Change Transmission Fluid - Mustang Evolution
Old 09-29-2011, 11:58 AM   #1
Hello all, new owner of 2012 Mustang GT Coupe here. I have not yet been under the car but am wondering about how difficult changing the transmission fluid is. Any help is appreciated.
Thanks
Tom
pcarman is offline   Reply With Quote
Old 09-29-2011, 12:05 PM   #2
Re: Change Transmission Fluid
if its a manual trans there will be a drain plug(s) and a fill plug(s). You take out the fill plug then the drain plug. After its drained you put the drain plug back in and use a fluid pump to put fluid back into the trans to the specified level/amount. Thats about it.
For auto it will be more intensive.
Old 09-29-2011, 12:23 PM   #3
Thanks. I should have stated it is a manual trans. Are both plugs on the side of the trans and easy to get to?
Tom
Old 09-29-2011, 01:20 PM   #4
gtstyles2's Avatar
Thanks
Tom
What's the reason for changing the trans fluid so early??
Old 09-29-2011, 01:58 PM   #5
I'm having the 1 - 2 shift issue. Not sure I trust the dealer to do the TSB prescribed work properly. Perhaps I am being foolish. First time with a Ford.
Old 09-29-2011, 01:58 PM   #6
Ravnus's Avatar
I would just go to the dealer and tell them the tranny is notchy when it's cold and they will change the fluid for you. I believe they swap the fluid for a lighter grade
Ravnus is offline   Reply With Quote
Old 09-29-2011, 02:16 PM   #7
I am right there with you, I probably wouldnt trust Ford either lol....
I have never done it on a newer one, but on mine its basically what I said above. Get under the car and take a look, they are probably both on one side. The pump you will need is generally like 10 bucks at an auto store~ its a pain to load it and pump it in the trans but you have no other method really~
Of course use jack stands and all that to be safe.
Old 09-29-2011, 02:18 PM   #8
KATO's Avatar
I agree with "Ravnus".
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R.
Old 09-29-2011, 07:07 PM   #9
gtstyles2's Avatar
Yea same here, I understand u don't wanna take it to the idiots at ford but at the same time, if your "new" car is doing something like that, there's a serious problem... Fixing it on your own is probably not gonna help cuz they will know u tampered with it and then your liable which voids warranty.... I'm sure u kno Ur stuff with cars but u gotta kno when to swallow your pride
Old 09-30-2011, 09:29 AM   #10
Thanks for your responses. I have decided to go to the dealer.
Old 09-30-2011, 09:35 AM   #11
KATO's Avatar
Good choice.
Old 10-01-2011, 01:27 PM   #12
11stangGT's Avatar
Region: Arkansas
Takin mine in on Tuesday to get my fluid changed..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 10:52 PM
Best Transmission Fluid Stang23 2005-2010 Mustang GT 0 08-07-2011 01:48 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 01:52 PM
Rear axle fluid Holdempoker102 2005-2010 V6 Mustang 8 07-14-2011 08:56 PM
What Brake Fluid do you use? 99ford General Mustang Discussion 1 06-27-2011 10:34 AM
11:56 PM
