285/35/19 on 2012 brembo wheels - Mustang Evolution
Old 10-12-2011, 05:16 PM   #1
back n a stang's Avatar
Has anybody put a 285/35/19 on one of the 9'' brembo wheels.I know it needs to be 9.5 or 10'' really but wondering if it has been done and what there exp. was/is? Probably not but figured I would ask. Thanks.....
Old 10-12-2011, 05:57 PM   #2
Re: 285/35/19 on 2012 brembo wheels
As you know I replied on GRRRR8 with pics now..To a alternative route for rims..Same look.
Old 10-12-2011, 06:09 PM   #3
Yea but I want immediate results...LOL! That would be my tires on these wheels I got by Friday!LOL! But not if it's gonna give trouble in any way or wear problem
Old 10-12-2011, 06:26 PM   #4
They may wear a little off. As they will hang over a little. But it really shouldn't be to much of an issue.
If I can fit a 275 on an 8" rim no issue I know these will fit no issue.
Old 10-12-2011, 07:13 PM   #5
deadsp0t's Avatar
275 on an 8" wheel is fine for going straight, it IS trouble on a tight curvy road as the side wall deflection causes the rear to at least give the sensation of sliding out which WILL lead to survival reactions which almost always lead to trouble. Hence the reason 275 is not recommended for an 8" wheel. It barely wedges on and is best left for wheels designed hold a 275, like a 9" rim. If you haven't experienced this issue then your either not a corner rat or your not paying attention.. Use at your own risk.
That's unimpressive
Old 10-12-2011, 07:41 PM   #6
I drove the car from Ohio to TX at speeds set at 80-100mph no issue. I also put over 2000 miles on them while in FT KNox KY for ALC. This was on the G8 also. Also they was low profile. 275/30. Almost no side wall. Plus the was Dunlop Z101's which run a little narrow compared to say a Nitto 275/30.
But I wasn't taking 90 degree turns trying to power slide around them either.
Old 10-12-2011, 08:45 PM   #7
pugboy's Avatar
Lightbulb Re: 285/35/19 on 2012 brembo wheels
Hi. I have the Brembo package, and my factory 8 inch wheels are 255/40 19 P Zeros. 285s are definitely too wide. Check out this package from American Muscle, as an example. Their fitment is always dead on, and they use 245/45 19s on 8.5 inch wheels:
Chrome Bullitt Wheel & Pirelli Tire Kit - 19x8.5 (10-12) at AmericanMuscle.com - Free Shipping!
Check out this FAQ as well:
2011-2012 Wheels FAQ Answer at AmericanMuscle.com - Free Shipping!
I went with 18 x 10 - 275/40 rear and 18 x 9 - 255/45 front, and they are great.
Inferno - 2011 GT Premium, Manual, Candy Apple Red, Brembo's, ROUSH Supercharger, built 5.0L Coyote all Manley forged
My Racing Blog
http://spencer-taylor.com/racing_blog.html
pugboy is offline   Reply With Quote
Old 10-12-2011, 09:45 PM   #8
Loc: Austin,TX
245.......to skinny.
Old 10-12-2011, 10:24 PM   #9
pugboy's Avatar
It sounds like it at first, but think about the math. It's a 245/45 19 - since the ratio is higher, e.g. 45, then the tire width is also wider. The reason for the 45 ratio is to maintain factory overall diameter for the speedometer. Otherwise, you have to use a tuner to adjust for revs per mile.
My Racing Blog
Old 10-12-2011, 10:34 PM   #10
deadsp0t's Avatar
+1
---------- Post added at 12:34 AM ---------- Previous post was at 12:33 AM ----------
+1
That's unimpressive
Old 10-13-2011, 12:01 AM   #11
11stangGT's Avatar
Region: Arkansas
Wrong.. 245=width.. 45=45% of width(245) which is sidewall height.. I have the brembo wheels and just to give an example.. my 255/40-19s would be comparable in height to a 275/35.. Actually slightly smaller if I remember the specs correctly.. And obviously 20mm wider.. Your gonna have to have a pretty big change in overall tire diameter for it to really effect your speedo.. More than an inch
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 10-13-2011, 05:48 AM   #12
They must have made some changes on the brembo wheel.You say your are 8''?Mine are for sure 9".Just odd.These were the OEM 2012 brembo wheel and they are 9"
Old 10-13-2011, 06:17 AM   #13
They have different sets of rims that come on the Brembo's.
These are all the wheels you can get on the 2011+ mustang All some one had to do is pay for the upgraded rims.
http://media.ford.com/images/10031/2...g_GT_Specs.pdf
TIRE AND WHEELS (TYPE, SIZE)
Standard P235/50ZR18 A/S Pirelli PZero Nero
18 x 8.0-inch wide spoke painted aluminum wheels
Standard aluminum wheel mini-spare
Optional P235/50ZR18 A/S Pirelli PZero Nero with:
18 x 8.0-inch premium painted aluminum wheels
P245/45ZR19 A/S Pirelli PZero Nero with:
19 x 8.5-inch machined face with painted spoke aluminum wheels
18 x 8.0-inch sterling gray metallic painted aluminum wheels (MCA Edition)
19 x 8.5-inch machined face with argent painted aluminum wheels (GT/CS)
255/40R19 Pirelli PZero Summer-Only (Coupe)
P255/40ZR19 Goodyear F1 Supercar (Convertible) with:
19 x 9.0-inch dark-stainless premium painted aluminum wheels
(Brembo Brake Package)
---------- Post added at 07:17 AM ---------- Previous post was at 07:05 AM ----------
I have a 295 on a 10" rear. And it really is perfect. Fronts are 255 on a 9".
