09-07-2011, 08:48 PM
#1 | | Registered User
| Ordered a few things today!
I talked my bosses into letting order a few things and just pay a lil at a time( work at an accessory shop).. So I ordered a Steeda CAI and a bbk aftercat xpipe.. Planning on having my muffler guy just weld in the xpipe and remove the cats.. I think I wanna leave the resonators on though.. I have a SF3 sct tuner.. After I cut off my cats can I just turn off the check engine light with my tuner? Also anyone else got the steeda CAI?
__________________ 2011 5.0
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
09-08-2011, 01:59 AM
#2 | | Senior Member
| Re: Ordered a few things today!
The Steeda/JLT/C&L really all make the same power. I have the JLT and two buddies have the Steeda. With same mods we all put within 2-4whp of each other.
You will not be able to shut the O2 sensors off with just a SCT tuner. YOu will need a custome tune. WHo did you get the SCT from? If you ordered it with the STeeda they should do it for you in the tune if you tell them.
One question is if plan on removing cats why not just order a off road x pipe? From Lethal or BBR?
09-08-2011, 07:17 AM
#3 | | Registered User
| Quote: |
Originally Posted by wnt2gofst The Steeda/JLT/C&L really all make the same power. I have the JLT and two buddies have the Steeda. With same mods we all put within 2-4whp of each other.
One question is if plan on removing cats why not just order a off road x pipe? From Lethal or BBR? | Cheaper to order aftercat xpipe and just have my muffler guy weld it in and remover the cats.. I work at an accessory shop so I got it from one of out distributors so there's no custom tuning on it.. Just the preprogrammed options.. And I can get the steeda CAI for 350 and I like the looks of it the best..
09-08-2011, 07:31 AM
#4 | | Registered User
| Re: Ordered a few things today! Quote:
One question is if plan on removing cats why not just order a off road x pipe? From Lethal or BBR? | SCT Performance - More Power! Less Fuel!
The SCT website disagrees with you.
__________________ |
09-08-2011, 07:41 AM
#5 | | Registered User
| Quote: |
09-08-2011, 07:53 AM
#6 | | Registered User
Yes.
09-08-2011, 08:11 AM
#7 | | Senior Member
Originally Posted by Napoleon85 Yes. |
* Adjustable Options vary for each vehcile and are not available on all vehicles
And no they are not disabled or have the option to. If that was the case they would not need to do it in the costume tunes.
He will need a real tune. The SCT tunes have also showed to do nothing as far as power. Same with the FRPP tunes. People have actually loaded the SCT tunes and gained nothing on the dyno and on the track. But some people will believe anything a vendor tells them.
09-08-2011, 08:23 AM
#8 | | Registered User
| Quote: |
He will need a real tune. The SCT tunes have also showed to do nothing as far as power. Same with the FRPP tunes. People have actually loaded the SCT tunes and gained nothing on the dyno and on the track. But some people will believe anything a vendor tells them. | I call bs on that.. I have the preloaded 93 octane tune and can without a doubt feel the power difference.. I took it off the other day bc I had it sold.. Then put it back on and it's night and day..
#9 | | Registered User
Originally Posted by wnt2gofst [B]He will need a real tune. The SCT tunes have also showed to do nothing as far as power. Same with the FRPP tunes. People have actually loaded the SCT tunes and gained nothing on the dyno and on the track. But some people will believe anything a vendor tells them. | That much I agree with you on. I would never use an SCT tune myself, and would never recommend it to anyone. I've never checked what paramters the SCT can adjust on the 2011-12 Mustang GT when not using a custom tune. If I get bored I may flash back to stock just to look, but I don't foresee myself being THAT bored for a while!
09-08-2011, 08:39 AM
#10 | | Blog Manager
Nice!!!
__________________ Layla - December 2010 Mustang of the Month |
09-08-2011, 09:17 AM
#11 | | Senior Member
Originally Posted by 11stangGT I call bs on that.. I have the preloaded 93 octane tune and can without a doubt feel the power difference.. I took it off the other day bc I had it sold.. Then put it back on and it's night and day.. | If you say so. The dyno don't lie. Have seen the back to back testing first hand. Same with some other tunes. Seen tunes compared to tunes. Lethal vs BBR...BBR compared to EVO. And then EVo compared to a dyno tune.
WHat you could be feeling is the increased throttle response. Which still isn't gaining power. Put it on a dyno. Stock tune vs SCT tune. Then when you finally get a real Bama/BBR or who ever you go with tune vs SCT. I got $50 on the SCT losing to the BBr/BAMA/EVO/LETHAL/Livernois. And if it does make more then stock it will not be nothing huge. Unless in the last 3 months they have really changed there tunes up. But I don't see it. If they did some many people would not be opting not to use the SCT tunes.
09-08-2011, 09:50 AM
#12 | | Registered User
I never said it was better or near as good.. They couldn't sell the product if it didn't do something.. I also know the diff between throttle response and power.. It's loses a significant amount of mid-range power if I return to stock.. There IS obviously increased throttle response but as I said I know the diff..
09-08-2011, 09:55 AM
#13 | | Terminator Owner
People have actually loaded the SCT tunes and gained nothing on the dyno and on the track. But some people will believe anything a vendor tells them. | SCT is just the tuner, the tune is by who ever wrote it, it will be identical for any tuner out there. The tunner is just a device for sending the car what to do, the software is whats really important as its what actually tells the car how to act.
