Exhaust leak question - Mustang Evolution
Old 10-15-2011, 09:19 PM   #1
drivinglesson's Avatar
So I finally installed the Heart Throb cat-to-axel 3" system, and I have a weird sound. I am assuming it is an exhaust leak, but can’t find where it is coming from. Does anyone have any advice on finding leaks? There were two of us installing it, and we had the car on a lift, so we took our time and made sure everything was positioned right. Started it on the lift and felt for leaks, but all seemed ok. This morning I drove her around to get the exhaust hot, and then tightened all the clamps. When I first start the car, it just sounds weird. If I give it a little gas, the sound goes away. It's not the typical ticking noise, but I just can't describe it. I am thinking of going to a local exhaust shop and having them fab up some axel-backs, but that will have to wait a couple of weeks. Anyone here have any ideas?
2016 Mustang GT
drivinglesson is offline   Reply With Quote
Old 10-15-2011, 10:42 PM   #2
Loc: Austin,TX
Re: Exhaust leak question
Strange......cant feel exhaust anywhere? Did you loosen the midpipe when you did the install?
Old 10-16-2011, 05:15 AM   #3
Changed it out too
2016 Mustang GT
Old 10-16-2011, 05:56 AM   #4
deadsp0t's Avatar
Maybe it's just the muffler.. Don't know that I get all new stuff..
That's unimpressive
Old 10-16-2011, 06:11 AM   #5
It's possible it is just a different sound Diego the resonators being removed, but it doesn't quite sound right. Maybe it's something inside the pipes and rattling.
2016 Mustang GT
Old 10-16-2011, 07:45 AM   #6
Drive it look for black marks on the exhaust. This will tell you if it is leaking. They will obviously be around the clamps and joints.
Old 10-16-2011, 07:49 AM   #7
Of course, great idea
2016 Mustang GT
Old 10-16-2011, 08:05 AM   #8
It's not me, it's you.
primer2tone's Avatar
Also, you can create some back pressure by restricting the exhaust flow at the tail pipe(s). Someone hold a rag over the exhaust tips and then the other guy then feel around for a leak. I had the same problem with a 4 banger. Crappy pacesetter header...
Old 10-16-2011, 08:07 AM   #9
deadsp0t's Avatar
That's unimpressive
Old 10-16-2011, 08:11 AM   #10
Great idea
2016 Mustang GT
Old 10-16-2011, 06:47 PM   #11
I did all the above and found the leak. It's where the H-pipe connects at the cats. I played with it for an hour or so, but no luck. I think it's an issue with the clamps. When I tighten them, they pinch the pipe where the two halves of the clamp come together. This is where the leak is. I went as far as to replace both clamps with the stock ones, and loosened the aft mid-pipe connections so I could properly align the connection; no luck. I think I will stop by the exhaust shop this week and see if they can work some magic. Before I do this, anyone have any solutions?
2016 Mustang GT
Old 10-16-2011, 11:16 PM   #12
If you are talking right place. Or I am thinking right place. YOu are talking where they slide up and clamp? If so make sure they are all way forward. And then tighten them. I knwo some others had same issues. Just had to tweak it just right.
Also Worse case is have exhaust shop it with a weld. Like a spot weld.
Old 10-17-2011, 08:50 AM   #13
I have the same issues with my X-pipe and catback system from Magnaflow.
I plan to have an exhaust shop weld the system together.
jackal98 is offline   Reply With Quote
exhaust
Exhaust Question michael81 2011-2014 Mustang GT 30 10-04-2011 10:39 PM
Detecting Exhaust Leak? crkmonzo 1979-1995 Mustang GT 6 09-22-2011 10:38 PM
exhaust question... (04 GT) Topless04GT 1996-2004 Mustang GT 7 07-23-2011 04:10 PM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 12:29 AM
Exhaust question Blackedout Pre-2005 V6 Mustang 4 06-29-2011 08:07 AM
05:44 PM
