01-09-2012, 04:46 PM
#1 | | Registered User
| need some help
Hey guys i know I'm still new too this but recently there has been a noise coming from the lower front suspension of my 2011 5.0, and it almost sounds like something is rubbing against something. I don't know if its a loose bearing, or a control arm or something, but i remember hearing some where that there was a TSB for it ?
__________________ |
01-09-2012, 05:58 PM
#2 | | Registered User
| Re: need some help Quote:
Originally Posted by 5.ohhhhh Hey guys i know I'm still new too this but recently there has been a noise coming from the lower front suspension of my 2011 5.0, and it almost sounds like something is rubbing against something. I don't know if its a loose bearing, or a control arm or something, but i remember hearing some where that there was a TSB for it ? | There is a TSB for popping/clanking when going over bumps, procedure is to replace some bushings on the front LCAs I believe. This does not sound like that ... can you be more specific?
01-09-2012, 09:43 PM
#3 | | Registered User
| Re: need some help
Yeah I blew my front passenger tire about a month ago, so i took it in to get change, and it was then when i noticed the noise, and the car just didn't feel the same so i took it into my mechanic who's a close friend of mine, and he looked at it and showed me that my car needed an alignment, so he fixed it for me and everything, but the noise is still there. It literally just sounds like something is rubbing against something, and now im wondering if i should just take it in to ford ?
01-09-2012, 10:04 PM
#4 | | Registered User
Originally Posted by 5.ohhhhh Yeah I blew my front passenger tire about a month ago, so i took it in to get change, and it was then when i noticed the noise, and the car just didn't feel the same so i took it into my mechanic who's a close friend of mine, and he looked at it and showed me that my car needed an alignment, so he fixed it for me and everything, but the noise is still there. It literally just sounds like something is rubbing against something, and now im wondering if i should just take it in to ford ? | Either that or a competent mechanic. I would get someone to look at it if you don't have any leads as to what it might be.
01-09-2012, 10:30 PM
#5 | | Registered User
| Re: need some help
Squeaky Bushings????
__________________ "Got to kill.... Captain Stupid" |
01-10-2012, 10:19 PM
#6 | | Registered User
| Re: need some help
maybe it could be squeaky bushings but i dont know...but yeah i'm probably going to take it to ford this week and let you guys know
Thanks
01-11-2012, 08:46 AM
#7 | | Registered User
Had the same thing after just one week. Took it in and the dealer swapped out both control arms; no noise since.
2011 Mustang GT
01-11-2012, 03:46 PM
#8 | | Registered User
I have a 2012 GT 5.0. It was doing the exact thing as you'd with only 300 miles!! It was the front passenger side control arm!! Had it replaced and more problem!!!
01-11-2012, 04:38 PM
#9 | | Registered User
| Re: need some help
better get it checked
__________________ 2011 GT Premium Race Red Shaker 1000 | polished 18s | comfort | flowmaster cat back |
01-12-2012, 11:49 PM
#10 | | Registered User
| Quote: |
Originally Posted by Tominkc I have a 2012 GT 5.0. It was doing the exact thing as you'd with only 300 miles!! It was the front passenger side control arm!! Had it replaced and no more problem!!! |
01-13-2012, 11:34 PM
#11 | | Registered User
| Re: need some help
im taking it in on tuesday to get it checked out, did they charge anything for the control arms or was it covered by warranty ?
01-13-2012, 11:54 PM
#12 | | Registered User
Mine has made a popping noise when im in reverse and turn the wheel really hard.. Really bad when it's really cold and worse when on a hill.. Could this be the same issue?
__________________ 2011 5.0
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