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
09-09-2011, 08:34 PM
#14 | | Registered User
| Quote: |
He will need a real tune. The SCT tunes have also showed to do nothing as far as power. Same with the FRPP tunes. People have actually loaded the SCT tunes and gained nothing on the dyno and on the track. But some people will believe anything a vendor tells them. | Check it out...
09-10-2011, 03:21 PM
#15 | | Registered User
Got my x-pipe installed today and had the cats removed.. Used my SCT SF3 to turn off the rear O2 sensors.. No check engine lights.. Good to go!
09-10-2011, 04:49 PM
#16 | | Senior Member
Originally Posted by 11stangGT Got my x-pipe installed today and had the cats removed.. Used my SCT SF3 to turn off the rear O2 sensors.. No check engine lights.. Good to go! | Nice..I was just talking to a couple people last night they said SCT unlocked more options with an update. Also have you looked you shoudl be able to adjust shift points from what they was saying. Even on the auto cars. There was more stuff as well.
09-10-2011, 05:58 PM
#17 | | Registered User
| Quote: |
Originally Posted by wnt2gofst Nice..I was just talking to a couple people last night they said SCT unlocked more options with an update. Also have you looked you shoudl be able to adjust shift points from what they was saying. Even on the auto cars. There was more stuff as well. | Yes there's several diff options... Mine hasn't been updated since january when I got it..
09-10-2011, 06:42 PM
#18 | | Senior Member
Originally Posted by 11stangGT Yes there's several diff options... Mine hasn't been updated since january when I got it.. | Ya..From what I gather SCT is unlocking more and more. Which can be good.
09-10-2011, 09:14 PM
#19 | | Registered User
Put this on last night.. Love the way it sounds
09-11-2011, 12:29 AM
#20 | | Registered User
| Quote: |
Originally Posted by 11stangGT Put this on last night.. Love the way it sounds | Sound must be great but what about the butt dyno? I've seen about 2 or 3 before and after dyno videos on YouTube averaging about 40 peak... One guy picked up 47.
That's a hell of a lot for peak... I'm not sure if that one was with steedas tune or a dyno but all these were the only mod
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual  and I still get over 26 mpg
09-11-2011, 12:43 AM
#21 | | Registered User
| Quote: |
That's a hell of a lot for peak... I'm not sure if that one was with steedas tune or a dyno but all these were the only mod | Feels pretty nice.. Lol.. I also had an xpipe put on today and my cats removed.. Between the two a pretty nice bump.. I'm definitely happy
09-11-2011, 04:09 AM
#22 | | Senior Member
Originally Posted by stangaroo Sound must be great but what about the butt dyno? I've seen about 2 or 3 before and after dyno videos on YouTube averaging about 40 peak... One guy picked up 47.
That's a hell of a lot for peak... I'm not sure if that one was with steedas tune or a dyno but all these were the only mod | Mosyt of that 47hp is from the tune. Also people like to inflate numbers, Take a bone stock car with 87 octane in it. Then tune it with cold air and add 93 octane. Show you the numbers. When in reality they would have gained 10hp with just running 93 octane in it. The 2011 PCM will add and take away timing for the car. If remember right up to 2-3 degree's. This was done so it could run on 87-93 octane. Quote:
Originally Posted by 11stangGT Feels pretty nice.. Lol.. I also had an xpipe put on today and my cats removed.. Between the two a pretty nice bump.. I'm definitely happy | On a dyno I watched the X pipe with no cats gain about 13whp.(my car) very nice gains for such a cheap mod. With those mods. Cold air, tune, and x pipe cats gone I made 414whp on a dyno jet. That was with a BBR canned tune.
Oh I know what the the other changes are, Timing. The update allows the adjustment of timing..
09-14-2011, 04:54 PM
#23 | | Registered User
Well today I ordered some steeda rear LCAs and frpp k-springs... Any tips, tricks, hints, suggestions for me?
09-14-2011, 05:03 PM
#24 | | Senior Member
LCA's are easy...Springs let some one else do it..LOL
The back is easy front is pain just cause you need spring compressor.
09-14-2011, 05:26 PM
#25 | | Registered User
| Quote: |
Originally Posted by wnt2gofst LCA's are easy...Springs let some one else do it..LOL
The back is easy front is pain just cause you need spring compressor. | I do this type of work for a living.. Leveling kits, suspension lifts, literally every accessory or aftermarket part you can think of.. We don't go too far into the engine though.. Not worried about being able to do it lol just wondering if anyone had any helpful hints...
09-14-2011, 06:49 PM
#26 | | Senior Member
Originally Posted by 11stangGT I do this type of work for a living.. Leveling kits, suspension lifts, literally every accessory or aftermarket part you can think of.. We don't go too far into the engine though.. Not worried about being able to do it lol just wondering if anyone had any helpful hints... | aww ok...
There is a install thing I think LRS did. I know there is one some where. I used it..haha ---------- Post added at 07:49 PM ---------- Previous post was at 07:48 PM ---------- 2011 Mustang GT 5.0 Ford Racing Lowering Springs Install - LRS Blog - Read Here Shop Here |
09-14-2011, 07:06 PM
#27 | | Registered User
| Quote: |
09-14-2011, 07:07 PM
#28 | | Senior Member
np!