Old 10-13-2011, 06:35 AM   #14
Cool.......Thats what I have.The 9's....I'll do something next week on a day off.
Old 10-13-2011, 03:04 PM   #15
pugboy's Avatar
Hi. 19 x 8 machined nickel, 255/40 19 Pirelli P Zeros are stock with the Brembo package for the GT Premium 2011 and 2012. I am not sure about the California Special. That may be different. Also, if you ordered your Mustang, you can select wider wheels from the factory. Occasionally, the dealer may option different wheels for sales.
---------- Post added at 05:04 PM ---------- Previous post was at 05:01 PM ----------
Ooops, I didn't see your post before mine.
My Racing Blog
Old 10-13-2011, 04:15 PM   #16
Ravnus's Avatar
If u have the Brembo Wheels they are definitely 19x9 all the way around. The Boss has 19x9.5 in the rear and they sport 285/35/19 Pirellis in the rear. The half inch probably won't make a difference. I would still get the 285's. That's the tire I'm getting.
Ravnus is offline   Reply With Quote
Old 10-13-2011, 05:50 PM   #17
You doing 285/35 on the 9'' brembo too? I already got the tires.245/40 front but I know thats no problem.I post pics when I get them mounted.
Old 10-13-2011, 05:59 PM   #18
Ravnus's Avatar
How come you didn't stick with the 255/40/19 for the front? Just curious
Old 10-13-2011, 06:06 PM   #19
He has Hankook's for the rear and front. WHy mix match tires?
Old 10-13-2011, 06:18 PM   #20
pugboy's Avatar
Excellent point.
A bit off-topic, but I prefer asymmetrical tires. It really depends on what you are doing with your car.
My Racing Blog
Old 10-13-2011, 06:34 PM   #21
Excellent point.
Got all fancy on every one...LOL
Could have said I prefer more of a performance tire to a all season or non performance tire...LOL
Old 10-13-2011, 06:51 PM   #22
pugboy's Avatar
This is what happens when you become track obsessed
My Racing Blog
Old 10-13-2011, 07:18 PM   #23
Actually the hankook v12 is not a bad tire.Check reviews.Not saying they are great but a good tire for the mileage you get.Decent performance
---------- Post added at 09:18 PM ---------- Previous post was at 09:12 PM ----------
Yea Brad you are right.I got all 4 of these tires and really just broke in.Just bought them in last 90 days and might have 1000-1200 miles.So they are prime meat in my opinion.Just got to take the time and go do this.Kinda like to find a great shape brembo for a spare first.If so I will buy after market wheels later.Like next year.This way I can do my 3 planned mods.Like this year.Like NOW! LOL!
Old 10-14-2011, 02:08 PM   #24
Just seems like with all these new stangs with Brembo wheels that somebody else has done this.I am sure there are guys who have but not read this post.I will be the first I guess.
Old 10-14-2011, 02:43 PM   #25
pugboy's Avatar
A lot have done this, plus the GT500 has the same front calipers and discs, and wheel sizes.
They have different sets of rims that come on the Brembo's. Thousands of Mustang owners have upgraded their wheels with no problems. And my GT Premium w/ the Brembo package had 19 x 8 inch wheels with Pirelli PZero Summer-only (not all-season Nero's) 255/40/19's. I upgraded to 2010 Black GT500 18 x 9 front and 18 x 10 rear wheels and they work perfectly with my Brembos. That's why I stick to a company like American Muscle that actually tests the fitments that work.
Ford's spec chart was nicely provided by wnt2gofst. It tells you what works on Ford wheels - not aftermarket. Different designs have backspacing issues and other problems. Just because a wheel is 9 inch or 10 inch doesn't mean that it will fit a Mustang.
My Racing Blog
Old 10-14-2011, 03:05 PM   #26
I get all that and understand all the changes one can do.It all has to do with offsets & etc. I know 1000's have made changes and I am not talking about that.I am simply asking has "anyone put a 285/35/19 on the OEM 19 by 9 Brembo wheel" on the back of there 2011 or 2012 mustang.Reason I ask is 285 is in fact a little wide for the 9'' width of the wheel but can be put on.Just wanting to see if anybody has exp. with this exact thing and logged miles and what results they got.
Old 10-14-2011, 03:55 PM   #27
pugboy's Avatar
As far as 285/35/19 on a 9 inch wheel, no that would not be a good idea. The tire is not designed for that. 285/35/19 may work on 9.5 inch, but a 10 inch is the correct wheel width to maintain the factory diameter.
