help for wheels for slicks - Mustang Evolution
Old 01-14-2012, 09:15 AM   #1
Will 94-5 Mustang GT wheels fit on the rear of my Brembo '12 GT? Anyone know offhand? I can get some cheap and I have 16" DRs in the house.
Old 01-16-2012, 12:46 AM   #2
Re: help for wheels for slicks
I have a st I am selling with DR's on them..15x10's. And the 94-05 will not fit they are the wrong off set.
Old 01-16-2012, 12:46 PM   #3
Well, the 94-5 waffles actually will tuck over the brakes, which was my concern. See this thread from elsewhere, if this forum will let me...
some 16" wheels will fit on the back of non-Brembo 2011 Mustang GT's - Ford Mustang Forums
Old 01-16-2012, 03:37 PM   #4
Issue isn't clearing brakes. The off set will push them out some from under the fenders...
Old 01-16-2012, 04:03 PM   #5
I expect they'll probably still clear on 255/16" DRs, with an unlowered car, not a ton of sidewall there. Might be tighter on ET Streets bias. With relocation brackets, the body should be moving up some anyway on launch.
WTH, it's worth a try, as I have the DRs and I can probably get a couple waffles real cheap, if I take the rashed up ones.
Do you know the actual #s on the offset for both, off the top of your head?
Old 01-16-2012, 05:02 PM   #6
I run them with no problems.
drewzx3 is offline   Reply With Quote
Old 01-16-2012, 05:57 PM   #7
We need 7 or 7.5 BS where they are 6.5...
Old 01-16-2012, 06:07 PM   #8
Cool, thanks, saves me chasing it around if I get to buying rims for the car.
Old 01-16-2012, 07:57 PM   #9
Mweigt07's Avatar
Region: North Dakota
Well I run the 275 wide on the 17 cobra replicas with more then enough room from touching the fender but yes does stick out pretty good so I only use it for my DRs at the track
Mweigt07 is offline   Reply With Quote
Old 01-16-2012, 08:13 PM   #10
Start luanching hard and you will hit tires..I didwhen luanchingover 5000rpms. That was using a buddies wheels..
---------- Post added at 09:13 PM ---------- Previous post was at 09:12 PM ----------
Really race stars are cheap. Can get in 15x10 and tires are cheap in 15 as more selection.
Old 01-17-2012, 07:46 AM   #11
Yeah if I was up to replacing them, I'd go that way for sure. I'd just like to use what I have until it's done then get something else.
I used to tap the fender fairly regular on my Foxstang at the strip. It was lowered but had lift bars in the back, using these 255s but, I had a Turbo Coupe rear in the back, which is wider, like the SN95s.
Old 01-17-2012, 10:39 AM   #12
You can get weld rts rims in all sizes..all way up to 20s
12:05 PM
