Header question - Mustang Evolution
Old 12-17-2011, 10:59 AM   #1
back n a stang's Avatar
Header question
If I do long tube headers what kinda issues will I run into connecting the current Borla catback I have to the headers?The catback has x-pipe(not off road) and just wondering what I will run into connection wise.I can do with or without cats.Not worried about that.Anybody know whats the best route and whats involved??Will I need more than just the LT's?Is there got to be bunch of cutting and welding to custom fit up to the LT's ?
Old 12-17-2011, 01:43 PM   #2
You should have buy a x pipe. You would really have get under it and see if the LT's would connect up. More then likely you will need a x pipe to match LT's. Then the cat back you have with out the x pipe.
Old 12-17-2011, 02:06 PM   #3
deadsp0t's Avatar
++ would defiantly buy an X to match the LT's and cat back before I paid to have the other mid pipe cut and welded IMO
That's unimpressive
Old 12-18-2011, 12:26 PM   #4
Benzo's Avatar
+1
Benzo is offline   Reply With Quote
Old 12-18-2011, 05:01 PM   #5
Re: Header question
Maybe I will see if Borla has a off road X-pipe that will match up to my current borla catback.Just pull my X-pipe out.Wonder what the gains will be by doing away with cats?The current exhaust is giving me pretty happy gains so maybe just leave it all alone.Sure do not want it any louder.If off road gives me much power over current X I will strongly consider.
Old 12-18-2011, 05:57 PM   #6
Re: Header question
Deleting the cats with an O/R X seems to gain about 15-25whp depending on the dyno used. That is also with a tune for it.
Old 12-20-2011, 06:53 AM   #7
GrayGhost's Avatar
Re: Header question
The Borla x-pipe has to be removed/replaced. The mid-pipe for the long-tube headers, which can be catted or non-catted in x-pipe configuration at exit of mid-pipe, will connect to the Borla cat-back.
2011 Mustang GT Premium 401A Spec- Sterling Gray, aka "Graycie", 6-Speed MT, 3.73, Brembo Brake Package, Current Mods: FRPP-Brakelines/Brake Ducts/Alternator/Radiator/Oil Pan/Oil Cooler/Trans.Scoop/Alum.Axle Cover, Steeda-Sport Springs/3rd Link/Adj.UCA/Alum.LCA/Rel.Brackets/Adj.PHB & Brace/Adj.F&R Swaybars/Adj.Front Endlinks/HD Strut Mounts/X11 Ball Joint/Bumpsteer/CAI, Koni Sport Shocks, ATI Damper, MGW Shifter, Kooks Catback, Wavetrac Diff, Michelin Pilot Super Sport... 93 Octane Performance Tune by VMP
GrayGhost is offline   Reply With Quote
Old 12-20-2011, 07:50 AM   #8
skyline247's Avatar
+1. As everyone else has said, you can keep the catback, but you will need to buy a new x-pipe for the LT headers (I would avoid cutting and welding the existing x-pipe). You should have some nice gains and a killer sound with this exhaust setup.
---------- Post added at 09:50 AM ---------- Previous post was at 09:43 AM ----------
I think most vendors that make LTs offer an x pipe to go along with the headers.
1988 GT - Stock
*SOLD* 2012 GT Premium, Black on Black, 3.55 Axle, HID and Security Package, Pypes Pype Bomb Axle Backs
skyline247 is offline   Reply With Quote
Another Header question OrganDonor 2011-2014 Mustang GT 12 10-30-2011 02:54 PM
Header question Brandon91 1979-1995 Mustang GT 45 08-29-2011 03:33 PM
Longtube header question? WhiteCobra94 1979-1995 Mustang GT 5 07-27-2011 04:34 PM
header question workmail21 1979-1995 Mustang GT 12 07-26-2011 02:15 PM
header question workmail21 1979-1995 Mustang GT 4 07-19-2011 03:20 PM
11:54 AM