I am not saying that it's impossible. I am sure your can "do" it, but you would be seriously pushing the luck envelope.
My Racing Blog
Old 10-14-2011, 05:25 PM   #28
I really don't think it be that bad. As the tire does not have a lot of side wall you will not have a lot to bulge out. Not a lot of roll etc. Now I wouldn't go take it and take it autoX by no means. But for daily driving. I mean if they can do this and DD and drift you will be fine.
Tire stretching. DRifters, and other cars do it even for DD. Even some cars that have 600whp. Real big with VW/G35/37's/350-370Z's
Old 10-14-2011, 06:49 PM   #29
I know you are right Brad.....Pugboy has a point to.I am on the fence.I been half the afternoon looking at the sve silver.I like!They only come 9.5 which is fine but kinda wish they had 8 or 8.5 for the front.So now I am onto the 2010gt 500 wheels because they are 10'' and 8.5 and that would be perfect for what I got now plus for future.I could go 295 easy in the future on the 10''.Like the black but like the chrome after looking at customers pics of both on black 5.0's. Overall the sve is sharper and great price.I am just thinking tonight.
Old 10-14-2011, 07:17 PM   #30
pugboy's Avatar
For whatever it's worth, American Muscle, amongst others - not to plug - has staggered 10 inch / 9 inch sets that are reasonable and will definitely work. Your total cost may be better, depending on your situation:
2011-2012 Ford Mustang Wheels & Rims at AmericanMuscle.com - Free Shipping!
If you decide to get a set, I would highly recommend going with 18 inch, not 19 inch wheels. You will notice a substantial improvement in ride quality over 19's. You can see my Black GT500 wheels on my garage pic to get an idea of what it will look like. They are 18's.
My Racing Blog
Old 10-14-2011, 07:36 PM   #31
I have 19" black GT500 wheels. 18x8.5 and 19x10 bought from AM. Simply cause they was cheap.
19's fill the wheel gaps better. As far as ride quality I think they are about the same. You don't have to go with a 275/35 you can move bigger still with a 19. I am running a 285/40. Before when I had 18x10's in the rear I had a 295/40. Once these tires that was super cheap are gone i will maybe get a 305. But I really don't see the point spending a lot on street tires. I ride on my Weld RT-S most the time anyway. With big *** MT ET Street Drag Radials out back.
Old 10-14-2011, 08:04 PM   #32
pugboy's Avatar
True, the 19's look nice. I like the factory wheels a lot. I use 18's primarily for the track. Next season I will use slicks, but I like to be able to drive to the track - it's only an hour from me, I'm super lucky. All the Ford teams have recommended sticking with 18's for racing. Granted, if I was not racing, I would probably put some blacked out 20's on her Obviously, for racing 18's offer a larger contact patch area than 19's. I'm still thinking what size I may use for Mickeys or Hosiers.
My Racing Blog
Old 10-14-2011, 08:35 PM   #33
I drive mine to the track. 17x4 fronts and 15x10's in the rear. Hell I have put 3000 miles on my car rinning bigs/skinnies 24/7. Instestate/highway/backroads/city. All the same. I just decided to save my DR's some. Plus I will switch to a full slick soon.
The 19's and street tires was mainly for shows and normal driving threw the week. As said DR's wear out really fast.
Old 10-14-2011, 09:34 PM   #34
pugboy's Avatar
I hear that! That's why I have not been in a rush to go to slicks. I just started to get serious about racing this year - joined a track, a lot of learning, getting the car to spec, etc. I am surprised by how well my Nitto's hold up. I used the Pirelli's before. The 555's are better.
I have never done an official 1/4 mile, but I should give it a go after she is out of the shop. The one thing I am learning from road racing is throttle control, but it is really hard to get a good launch with street tires and 3.73's. My best 0-60, with no accounting for 60-foot times, is 4.43 using my 3-axis accelerometer. That is before the Roush and many improvements that are being done. I can't find a place large enough to practice full 1/4's and not get arrested
Using said accelerometer, my friend pulled a 3.07 sec 0-60 with his GT-R running street radials, including my weight too and no roll out! That is insane.
My Racing Blog
Old 10-14-2011, 10:13 PM   #35
Have to remember he is AWD that helps a lot on a unprepared surface for launching a car on street tires or DR/Slicks.
At the track I have cut better 60ft's then GTR's. Most them I see are 1.6's while I am 1.5's. So I am happy. LOL
19" Brembo Wheels, What are they worth? Kystang615 2011-2014 Mustang GT 34 11-19-2011 11:32 PM
Lowering the 2012 5.0 Brembo Brake Package avengnd 2011-2014 Mustang GT 33 10-28-2011 07:47 PM
2012 Wheels and Tires Forsale avengnd Mustang Parts for Sale and Wanted 1 09-25-2011 08:55 AM
2012 5.0 Brembo Wheels and Tires Up For Sale avengnd Mustang Parts for Sale and Wanted 5 09-11-2011 01:45 PM
Brembo painted wheels 11stangGT 2011-2014 Mustang GT 0 07-15-2011 01:37 AM
12:07 PM
