Winter Tire & Wheel ?? - Mustang Evolution
Old 09-04-2011, 07:07 AM   #1
Picking up my 5.0 on Friday. Black on Black, GT Brembo & 3.73. This is my first Mustang, I've always been a Camaro guy but after wrecking my track car (RX8) it's time to get another track capable car. This time I wanted more power and handling so I decided Ford had the Bowtie beat as an all around package.
Now to the purpose of this thread. I live in WI and the 5.0 will be my DD. I had snow tires on the RX8 and it was fine in the snow. So my question is will the GT500 wheels on the link below fit the brembo pack? If so should I go with 245/45R18 or 235/45R18 of the Michelin X-Ice Xi2? I'm sure both tires will fit the 18x9's. Conventional wisdom says narrow is better for snow.
http://www.americanmuscle.com/black-...18x9-9410.html
Kona Blue 2012 GT Premium, Brembo, 3.73, Accessory pkg 5, GT500 Axelbacks, Boss Pod w/ Prosport Gauges, Boss/CS F&R facsia'a, Boss Brake cooling ducts, Boss splitter, Roush side splitters, Saleen Grill & Roush CAI(non tune). More to come
Devildog1679 is offline   Reply With Quote
Old 09-04-2011, 09:29 AM   #2
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Not to be a damper bud but I don't think 18s will clear I mean the 9 depth clears alone by 3/16 of an inch and if the curve of the 18 isn't just right it probably won't clear but don't just take my word for it call am and they can give u some added advice
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 09-04-2011, 10:58 AM   #3
guzie's Avatar
Re: Winter Tire & Wheel ??
You will need 19s with the brembo package. I have the optional 19s but without the brembo package. With the brembos you dont have a choice. I live in Michigan and mine is my daily driver as well. I bought a almost new set of GT500 SVT performance package wheels and tires for the summer. I am going to mount the winter tires on my original 19s that came on the car. The tires you mentioned look good. Check out Hypercoated 2010 GT Premium Wheel 05-12 Mustang (19x8.5) at AmericanMuscle.com - Free Shipping! for another rim option that should fit for your brembos.
guzie is offline   Reply With Quote
Old 09-04-2011, 11:02 AM   #4
gregtommy's Avatar
I don't think those are going to work because they are only 8.5 deep the stock 19s are at least 9 in depth. If you could get away with a set of all season with a 45000 mile warranty would you be interested in those??
Old 09-04-2011, 02:12 PM   #5
Yea, I'll have to ask them. I've read a few in other forums that say the Gt500 wheels fit. If they do what do you think about 235 vs. 245?
Old 09-04-2011, 02:20 PM   #6
gregtommy's Avatar
well when you start making those kind of adjustments I have heard....I stress this is third person advice but when you go up or down from the stock #s you through your speedo out of calibration. So take that with a grain of salt but I was looking to put 275s on mine and when i found that out I decided to stick with the stock tire size which the best i have found is a set of all weathers 325 bucks a piece Michelin apilots with a 45,000 mile warranty
Old 09-04-2011, 03:23 PM   #7
guzie's Avatar
The tire width change is only one factor in the diameter. Diameter is factored in with the aspect ratio of the tire plus the wheel diameter. If you want to go to say a 275 width you need to lower the aspect ratio from say a 45 to a 40 to stay close to original. 235 vs 245 in the same aspect ratio is going to be a little smaller diameter but probably not enough that you would notice. I would stick with the 245 though to get a better contact patch for the power in the car.
Old 09-04-2011, 03:28 PM   #8
gregtommy's Avatar
the more you know.....thanks for the tire lesson
Old 09-06-2011, 05:12 AM   #9
guzie's Avatar
Old 09-06-2011, 07:45 PM   #10
AM just confirmed that the GT500 18x9 will clear Brembos
Old 09-06-2011, 09:58 PM   #11
gregtommy's Avatar
Thanks for the info that's good to know
MOTM DEC 2011
What tire should I go with? poloka General Mustang Discussion 7 09-08-2011 09:19 PM
Wheel spacers opinions gregtommy 2011-2014 Mustang GT 49 09-04-2011 09:11 AM
Wheel size Travis B 1979-1995 Mustang GT 4 08-09-2011 04:46 PM
Duplicolor Wheel paint=-( Project Pony Pre-2005 V6 Mustang 10 08-01-2011 09:01 PM
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
12:29 PM
