Painting Calipers/Bracket and Caliper Reinstalltion/Brake Bleeding - Mustang Evolution
Old 01-10-2012, 07:24 AM   #1
Napoleon85's Avatar
So I'm going to paint my calipers soon (have the dupli-color kit) and I'm curious if anyone has done this and can post pics.
The wildcard for me is the bracket... I've seen people leave the bracket alone and I don't think it looks all that great, but I'm concerned that it would be too much red. A few people have suggested painting the bracket black. Any thoughts on this?
Also, what kind of nightmare am I going to run into trying to bleed the brakes? I haven't done this in quite a while and I've heard that certain ABS systems can make this difficult due to secondary reservoirs trapping air bubbles and the like. I may open a separate thread for this when the time comes, but if anyone has had the calipers off on one of these cars any tips would be appreciated.
Old 01-10-2012, 07:35 AM   #2
Re: Painting Calipers/Bracket and Caliper Reinstalltion/Brake Bleeding
I'd really just build a little stand for them out of scrap, take them off and clean/paint them right in the wheel well. Calipers only, in red, semi-gloss black everything else.
It's really not materially different bleeding ABS brakes than regular brakes. An inexpensive vacuum pump is your best friend here. They can be had on FleaBay cheap.
Old 01-10-2012, 07:40 AM   #3
afree05's Avatar
I've painted mine, I'll post pics later today if you want to wait
afree05 is offline   Reply With Quote
Old 01-10-2012, 08:31 AM   #4
Napoleon85's Avatar
That's been the common suggestion. If I do this I'll take pics. I want to avoid doing them inside the wheel well. I just don't think I'll be able to get them as clean and get as consistent of a coat trying to work around all the other junk and dirt in there.
Cool. I had heard you could have issues withe the secondary reservoir not really purging but you know what they say about what you read on the internet.
That would be great. It's probably going to be a bit before I paint mine, just gathering info before I get balls deep in it.
Old 01-10-2012, 08:37 AM   #5
CZYFAST's Avatar
I painted mine while they were still attached to the car I didn't want to bleed my brakes and its black with yellow stuff EBC pads I think it looks alright?
IN SALEEN WE TRUST!!!
CZYFAST is offline   Reply With Quote
Old 01-10-2012, 08:42 AM   #6
Napoleon85's Avatar
Attachment 37751
That does look pretty good, but how is the backside of the caliper? I'm pretty anal about these kinds of things and it would bother me KNOWING that I may have missed a spot.
I'm not trying to get out of bleeding the brakes, was just curious what complications, if any, could arise from the abs system since I haven't really bled the brakes on an ABS car before.
Also, what kind of rotors are those?
Old 01-10-2012, 08:50 AM   #7
CZYFAST's Avatar
Well when you do them clean the caliper really well I bought three cans for just the front and used about 2 1/2 and I was able to get the backside done first and then I did the front and I didn't do the inside cause it won't be seen and will just get dirty anyway and I set them on a jack stand next to the car and let them dry and then did them again, 4 coats to make sure I got everything and that it was dark and then put the pads on and then done, and my rotors are Powerstop rotors got a great deal through stage 3 motorsport.com but put EBC yellow stuff and not the hawk pads
Old 01-10-2012, 09:24 AM   #8
Napoleon85's Avatar
Doesn't look like they sell them any more ... only the rears
Any reason for going with EBC over Hawk? I've been torn between the yellowstuff and HPS ... don't see people commenting much either way on them.
Old 01-10-2012, 09:35 AM   #9
CZYFAST's Avatar
They should have them but I can try to look another time and see if I can find them. I have just heard bad things with hawk pads, so I wanted to use EBC pads because I've never heard anyone complain about them and with my drilled and slotted they help me stop without brake fade and they don't squeal as much as people think or at least mine don't but yeah it was a great buy and upgrade because my stock rotors and pads were terrible because I got them so hot I burned the rotors and from then on I had horrible brake fade but not anymore with my setup!
Old 01-10-2012, 10:14 AM   #10
afree05's Avatar
I did mine while they were still on as well, do you have the spray or brush on kit?
ID:	37755   Click image for larger version
Old 01-10-2012, 10:16 AM   #11
Napoleon85's Avatar
The brush on kit from duplicolor. Thanks for the pic. Looks like you left your brackets plain?
Old 01-10-2012, 10:38 AM   #12
back n a stang's Avatar
Do be careful using spray for who goes that route.You can do a great job with spray if done right ,but if done on the car you better cover very well.Entire car.You may not see over spray,but when you clay the car it will be obvious what happen.I saw this with another guys car.I am very anal about doing it right so I would remove them.Personally if they are not brembo I would not do any painting to them.JMO.That was one mod I done on my G8 I regretted.Came out good but much later wish I would have left them OEM finish
Old 01-10-2012, 11:04 AM   #13
Musskao's Avatar
I painted mine using same brand. I did not remove brakes, just taped up around it.
Musskao is offline   Reply With Quote
Old 01-10-2012, 11:09 AM   #14
Napoleon85's Avatar
Attachment 37757
How many coats did you use? Did you have plenty from the kit to do both fronts and rears?
Old 01-10-2012, 11:23 AM   #15
Musskao's Avatar
Oops, already replied to you once.. Lol sorry
Old 01-10-2012, 12:23 PM   #16
I'm debating doing this on my Brembo car. However, what I really want is them not to turn rusty. The front's look painted already, backs I haven't inspected that closely but, if they are, I might just leave them alone.
Old 01-10-2012, 12:27 PM   #17
Napoleon85's Avatar
Front Brembos are painted, rears aren't painted on any stock Mustang. This is a big part of the reason I'm painting mine ... any color is better than rust LOL
Old 01-10-2012, 03:05 PM   #18
Musskao's Avatar
Did 3 coats I believe. Had plenty left over. Just clean them well with the brush in the kit before painting. Also let dry between coats...
Old 01-10-2012, 09:54 PM   #19
afree05's Avatar
yea, the brackets are unprinted, I can't remember exactly how many coats I did, I think like 3-4?, and I didn't even tape anytging
Old 01-11-2012, 05:34 PM   #20
sixx's Avatar
Attachment 37757
looks hot!!!
Harlequin
sixx is offline   Reply With Quote
Old 01-11-2012, 06:27 PM   #21
jhagan1980's Avatar
I don't understand why people don't paint the bracket. I think it looks half assed when not painted IMO.
jhagan1980 is offline   Reply With Quote
Old 01-11-2012, 06:35 PM   #22
CZYFAST's Avatar
Hey I painted my bracket and you are right if you don't paint it I think it looks tacky as well
Old 02-02-2012, 04:12 AM   #23
blackhawk 1's Avatar
i love my red painted calipers , so easy .,looks awesome
blackhawk 1 is offline   Reply With Quote
04:31 AM
