Ford Sync - Mustang Evolution
Old 10-24-2011, 05:18 PM   #1
2011CS's Avatar
Ford Sync
Question. When I first bought my stang I could plug my iPhone into the USB port in the center console and play my music through the speakers. Now it won't work through the speaker. Anybody know why it won't work now.
2011CS is offline   Reply With Quote
Old 10-24-2011, 05:25 PM   #2
Re: Ford Sync
Did you change the setting? That is what my wife did in her toyota with her sync.
Old 10-24-2011, 05:25 PM   #3
Ravnus's Avatar
If u have Navigation, u don't need a wire it syncs wirelessly
Ravnus is offline   Reply With Quote
Old 10-24-2011, 05:34 PM   #4
2011CS's Avatar
I don't think I changed anything but I quess I could have.
---------- Post added at 05:32 PM ---------- Previous post was at 05:32 PM ----------
No navigation.
---------- Post added at 05:34 PM ---------- Previous post was at 05:32 PM ----------
No navigation.
I guess I will play with the setting tomorrow. I wonder if I updated my phone if that might be the problem. I can't remember last time I updated it.
Old 10-24-2011, 05:49 PM   #5
5pointOh's Avatar
Re: Ford Sync
This happened to me but only with my ipod. What you have to do is pull the fuse for SYNC. Pull it and leave it out for about 30 secs and replace. I did that and everything worked fine, of course you gotta pair your phone again. If I remember correctly its fuse #3
2012 kona blue gt, GT500 exhaust, tinted windows, J&M Panhard bar, Steeda Ultralites, Koni STR shocks and struts, GT500 strut mounts, SR Performance shifter, Steeda Shifter Bracket, 20" Giovanna Monzas..damn I need more money!!
5pointOh is offline   Reply With Quote
Old 10-24-2011, 05:55 PM   #6
2011CS's Avatar
Cool thanks. I will try that.
Old 10-24-2011, 06:10 PM   #7
gtstyles2's Avatar
On your iPhone touch your screen, make sure the sound is coming out of "sync" not Bluetooth or speakerphone .... Your Bluetooth might be taking over, it's nothing to do with the car settings...
Old 10-24-2011, 06:12 PM   #8
5pointOh's Avatar
Sure, let me know if it works for you
Old 10-24-2011, 06:13 PM   #9
gtstyles2's Avatar
Make sure your in the iPod app in the iPhone, it happened to me, it seemed the the music was playing but muted
Old 10-24-2011, 06:31 PM   #10
mgioia2's Avatar
All Ford Sync in the Mustang is wireless...go to phone, add new device, and then just reSync your phone with your car if you're having trouble...
I change operating systems in my cell phone a few times a week, everytime I do it have to resync with my car, takes 20 seconds tops...
2012 GT Pemium w/hood and spoiler package, auto
mgioia2 is offline   Reply With Quote
Old 10-24-2011, 06:38 PM   #11
2011CS's Avatar
I'v tried re-syncing the phone and it still does not work. If I remember correctly when the iPod app is running a white screen cones up and says something about not being able to access my library or some thing like that.
---------- Post added at 06:38 PM ---------- Previous post was at 06:37 PM ----------
I kinda think what the person said about fuse is hopefully it. Thanks
Old 10-24-2011, 06:40 PM   #12
gtstyles2's Avatar
Is the iPod playing but silent? I'm sure it's your Bluetooth taking over the USB
Old 10-24-2011, 06:45 PM   #13
2011CS's Avatar
No it just goes to that screen that says can't access library and won't let me view any music till I pull the USB out. As soon as I unplug the USB then I can access my library.
Old 10-24-2011, 10:53 PM   #14
M3to5.0's Avatar
Re: Ford Sync
Damn Microsoft...lol
M3to5.0 is offline   Reply With Quote
Old 10-24-2011, 11:10 PM   #15
MedxGT's Avatar
For the best audio use the USB cable. Make sure that at the bottom of your iPod screen you click on the little box, and select DOCK CONNECTOR, then on the media screen, choose USB as your source. Once sync finds your music, just go to Library, or use the voice search option.
MedxGT is offline   Reply With Quote
Old 10-25-2011, 02:35 AM   #16
It's not me, it's you.
primer2tone's Avatar
I had the same problem with the sync on my F150 about 6 months ago and I told my service writer when I took it in for service. Idk what they did but it's worked ever since.
Old 10-25-2011, 10:56 AM   #17
Napoleon85's Avatar
Re: Ford Sync
I have problems every time I start the car ... here is what I usually do.
1. Start with the car off
2. Plug the iPod/iPhone in to the USB cable
3. Start the car
4. Press the voice command and say "USB" - it will switch but nothing will play
5. Unplug the device from USB - audio should now start playing through bluetooth
6. Plug the device back in to the USB cable
7. Press the voice button and say "USB" - it should now switch to USB and start playing
Bottom line, SYNC is a complete toolbag piece of ****. I had this exact same issue in my '10 with an Android device, a new car and a new phone later the **** still sucks. The underlying issue is that when you turn the car on it connects via USB and Bluetooth. There is no way to tell SYNC to only use bluetooth for Services and Phone Calls, it's ON of OFF. It seems to me that the easy fix would be to allow us to disable Bluetooth streaming audio.
Old 10-25-2011, 11:21 AM   #18
Ravnus's Avatar
Has anyone figured out how to bypass the safety on the Sync DVD/Nav? I wanna watch movies in motion. I think it has something to do with the emergency brake. My buddy has a Lexus ISF and he just spliced some wires.
Old 10-25-2011, 10:39 PM   #19
MedxGT's Avatar
http://www.coastaletech.com/synclockpick.htm
It isn't cheap.
Old 10-26-2011, 07:55 AM   #20
Napoleon85's Avatar
Re: Ford Sync
There's a cheaper way to do it. It's a single wire that needs to be grounded and it tricks the system into thinking the car is in park. No, I don't know what wire it is. You local car audio shop should be able to hook you up, or google it.
Old 10-26-2011, 08:20 AM   #21
MedxGT's Avatar
Wow. Awesome. Does this work even with a manual transmission? Anyone with a how-to on this, please post
Old 10-28-2011, 06:30 AM   #22
avengnd's Avatar
Re: Ford Sync
touch screen or not, your iphone will connect via bluetooth. just tell the lady bluetooth music and you should be good to go. The only bad thing is you can't request songs etc. It uses the itunes on your iphone like the car uses the iphone.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 11-16-2011, 09:53 PM   #23
Tom6502's Avatar
3. Start the car
I have found that If no music is playing in usb then the phone is on Bluetooth. go to iPhone start Music app, then in lower right is a box with triangle press it and select dock connector.
Have you tried starting the car first and the. plugging in the iPhone?
Tom6502 is offline   Reply With Quote
Old 11-17-2011, 06:34 AM   #24
Napoleon85's Avatar
Re: Ford Sync
Yes, that is typically what confuses it in the first place. When you turn the car on first it connects to bluetooth and starts playing audio, even if that source is not selected.
Ford rumors of SVO mustang to be produced for 2015 mustang Kyle94GT302 General Mustang Discussion 3 10-19-2011 10:02 AM
1968 Ford Mustang for sale Thunder68 Classic Mustangs 1 09-24-2011 05:16 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
10:00 AM
