gauge install help. - Mustang Evolution
Old 01-20-2012, 06:24 PM   #1
king 5.0's Avatar
gauge install help.
Just bought the aeroforce gauge and boost gauge (colbalt) just wanted to know how everyone is running their wires? And stuff like that. I have the vac line already installed. About to install the duel SOS pod also. On the aeroforce, where are y'all hidding the cords at?
Anyone know a thread that they already talked about this topic?
Thanks
Sent from my SAMSUNG-SGH-I997 using Tapatalk
king 5.0 is offline   Reply With Quote
Old 01-20-2012, 07:34 PM   #2
Msoler's Avatar
I just recently installed the SOS dual pod and dual Aeroforce gauges and the install was really fast! You'll have a little more wiring work to do than I did, since all I had to do was hook right into the port. The stock pillar pulled off fairly easily. Once that's off, put a light on the floor. Then from above, looking down from where the pillar was you will be able to see your light and determine the best path to route your wiring. Once I had my wiring routed down, I coiled up all the excess, zip tied it, and stuffed it behind one of the panels. Then I plugged into the OBD2 port. Ran the other end of the cable in through the new dual pillar gauge pod and connected each Aeroforce gauge. Snapped the new pillar into place and that's it!
Msoler is offline   Reply With Quote
Old 01-20-2012, 10:05 PM   #3
Thanks
I have all my wires under dash zip tied up.
2005 gt cluster gauge repair... jmpark527 2005-2010 Mustang GT 29 11-25-2015 09:05 AM
Stripe Install Jeffola 2011-2014 Mustang GT 14 10-24-2011 04:48 AM
Fuel gauge not working after CAI install. Hellraisen 1996-2004 Mustang GT 0 09-14-2011 06:58 AM
20 gauge to 18 gauge XXSTEVEO66 General Mustang Discussion 0 08-16-2011 06:58 PM
Gauge install help needed dacriss 2011-2014 V6 Mustang 0 07-20-2011 02:41 PM
06:12 AM
