Manual Transmission Fluid - Mustang Evolution
Old 11-15-2011, 07:19 AM   #1
Napoleon85's Avatar
So the stang is all put up for the winter and I'm starting to gear up for some projects to get her ready to kick some serious *** next spring. First on the list is changing the manual transmission fluid, since I'm getting some pretty bad crunching when shifting until it warms up (if the fluid change doesn't fix it I will take it to the dealership but I'm trying to avoid that for all the obvious reasons).
I was planning on putting in Royal Purple MT Fluid, but someone (cant remember who or what forum) said that I should be careful about doing that and only use the dual-clutch MT fluid from Ford/Motorcraft. Is there any credibility behind this or will I be OK running the Royal Purple stuff? If so, should I just get the fluid from Ford or are there any other acceptable alternatives.
Also, if you have changed your fluid out for anything other than the Motorcraft Dual Clutch stuff, please let me know what you used and whether it helped the crunchy gear shifting.
Thanks!
Old 11-15-2011, 08:11 AM   #2
Benzo's Avatar
Thanks!
I second this! I would like to know the same.
Benzo is offline   Reply With Quote
Old 11-15-2011, 10:32 AM   #3
Yea you basically have the same question that I am asking. One of the guys on this forum was telling me there is a TSB I believe and the dealer will change it for you which I am going to look into. I was going to buy the royal purple stuff at first too from anericanmusce.com but someone told me if you use anything other then Ford tranny fluid or what is recommended they might not warranty it if anything ever happens to the tranny.
5.ohhhhh is offline   Reply With Quote
Old 11-15-2011, 10:40 AM   #4
jimbullit's Avatar
Re: Manual Transmission Fluid
True, that. Go with their recommendation, and have it done at the dealer, per their TSB.
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
jimbullit is offline   Reply With Quote
Old 11-15-2011, 10:55 AM   #5
Napoleon85's Avatar
Yes, there is a TSB but I will not be taking it in. My warranty is history, but I don't want to discuss that. I want to discuss if there are any technical reasons that the Royal Purple MTF would not be compatible with the MT-82. Regardless of the fluid used, I will be doing the change myself.
Old 11-15-2011, 12:04 PM   #6
I have not heard anything about the royal purple but I know you can buy it on americanmuscle.com. I would go with the dual clutch.
Old 11-15-2011, 02:47 PM   #7
I am running redline in mine. I know others running RP or RL as well. No issue. Helps the tranny shift smooth here.
6 spd. transmission in Mustang GT made in China Mercedez L. 2011-2014 Mustang GT 24 01-11-2012 08:49 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
Change Transmission Fluid pcarman 2011-2014 Mustang GT 11 10-01-2011 12:27 PM
Best Transmission Fluid Stang23 2005-2010 Mustang GT 0 08-07-2011 12:48 PM
Auto to Manual swap? BrKu789 1996-2004 Mustang GT 9 07-17-2011 09:17 PM
11:21 AM
