Rear wheel hop problem - Mustang Evolution
Old 12-09-2011, 06:37 PM   #1
Nobody able to solve the dreaded rear wheel hop we get on our cars?
2011 mustang gt is offline   Reply With Quote
Old 12-09-2011, 06:51 PM   #2
phobik's Avatar
Peg leg?
phobik is offline   Reply With Quote
Old 12-09-2011, 08:36 PM   #3
back n a stang's Avatar
Re: Rear wheel hop problem
Easy!! Aftermarket LCA's!! Hell,even when I took off the OEM tires and put on my Hankooks the hop got better.With LCA's you get better grip which means better launch.Otherwise you are stuck with it
Old 12-09-2011, 09:17 PM   #4
GrayGhost's Avatar
As stated, aftermarket lower control arms should do the trick. I had those, the upper control arm, and the upper 3rd link mount all replaced at the same time so I'm not sure how effective the LCA-swap would have been on its own.
2011 Mustang GT Premium 401A Spec- Sterling Gray, aka "Graycie", 6-Speed MT, 3.73, Brembo Brake Package, Current Mods: FRPP-Brakelines/Brake Ducts/Alternator/Radiator/Oil Pan/Oil Cooler/Trans.Scoop/Alum.Axle Cover, Steeda-Sport Springs/3rd Link/Adj.UCA/Alum.LCA/Rel.Brackets/Adj.PHB & Brace/Adj.F&R Swaybars/Adj.Front Endlinks/HD Strut Mounts/X11 Ball Joint/Bumpsteer/CAI, Koni Sport Shocks, ATI Damper, MGW Shifter, Kooks Catback, Wavetrac Diff, Michelin Pilot Super Sport... 93 Octane Performance Tune by VMP
GrayGhost is offline   Reply With Quote
Old 12-09-2011, 10:53 PM   #5
Any suggestions for brand of lower control arm? Cost? Is it a do it yourself bolt on? Thx!
Old 12-09-2011, 11:50 PM   #6
Some of them are BMR.UPR,and Spohn to name just a few of the very best.Yes you can do it yourself.Will take you at least 2 hours but might take 4 or 5.You will need Jack stands for sure,TQ wrench and Etc.
As for the type.....There are several.If you do not plan on racing at the drag strip and/or not very high RPM launches then you may want to go with the polyeruthene (sp) bushing ends.If you do race and launch strong you will split the bushing.Bushings are not much at all money wise but still pain in the *** to be replacing and that will get old.They make some with sepherical ends which are alot stronger.They also make some that are just solid-ends teflon lined and nothing to break.These are great for racing and playing.No matter which ones you go with it will change your ride quality.You will feel and of course noise transfers easier.The Factory ones have soft cushion like bushings.Makes car all smooth,quiet,but leaves you with wheel hop.Your Best bet is to google BMR and go on the site and read up on susp. stuff for 2011-12 GT's.They have a LCA section.If you plan on lowering your car in the future you might better get the adjustable LCA's but personally I would stay away from the Poly type.The ones I just bought from them you probably would not want unless you are gonna race like I said.Also they are a bit more pricey.They are BMR # is TCA-020.There sittin in front of me waiting on install.Overall alot of guys go with the poly type bushing ends and can be had for as little as 100.00. Just a decision you will have to make.There are many threads on here to help ya understand it all. Hope this helped ya a little
Old 12-10-2011, 02:18 AM   #7
MedxGT's Avatar
Nice write-up!! I'm considering LCA's and this was great information. Thank you!
MedxGT is offline   Reply With Quote
Old 12-10-2011, 07:55 AM   #8
Wow! Thank you...my shop iS installing 35125.880 Eibach sway bar and spring kit Monday. I will then get cracking on research for the LCA. Thank you for the info and advice. My car is an '11 GT 6 speed, stock Vortech an
D nothing more. My goal is to keep it very stock looking with a ju
St a bit more power and handling...
Old 12-10-2011, 11:58 AM   #9
M3to5.0's Avatar
Even with the wheel and tire swap the wheel hop got 75% better.... when I put on the LCA's... should be golden
"Got to kill.... Captain Stupid"
M3to5.0 is offline   Reply With Quote
Old 12-10-2011, 01:46 PM   #10
+1 Agreed and mine are not on yet.Tires sure helped half the problem.LCA's will solve the other half.I got a buddy who has a 4-point nice lift in his garage.Gonna just wait and do it there.
---------- Post added at 03:46 PM ---------- Previous post was at 03:43 PM ----------
Damn Dude....You got a Vortech!! How much HP you making? Ohh yeah! For sure get the good LCA's and have fun dropping clowns off with your beast! LOL!
Old 12-10-2011, 02:08 PM   #11
M3to5.0's Avatar
Not trying to poke anyone in the eye... but I was always taught to build a car from the ground up... you know... Brakes, Wheels and tires, suspension, fuel and oil, engine internals... THEN super/ Pro Charger. If you are still dealing with wheel hop with a pro charger... I would say you might be a little behind the power curve as far supporting performance parts go. I may be wrong... I have been ONCE before...lol
Old 12-10-2011, 04:20 PM   #12
phobik's Avatar
I agree with u. U always want to upgrade ur wheels suspension etc so the power can be supported on the ground as well
Old 12-10-2011, 06:26 PM   #13
Napoleon85's Avatar
I have links to parts here from BBR/BMR/UPR
LCA Relocation Brackets
Old 12-10-2011, 10:19 PM   #14
SSC182's Avatar
If you want an easy solution to wheel hop put an airbag inside the right rear spring and put about 60 lbs of air in it and you will have zero wheel hop. I mean LCAs work also but drag racers have been doing the airbag trick for many many years and it works.
SSC182 is offline   Reply With Quote
Old 01-26-2012, 06:55 PM   #15
Ravnus's Avatar
Where do I get an airbag?
Ravnus is offline   Reply With Quote
Old 01-26-2012, 08:26 PM   #16
Yellow50's Avatar
Very curious of the airbag trick please explain thank you
Yellow50 is offline   Reply With Quote
Old 01-27-2012, 04:33 AM   #17
avengnd's Avatar
Ordered mine today Ford Racing Mustang Rear Lower Control Arms (05-12 All) M-5538-A - Free Shipping! they will go with my FRHP (Ford Racing Mustang Handling Pack - Coupe (05-12 GT) M-FR3-MGTA - Free Shipping!) that is sitting in the garage at the moment.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
IRS wheel hop issues....... rinfield2004 SVT Mustang 21 01-26-2012 10:28 PM
Rear end a little funny BigRed1781 1979-1995 Mustang GT 13 12-13-2011 12:07 PM
Getting the car to hook and stop wheel hop back n a stang 2011-2014 Mustang GT 7 11-06-2011 06:02 PM
Rear wheel spacers Tippy 2005-2010 V6 Mustang 14 10-20-2011 10:52 PM
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
01:42 PM
