With a fast car you need excellent braking - Mustang Evolution
Old 09-20-2011, 07:38 PM   #1
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Got my new drilled and slotted 14 inch rotors for a small upgrade to the brembo package
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 09-21-2011, 12:46 AM   #2
Re: With a fast car you need excellent braking
Nice...I am switching to strange brakes. Lighter less weight...LOL
Old 09-21-2011, 02:00 AM   #3
11stangGT's Avatar
Region: Arkansas
What'd those run? What brand? Etc..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 09-21-2011, 07:53 AM   #4
gregtommy's Avatar
Nice yeah these r 28 pounds a piece but the coloring of the discs comes from TNT ionized zinc helps prevent corrosion and it comes off as u use brakes.
MOTM DEC 2011
Old 09-21-2011, 08:04 AM   #5
Ya the color will look good behind a nice set of open wheels. Specially with the Brembos.
Here is what I am installing later. This set weighs less then only 33.5lbs for both the calipers and rotors....LOL
Strange Engineering B4148WC - Strange Pro Race Steel Front Brake Kits - Overview - SummitRacing.com
Old 09-21-2011, 08:07 AM   #6
stampde's Avatar
and they'll make your wheels lok better , with out rusted rotor hats
got them on my Mach 1 , they make the rims look so much better ,cleaner look
2011 GT Auto
Old 09-21-2011, 08:14 AM   #7
gregtommy's Avatar
Can't remember the site search 2010 brembo thread will pop up. Cost was 200 dollars and it didn't come plastered with a brand name on them so I am not positive
MOTM DEC 2011
Old 09-21-2011, 08:35 AM   #8
Here some for GT not sure if just standard brakes or will fit Brembo brakes also.
2005-2012 Mustang GT Roush Slotted Rear Rotor Kit
Old 09-21-2011, 08:43 AM   #9
gregtommy's Avatar
hey bud here is the link to the site I didn't catch the name when i ordered them and they weren't stamped on the box.
2010-2011 Mustang, GT, GT500 and GT500KR Front Rotors with Brembo Setup
---------- Post added at 07:41 AM ---------- Previous post was at 07:40 AM ----------
those look pretty sexy bud, I didn't see on there but how big are the rotors, if they are 14 inch they should be compatible with the brembo set up
---------- Post added at 07:43 AM ---------- Previous post was at 07:41 AM ----------
yeah for the next couple years i am going to be staying with the stock 19 in brembo wheel set up and those have a fair amount of space between the wheels they also have a thick coat of zinc on them so rusty discs should be a thing of the past
Old 09-21-2011, 09:15 AM   #10
You wouldn't run these with Brembo's. They replace calipers and every thing. They are to drop rolling weight. Help drop weight of car. More rolling weight you can drop the faster the car will be.
This is why people use lighter wheels such as skinnies up front with lighter in the rear as well, aluminum drive shafts, lighter flywheels. Its not all for strength.
Old 09-21-2011, 09:33 AM   #11
deadsp0t's Avatar
Sprung V. Unsprung weight.
The lower you get in overall weight the more important. It's when weight starts to equal horsepower. Very important to a 420lb 150hp 1000cc sportbike.
---------- Post added at 09:33 AM ---------- Previous post was at 09:32 AM ----------
You are also talking rolling resistance when you talk about skinnies up front.
That's unimpressive
Old 09-21-2011, 09:55 AM   #12
Yes indeed.
I have my car down to about 3450lbs with me in it. I am 210lbs. Also what is better from looking at it you would never know it. Everything seems to be there. There is a lot of ways to drop weight and people could never tell.
Plan is to get the car down to about 3300 with me in it. And still have AC-heat and all the other luxuries.
Old 09-21-2011, 10:24 AM   #13
you should do a back to back stop comparison. I am thinking the OEM rotors will stop better unless the new ones are much lighter
Old 09-21-2011, 10:28 AM   #14
deadsp0t's Avatar
In my already light 95GTS I took the seats out pulled the carpet and removed the insulation and sound deadener. Same thing in the trunk. Eventually I removed all the liner in the trunk.
That's unimpressive
Old 09-21-2011, 10:28 AM   #15
Las0mbra's Avatar
But around a track, you'll most likely get a lot less brake fade.
Old 09-21-2011, 10:36 AM   #16
11stangGT's Avatar
Region: Arkansas
Rear rotors should be the same between brembo vs standard shouldn't they?
Old 09-21-2011, 10:39 AM   #17
new brakes dont vent gas like old school back in the day systems did. Look at real track cars, look at what they run, most are flat rotors.
Slotted/drilled are very prone to crack and not hold up under stress if they were not molded but actually cut after made.
they look great, just part of it, not saying they wont work just that they wont be really any change over stock.
Old 09-21-2011, 10:44 AM   #18
Las0mbra's Avatar
Yes indeed.
What kind of weight have you dropped?! That's ridiculous considering these things weigh like 3700lbs
Old 09-21-2011, 10:47 AM   #19
rotating weight is VERY critical, every 1lb you drop of rotating mass (drive shaft, rotors, wheels) is about equal to 10lbs of dead weight thats why two piece rotors are very popular.
one guy on another forum got his 03 cobra coupe from 3670 down to 3100lbs had the fastest (10 second car) 03 cobra with a non ported blower I believe.
Old 09-21-2011, 11:06 AM   #20
Actually a base model doesn't weigh that much. A base model is already under 3530lbs bone stock with less then 1/8 tank of gas. Now a convertible does.
But I have full suspension adds up fast the LCA's was about 2.2 lbs lighter each for example, Che bumper supports front and back total dropped was almost 40lbs, back seat delete, aluminum drive shaft, Weld RT-S rims 15x10/17x4, Full exhaust even dropped weight. My wheels alone was almost 80lbs lighter. Also took out the spare tire and jack. All foam behind bumpers. Lighter flywheel. Front sway bar delete(completely off) and lighter radiator support. Lighter hood. Some other little stuff. I weighed it last time at the track. SAR. I also had the Cat back off when weighed it. If remember right the precise weight was 3486 give or take a lb or two. Not sure where the picture of the scale is I took. This was before drive shaft and flywheel.
This is also with a full tank of gas. My shipping weight was 3456lbs.
http://media.ford.com/images/10031/2...g_GT_Specs.pdf
Old 09-21-2011, 11:58 AM   #21
gregtommy's Avatar
Yeah I will give it a try I will have the back ones changed out then as well wit upgraded 14 in so ur will be interesting to see
---------- Post added at 10:58 AM ---------- Previous post was at 10:55 AM ----------
Yeah as far as I know the rear brakes on brembo packages are the same as the gt
MOTM DEC 2011
97 GT Smelling gas fumes in car Sharky97 1996-2004 Mustang GT 2 09-20-2011 02:54 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Favorite Thing About Your Car Thread bradh2414 General Mustang Discussion 43 07-24-2011 04:55 PM
06:38 AM
