6 spd. transmission in Mustang GT made in China - Mustang Evolution
Old 10-07-2011, 10:24 PM   #1
Mercedez L.'s Avatar
Question 6 spd. transmission in Mustang GT made in China
Have they addressed the problem with this transmission yet? Or will switching to a synthetic transmission fluid like Amsoil or Redline solve the problem
ID:	32637   Click image for larger version
ID:	32639   Click image for larger version
Mercedez L. is offline   Reply With Quote
Old 10-07-2011, 11:08 PM   #2
Loc: Austin,TX
Re: 6 spd. transmission in Mustang GT made in China
Nothing solid yet. There are tons of threads all over the web about this but not a solid solution as of yet.
Old 10-08-2011, 12:40 AM   #3
Question Re: 6 spd. transmission in Mustang GT made in China
is it better at this time to get the automatic transmission? Is it a 6 spd auto? What are the differences betweent the manual and auto in power.
Old 10-08-2011, 01:27 AM   #4
93slowstang's Avatar
So far it seems the auto is more reliable out of the two. The auto is a six speed as well.
Old 10-08-2011, 02:26 AM   #5
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
its not really happening all that often in either transmission though, only a few people have had problems and a lot of people that feel slight notchiness in the shifting resolve it through replacement of the shifter with a short shifter and a new bracket.
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 10-08-2011, 06:17 AM   #6
12GTstangCS's Avatar
The TSB for it says to switch from the full synthetic to a dual clutch transmission fluid. I've had the shifting problem only when the engine hasn't warmed up. Anyone switched fluids yet and noticed a difference?
http://mustangsdaily.com/blog/wp-con...b-11-03-18.pdf
12GTstangCS is offline   Reply With Quote
Old 10-08-2011, 06:47 AM   #7
Napoleon85's Avatar
Im planning to have my transmission flushed and filled with Royal Purple sometime in the near future. I haven't noticed many problems other than occasional problems hitting 5th from 4th.
Old 10-08-2011, 09:07 AM   #8
No problems here, but with WI winter soon approaching, that may change
Kona Blue 2012 GT Premium, Brembo, 3.73, Accessory pkg 5, GT500 Axelbacks, Boss Pod w/ Prosport Gauges, Boss/CS F&R facsia'a, Boss Brake cooling ducts, Boss splitter, Roush side splitters, Saleen Grill & Roush CAI(non tune). More to come
Devildog1679 is offline   Reply With Quote
Old 10-08-2011, 02:15 PM   #9
First tranny went out.
New tranny has been perfect. Running Redline fluid in it. Also have Barton short throw with bracket.
The auto is way stronger. Guys have been in the 9's with stock autos. They are also holding more power. Remember the stock tranny is only rated at 383wtq.
There is also another solution if you want to keep a manual but want big power.
Ford 2011 Mustang Gt Transmission Swap Tremec T56 Magnum Photo 1
Old 10-08-2011, 05:51 PM   #10
Benzo's Avatar
Surprisingly no problems with my 6SMT maybe slightly notchy in 1st and 2nd but nothing really worth mentioning. Do u thing full bolt on and nitrous kit spraying 100 shot is putting to much stress on the manual tranny?
---------- Post added at 11:51 PM ---------- Previous post was at 11:50 PM ----------
And also what do u think is better redline trans fluids or royal purple trans fluids?
Benzo is offline   Reply With Quote
Old 10-08-2011, 06:07 PM   #11
Do a clutch you will be fine. Either is really good with the oils.
Old 10-12-2011, 07:56 AM   #12
jimbullit's Avatar
It must be remembered, that those 'planning on making big power', 'heading to the dragstrip', would want to contemplate the tranny switch switch. (The Tremec looks bada$$!) I have had little difficulty with my Getrag 6speed. If you do favor a manual transmission, the fact that the AT, 'is making better power'/'holding together, better', is pretty much, a moot point..if you are not upgrading/racing-IMHO.
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 10-12-2011, 08:12 AM   #13
i dont know why they didnt just start using the T-56 and perhaps beefed it up a bit more
Old 10-12-2011, 08:15 AM   #14
T-56 magnum ftw.
Old 10-12-2011, 08:44 AM   #15
Sean Kelley just went 9.2@151 with his stock suspension stock tranny 2012 Auto 5.0. He has trapped the highest out any mustang 5.0 yet. He also plans on being the fastest next weekend. Made a few tweaks and will shooting for an 8 sec pass to beat Evolutions 5.0 that went 8's. He has threads on S197 and Modularfords where he called out JPC/BBR/Evo to run next weekend at Ford Fever.
On that Note BBR claims the highest HP 5.0 in the country. 953whp with a built block and turbo in a manual car. Yet they have no track passes on it. It broke a drive shaft before the could run it. It has also been said that Sean Kelley makes over 1000whp now and Evolution made over 1000whp with there 8 sec car.
Old 10-12-2011, 02:53 PM   #16
Benzo's Avatar
That's effin sweet!
Old 10-12-2011, 05:12 PM   #17
Loc: Austin,TX
Is Sean the one with the white 5.0?
Old 10-12-2011, 06:02 PM   #18
Nope. Sean used to have a Kona blue. Now he has a Grabber blue 2012. You are thinking his runs high 9's and his was built by Evolution. I think his name is Chris if remember right.
---------- Post added at 07:02 PM ---------- Previous post was at 07:00 PM ----------
His old car. His new one is faster. LOL
Old 10-22-2011, 05:17 PM   #19
I had the dual clutch fluid put in a couple days ago and it seems to have improved shifting. Not perfect but noticeably better.
Sfalkin is offline   Reply With Quote
Old 12-01-2011, 10:16 AM   #20
back n a stang's Avatar
Anybody that has done this......What weight did you use-75w-90 ?? How much does it take to fill it back up after draining it ??
Old 12-01-2011, 10:42 AM   #21
Napoleon85's Avatar
Whoa, this thread is ALIIIIIIVE again.
I'll be doing the fluid change myself this winter, I believe it's something to the tune of 2.7 or 2.8 quarts. Once I get it done, I'll report back, but I won't have any driving impressions until things thaw out...
Old 01-11-2012, 07:22 PM   #22
FXDWG11bm's Avatar
Did you get it changed over? I do notice a difference when its cold vs warm. Ordered the Barton braket today, sounds like it will help with the slop........
FXDWG11bm is offline   Reply With Quote
Old 01-11-2012, 07:27 PM   #23
Could have got you one for 200
Old 01-11-2012, 07:34 PM   #24
FXDWG11bm's Avatar
Just doing the bracket for now, 2 bills would have been a great deal though!
Old 01-11-2012, 08:49 PM   #25
Napoleon85's Avatar
Not yet. Been busy
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
02:59 AM
