6spd MT question - Mustang Evolution
Old 09-27-2011, 12:20 AM   #1
11stangGT's Avatar
Region: Arkansas
6spd MT question
At work today we had another 5.0 6spd mt stang.. And when I pulled it in I noticed the shift is a lot smoother on his car and I know for a fact it's stock bc i know the guy.. I just pulled it in and sat at idle and ran through all the gears.. Felt a lot smoother through all the gears.. As i've said b4 this is the first manual car that I've actually owned.. So basically is there something wrong w mine? Like synchronizer? Or is this what people are referring to when they are talkin about their transmission being "notchy"? Could I have the trans. Issue that a lot of 5.0s have had? Any help is appreciated!
---------- Post added at 12:20 AM ---------- Previous post was at 12:17 AM ----------
Also really hard to get in reverse when I first start it up in the morning.. And if definitely pushing down on the shifter to disengage the reverse lock out..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 09-27-2011, 04:16 AM   #2
Re: 6spd MT question
You seem you have the "notchy" tranny that people talk about. HAs he changed his fluid in his. And the hard shift in the morning is the fluid as well.
Strano Performance Parts - Part Details
What I run in mine. It works great. Got rid of the codl stuff in teh morning and isn't notchy either. Combined with the Barton Shifter. Also not sure you are tracking but Steeda has a bracket out now also.
Also the have the shifter for 224.
Anyway about the whole kit with Red line MT fluid.
WWW.S197FORUM.COM
Old 09-27-2011, 08:37 AM   #3
jimbullit's Avatar
WWW.S197FORUM.COM
Thanks for the helpful links. I have a plan to get the Barton, and per your good experience-I guess I will also be doing a tranny flush, and put the 'good stuff' back in, at the same time!
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 09-27-2011, 08:47 AM   #4
11stangGT's Avatar
Region: Arkansas
WWW.S197FORUM.COM
No he hasnt changed his fluid.. And yes I did notice that steeda has a bracket out now.. Would it prolly be the exact same thing as the Barton bracket? So prolly change out my fluid and when I get a shifter should take care of it? Think ford would change the fluid under warranty if I complain about it?
Old 09-27-2011, 09:01 AM   #5
avengnd's Avatar
I thought I read somewhere there is a TSB about this? About changing out the fluid.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 09-27-2011, 09:55 AM   #6
11stangGT's Avatar
Region: Arkansas
That's what I was wondering.. I know there's a few tsb's out there..
Old 09-27-2011, 10:10 AM   #7
You would think it would be the same as the Barton one. It is new so I haven't seen no one to say yes or no.
There is a Ford TSB out also. They use a little thicker fluid as well. It is better then what is in it stock but not as good as the red line. YOu take your car to ford and they should change the fluid for you. I am looking for the TSB now. They have a few out for these trannies
---------- Post added at 10:08 AM ---------- Previous post was at 10:01 AM ----------
Ford Issues TSB For 2011-2012 Mustangs
---------- Post added at 10:10 AM ---------- Previous post was at 10:08 AM ----------
has a bunch in this thread of all TSB's
Post 2011 Mustang Technical Service Bulletins (TSBs) here - Ford Mustang Forums
Old 09-27-2011, 10:13 AM   #8
11stangGT's Avatar
Region: Arkansas
Sweet thanks dude.. Lemme know if you hear anything about the steeda bracket..
Old 09-27-2011, 11:16 AM   #9
Will do.
Old 09-27-2011, 02:27 PM   #10
avengnd's Avatar
Awesome, thanks for the links.
2014 Shelby GT500
Old 09-27-2011, 03:42 PM   #11
The Darkside's Avatar
Dude I swear on another thread they posted a royal purple fluid to be used?
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 09-27-2011, 03:54 PM   #12
11stangGT's Avatar
Region: Arkansas
Is this related to the miss that everyone talks about around 2100-2300rpms? Or totally separate issue all together?
Check Engine Question PonyBoyV6 Pre-2005 V6 Mustang 13 09-20-2011 04:35 PM
Rocker arm question? WhiteCobra94 1979-1995 Mustang GT 7 09-12-2011 01:46 PM
Anotger transmission question. Nick_L Classic Mustangs 1 08-24-2011 05:27 AM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 01:29 AM
Aft cat deletion question Mustanglife Pre-2005 V6 Mustang 21 06-27-2011 10:30 AM
06:53 AM
