LCA Relocation Brackets - Mustang Evolution
Old 11-06-2011, 01:06 AM   #1
M3to5.0's Avatar
Question.... If I lower the car, I have to get LCA relocation brackets? I bought Eibach adjustable LCA's.... but I cannot find a relocation brackets for LCA's anywhere. Am I overlooking the obvious? a little help would be appreciated.
M3to5.0 is offline   Reply With Quote
Old 11-06-2011, 06:37 AM   #2
Re: LCA Relocation Brackets
It is a good idea to get them to help correct the angle of the LCA's.
Rear Control Arm Relocation Brackets : UMI Performance, Inc.
Old 11-06-2011, 10:20 AM   #3
M3to5.0's Avatar
Damn Brackets cost almost as much as the LCA's themselves...... lol
Old 11-06-2011, 11:43 AM   #4
back n a stang's Avatar
Do you need reloc. brackets if you don't lower??I like these threads about LCA's/reloc. brac. as we all got to cross this bridge if we want performance.I started a similar thread.Seems Brad(wnt2gofst) is our only guy with knowledge on it.I am wondering when you do it do you got to have any alighnment work done or is it just bolt and go.Seems like a easy fix to gain grip and stop wheel hop.!!??
Old 11-06-2011, 11:46 AM   #5
Napoleon85's Avatar
No, they just help you adjust the angle of the LCAs on lowered cars from what I understand.
Old 11-06-2011, 11:49 AM   #6
K....cool....so all I need is LCA,s and no alighnment??Napoleon85 are you using lca's yet?
Old 11-06-2011, 11:53 AM   #7
Napoleon85's Avatar
Not yet. I will be installing LCAs as well as a new UCA and mount this winter. Hopefully an off-road x-pipe as well, then dyno tune in the spring. If the tax man is nice enough I may even see some new wheels and tires.
Old 11-06-2011, 12:01 PM   #8
What improvements are from the UCA's expected.I am looking at tax return help too.I bought a 70,000.00 tool truck so should get plenty of help on write offs.Ever need any speciality tools holla.
Old 11-06-2011, 12:02 PM   #9
Napoleon85's Avatar
Helps reduce wheel hop and improve stability of the axle.
Old 11-06-2011, 12:07 PM   #10
Ok....Got a link to the ones you looking at? Are you lowering or staying stock height?
Old 11-06-2011, 12:21 PM   #11
Napoleon85's Avatar
Staying stock height for now, but I will be lowering at some point. When I do, I will put the LCA relocation brackets on. I haven't decided which one I'm going with yet ... but here are the links to what I have been looking at.
BMR
UCA
UCA Mount
LCAs
BBR
UCA
UCA Mount
LCAs
note: I believe these are all repainted/rebadged BMR parts
UPR
UCA with mount
LCAs
I'm not sure which ones I'll be getting, and have no data on the performance of any of these products. It would be nice if people who had them installed would chime in with pros and cons. At this point it's pretty much speculation, all I've been able to find on the forums is people whining about how they aren't as quiet as the stock parts ...
Also, note that these are all non-adjustable since I'm mainly building a street car that will occasionally see the track. If you're building a hard-core drag car you will probably want to look for the adjustable versions of these parts.
Old 11-07-2011, 02:44 AM   #12
Also a adjustable UCA lets you adjust the angle of your tranny-driveshaft-axle when you lower the car a lot. Not always needed though. I know with mine i didnt need it but I did a UCA anyway just cause its stronger/lighter and adjustable in case i needed it.
You will not need an alignment when doing LCA's. Even if you are lowered.
---------- Post added at 03:44 AM ---------- Previous post was at 03:38 AM ----------
Also the BBR stuff is basically what you said repainted BMR stuff. I really liked my BMR stuff on my G8. I have some BMR stuff on the car now most of it is now been switched to UPR.
I had Spohn which is known for Mcars also. But I split a bushing on my LCA's. Guess it didn't like my 6000rpm launches. LOL
UPR/BMR you can't go wrong.
Old 11-15-2011, 12:15 PM   #13
Napoleon85's Avatar
Why did you switch some of your BMR stuff to UPR? I'm leaning towards UPR anyways (the 10% discount helps) but I'm just curious. Would it be prudent to go ahead and spend the extra money for the adjustable third link/UCA? It's only $60. I'm going to go with the billet LCAs I think.
Old 11-15-2011, 02:43 PM   #14
I broke a bushing in the BMR LCA's I had. So when I bought new ones I went with spherical ends on both sides in stead of just one. If you plan on lowering or anything get adjustable LCA's. Same goes for the UCA.
Old 11-15-2011, 03:01 PM   #15
Napoleon85's Avatar
I do plan on lowering. Do I still need adjustable LCAs if I run relocation brackets?
lca which one kickerofdoom Pre-2005 V6 Mustang 15 07-02-2011 04:57 PM
06:00 AM
