Muffler removal - Mustang Evolution
Old 12-29-2011, 12:31 PM   #1
Muffler removal
I'm having trouble removing my stock mufflers on my 2011 GT. Got the rear hanger off of the rubber, and the clamp undone completely, the pipe is free. But I can't get the muffler to slide forward to free it from the rubber hanger towards the front of the muffler near the axle. Any tips on how to free it?
ray bouquet is offline   Reply With Quote
Old 12-29-2011, 04:19 PM   #2
gtstyles2's Avatar
Re: Muffler removal
Its pretty easy actually, use wd40 to lube the rubber hangers off, its useless pulling the actual muffler off the hangers.... its more difficult that way. Also, u will need a crowbar to break off that link between the muffler and the pipe
Old 12-29-2011, 04:23 PM   #3
5pointOh's Avatar
Re: Muffler removal
you gotta use some old fashioned elbow grease man..you won't break anything unless you are the incredible hulk. Like Gt said though, make sure you lube up those rubber hangers and that will make life easier. Oh also, I put a wrench between the hook from the exhaust and the rubber hanger to help get it loose also.
2012 kona blue gt, GT500 exhaust, tinted windows, J&M Panhard bar, Steeda Ultralites, Koni STR shocks and struts, GT500 strut mounts, SR Performance shifter, Steeda Shifter Bracket, 20" Giovanna Monzas..damn I need more money!!
5pointOh is offline   Reply With Quote
Old 12-29-2011, 05:24 PM   #4
bigsmitty24's Avatar
+1. Just did mine monday. Can be a pain in the a$$ but patience is key.
bigsmitty24 is offline   Reply With Quote
Old 12-29-2011, 05:29 PM   #5
yugoboss's Avatar
You can also undo the bolts that hold the hanger, and pull the muufler of with the hanger.
yugoboss is offline   Reply With Quote
Old 12-29-2011, 05:46 PM   #6
Loc: Austin,TX
Re: Muffler removal
No need for a crowbar or unbolting the hangers. Loosen up the mid pipe so you can slide the overaxel pipes back. This will give you the room to remove the mufflers.
Old 12-29-2011, 07:37 PM   #7
11stangGT's Avatar
Region: Arkansas
You can do it put your back into it haha
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 12-29-2011, 08:20 PM   #8
Re: Muffler removal
Thanks for the info guys. I used the wd-40 and lowered the panhard brace on the drivers side . Gave me the rooom to make it fairly easy. The flowmaster classic american thunder mmufflers sound great, by theway.
New Muffler Option- Boner Time robb15033 Pre-2005 V6 Mustang 0 11-22-2011 11:29 PM
Muffler Delete MustangGT02 1996-2004 Mustang GT 21 11-15-2011 06:30 PM
Single muffler flowmaster 98projectpony Pre-2005 V6 Mustang 32 11-11-2011 12:58 PM
Off road H or X...muffler deletes SaleenV8 2011-2014 Mustang GT 1 08-30-2011 03:10 AM
12:09 AM
