Adjustable panhard bar - Mustang Evolution
Old 10-02-2011, 09:25 AM   #1
gtstyles2's Avatar
Have the BMR adjustable panhard bar and I was curious if I have to raise the rear off the ground to adjust?? I have the drive up ramps which are really easy to use, that's how I did my axlebacks... If so what size wrenches can I use??
Old 10-02-2011, 11:43 AM   #2
Re: Adjustable panhard bar
Jack the back off the ground. Then adjust it. If remember right it is 5/8 bolts. Its been while since i did mine. But once adjust sit down and measure each side make sure even. If not then jack back up and adjust again. While it is up you will be able to measure and get it close. Once sit down you will know better cause the suspension will settle. Also Take the car for a around the block to make sure the suspension is settled and perfect. Make your last measurements to make sure even on each side.
Old 10-02-2011, 12:09 PM   #3
gtstyles2's Avatar
Ok, so the weight of the vehicle on ramps wouldn't work? Wheels have to be off the ground?
Old 10-02-2011, 12:37 PM   #4
Yes that way it lets it adjust freely. No weight on it. Will be easier to turn etc.
Old 10-08-2011, 12:41 PM   #5
gtstyles2's Avatar
Thanks I finally adjusted it, now I'm wondering what's the right way and what to use to grease the ends
Old 10-08-2011, 02:12 PM   #6
What mean right way? And go to local parts store. They should carry the grease you need.
Old 10-08-2011, 03:31 PM   #7
gtstyles2's Avatar
I meant I need to get a grease gun right? I haven't delt with a car with grease fittings since I worked for jiffy lube 12 years ago lol... Do they sell small grease guns in auto parts stores, what type of grease should I get?
Old 10-08-2011, 04:05 PM   #8
Yes a grease gun. They should sell at them.
grease here you go.
2010 - 2012 Chevy Camaro | Grease | SUL41150 - Superlube 14 Oz. Grease Cartridge | BMR Suspension - The Leader in High Performance Suspension & Chassis
g-trac bar jwhayne0001 1979-1995 Mustang GT 0 08-31-2011 07:51 PM
Panhard Bar Adjustments JonChambers03 2005-2010 Mustang GT 6 07-29-2011 01:59 PM
Adjustment of panhard bar poloka 2011-2014 Mustang GT 9 07-17-2011 01:29 PM
saleen roll bar install..... rinfield2004 Mustang Paint, Appearance & Detailing 5 07-13-2011 02:28 PM
Panhard Bar and Rod Support Suggestions poloka 2011-2014 Mustang GT 22 07-02-2011 07:56 PM
07:19 AM
