K sprigs install - Mustang Evolution
Old 11-28-2011, 03:41 PM   #1
Reinkey's Avatar
K sprigs install
Do I need to take my mustang to get an alignment if I install k springs? Do I need to purchase any parts other then just the springs? I saw on the website they recommend installing other parts along with the springs.
Reinkey is offline   Reply With Quote
Old 11-28-2011, 03:53 PM   #2
Loc: Austin,TX
Re: K sprigs install
Yes you need to take her in for alignment after the spring install. You may need camber bolt which are not very expensive and you may not need them, some also get new strut mounts and some disagree with that. A 1.5 drop is not that bad so you may not need the camber bolts.
Old 11-28-2011, 11:11 PM   #3
M3to5.0's Avatar
Get the GT500 upper strut mounts at a minimum. The suspension is one of those items you DONT half ***. They are only 85.00. The springs will not seat correctly on the stock strut mounts.
"Got to kill.... Captain Stupid"
M3to5.0 is offline   Reply With Quote
Old 11-29-2011, 04:58 AM   #4
Loc: Austin,TX
They seated fine for me.
Old 11-29-2011, 05:04 AM   #5
Reinkey's Avatar
Anyone know of a vendor in Houston where I can buy the bolts and if I don't need the I'll take them back
Old 11-29-2011, 06:11 AM   #6
M3to5.0's Avatar
You are special then....
Old 11-29-2011, 06:43 AM   #7
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Brembo brake packages don't require plates either. I installed mine got the front end aligned and the shop said they had no problem aligning after the drop.
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 11-29-2011, 07:08 AM   #8
Reinkey's Avatar
I don't have the brembo package
Old 11-29-2011, 08:05 AM   #9
gregtommy's Avatar
I would recommend camber plates then, I can't remember what other member it was but he used the ksprings and got the camber plates to make the alignment go more smoothhly and he also didn't like the look with the 18 in rims and the drop so u might consider increasing your rim size to 19 or go big and go with 20's. I do have the brembo package with 19's on k springs so if you want you can check out my garage and see how it looks the my car has some before the drop photos for u to compare as well
MOTM DEC 2011
Old 11-29-2011, 08:28 AM   #10
Reinkey's Avatar
I'll prolly get the camber plates cause I'm the kind of person that don't do anything half ***. Do it right or don't do it. I have the 19" rims. So no issue there they are the grey spoke factory 19x8.5 I believe.
Old 11-29-2011, 10:05 AM   #11
M3to5.0's Avatar
I sure hope your not right with the rim size..... I just bought 18's to replace my 19's
Old 11-29-2011, 10:14 AM   #12
gregtommy's Avatar
Yeah that was in his opinion I don't know, I know that I like the drop with 19s although the rims I want will be staggered 20s
MOTM DEC 2011
Old 11-30-2011, 12:46 AM   #13
11stangGT's Avatar
Region: Arkansas
That extra half inch makes a lot more difference than you would think.. I have seen someone complain about their 19x8.5s looking too tucked in after the drop... They are also a different offset wheel so makes it stick out further..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 11-30-2011, 04:37 AM   #14
Reinkey's Avatar
Was there enough clearance? Did the tires rub when he turned?
Old 11-30-2011, 07:05 AM   #15
11stangGT's Avatar
Region: Arkansas
I never saw him say anything about it..
Old 11-30-2011, 08:19 AM   #16
Reinkey's Avatar
Well what about p springs? They are 1 inch all around. Is that still a noticeable difference?
Old 11-30-2011, 08:24 AM   #17
11stangGT's Avatar
Region: Arkansas
Check out late model resto.. They have instructions for the installation and they used p springs.. They have b4 and after pics..
Old 11-30-2011, 08:26 AM   #18
Reinkey's Avatar
Sweet thanks
Old 11-30-2011, 10:41 AM   #19
11stangGT's Avatar
Region: Arkansas
Sweet thanks
I think his pic is with the brembo wheels though if I remember correctly..
Stripe Install Jeffola 2011-2014 Mustang GT 14 10-24-2011 04:48 AM
New gear install prices XXSTEVEO66 1979-1995 Mustang GT 10 09-02-2011 11:59 AM
Steeda Tri ax short shifter install..... rinfield2004 SVT Mustang 10 09-02-2011 12:40 AM
BBK long tube headers install help....... rinfield2004 SVT Mustang 15 07-20-2011 08:17 AM
saleen roll bar install..... rinfield2004 Mustang Paint, Appearance & Detailing 5 07-13-2011 02:28 PM
05:10 PM
