   #9
11stangGT's Avatar
Region: Arkansas
Damn metric system lol... Isn't 33x12.50 or 31x11.50 so much easier?
Old 09-08-2011, 07:24 AM   #10
25.4mm = 1 inch~ FYI and the second tire number is a percent not a size
Old 09-08-2011, 07:34 AM   #11
11stangGT's Avatar
Region: Arkansas
I guess you missed my post lol
2011 mustang 19" wheels with tires gtstyles2 Mustang Parts for Sale and Wanted 3 09-03-2011 11:56 AM
Paint my wheels? 559Danny Pictures and Videos 7 08-28-2011 10:40 PM
Getting my wheels painted! 11stangGT 2011-2014 Mustang GT 45 08-24-2011 09:25 AM
White Wheels on Black New Edge :) Topless04GT 1996-2004 Mustang GT 18 08-10-2011 03:27 PM
Powder coat wheels/ buy new rims STONE47 General Car Discussion 8 08-02-2011 12:55 AM
03:45 PM
