Abnormal noise with my 5.0 - Mustang Evolution
Old 11-01-2011, 11:44 PM   #1
I own a 2012 mustang 5.0. It has 1200 miles on it now. The car runs great but it just started to make a noise only when first started cold. It starts once I hit a speed usually above approx 20 mph , It increases in intensity and only when the throttle seems closed or when i let off the accelerator. It does not make the noise when stopped or when the car is not moving. The noise is high pitched and slows down in intensity as the car slows down. I goes away after a short period of driving(about a min or less) and only repeats just when the car is first started after sitting for at least and hr. What could this be? Thank you
tmag is offline   Reply With Quote
Old 11-02-2011, 12:40 AM   #2
M3to5.0's Avatar
Re: Abnormal noise with my 5.0
Does it resemble a "supercharger whine"? If so it is normal for our cars I assume as every one I know with a 11+ manual has the same issue, it is the tranny whining.. Just get a louder exhaust..lol
M3to5.0 is offline   Reply With Quote
Old 11-02-2011, 01:03 AM   #3
No it's a little different than that noise that you're describing. It's weird because it stops after a short time of driving and it's not present during acceleration. I do like the idea of a louder car. Haven't put the off-road pipes on yet
Old 11-02-2011, 01:18 AM   #4
Do you have 3.73 gears?
Old 11-02-2011, 09:34 AM   #5
Ravnus's Avatar
Make an appointment at the dealer and drop the car off the night before so it sits. I wouldn't worry unless you tuned it already.
Ravnus is offline   Reply With Quote
Old 11-02-2011, 10:03 AM   #6
crank it and let it sit and fully warm up then drive it, if it doesnt do it... it my be valve train noise (when it first is getting lubed up in the morning)
Old 11-02-2011, 07:47 PM   #7
I do have 3.73 gears in the car. If I start the car cold and let it idle for approx. 15 mins it does not make the noise.
Old 11-03-2011, 01:57 AM   #8
Benzo's Avatar
Could be neutral gear spin the tranny is right under u. I can hear it in my car from time to time.
---------- Post added at 06:57 AM ---------- Previous post was at 06:55 AM ----------
I have the 3.73's also in first and second i hear neutral gear spin from time to time.
Benzo is offline   Reply With Quote
Old 11-03-2011, 10:37 AM   #9
jimbullit's Avatar
I don't think you need to warm the engine for 15 minutes-unless it's 'below freezing', outside.. But I personally believe in warm-up in the driveway, for awhile, to get everything lubed up, intially. As has been stated-if this persists-take it to your dealer. Let us know the outcome.
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 11-05-2011, 08:56 PM   #10
back n a stang's Avatar
Mine has a little faint type tick on ''cold start" but I don't think it's anything serious.Almost thought it was exhaust related so I tighten everything again and it still does it.Only on cold start and only for a minute max. 3900 miles.....not to worried about it.
Old 11-07-2011, 05:35 PM   #11
I don't know if I have ever had a car that made as many noises when new as this 2012. At low gear (1-4) it's all transmisison noise. Once that is gone the rear 3.73 diff takes over the rest of the range. Add to that drivetrain lash and exhaust note and never is there a dull moment.
unimorpheus is offline   Reply With Quote
Old 11-07-2011, 08:30 PM   #12
SSC182's Avatar
It could also be timing chain noises though that is usually a ticking sound and you won't usually here in the cabin
SSC182 is offline   Reply With Quote
Old 11-09-2011, 11:52 AM   #13
drivinglesson's Avatar
I am so glad I am going deaf...
2016 Mustang GT
drivinglesson is offline   Reply With Quote
Watch 5.0 Magazine test AmericanMuscle's 2011 V6! AMDanBailer 2011-2014 V6 Mustang 0 10-19-2011 01:47 PM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 09:14 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 05:49 AM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 05:08 PM
05:15 PM
