anyone else with squeaky brembos? - Mustang Evolution
Old 01-20-2012, 09:38 PM   #1
CaptainBeyond's Avatar
Hi guys, so I'm curious if its my car or if having brake squeal is common with the brembos?? Its pretty embarrassing to be in a devilishly handsome car that that squeaks like some old jalopy rolling through a parking lot. No I didn't really give the new brakes a chance to break in with all that power under my foot, I confess... But does anyone know if there are some good aftermarket pads or rotors that wont make noise?? Thanks!
---------- Post added at 10:38 PM ---------- Previous post was at 10:35 PM ----------
oh yes. and I did scuff up my pads and rotors pretty good with sandpaper. The squealing went away for a few days then came back.
Life's a garden, dig it
CaptainBeyond is offline   Reply With Quote
Old 01-20-2012, 09:46 PM   #2
back n a stang's Avatar
Re: anyone else with squeaky brembos?
Not much squealing with mine.A little.If yours is that bad try google for a few tips to cure the ill.Your wheels TQed to 100 ?? Your rotors are probably not warped but just wondering.But yes mine does but very little and nothing I give 2nd thought to.
Old 01-20-2012, 09:48 PM   #3
gtstyles2's Avatar
I don't have brembo but when I back out of my driveway, brakes always squeak when cold
Old 01-20-2012, 09:57 PM   #4
11stangGT's Avatar
Region: Arkansas
About a week or so after I wash it and the dirt starts to build back up it does a lil.. If I don't use a power washer when I wash the car and spray the brakes real well it will some also
---------- Post added at 10:57 PM ---------- Previous post was at 10:57 PM ----------
And mine is a brembo car
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 01-20-2012, 10:26 PM   #5
Redstang1's Avatar
Yes this happens all the time to mine got about 11200 on the car. If you get out on some back roads and warm em up they stop. It's not unusual for brembos to make noise when they are cold. It's because there "high performance" brakes.
Redstang1 is offline   Reply With Quote
Old 01-20-2012, 10:39 PM   #6
DaBluedude's Avatar
Its also important to get the hi temp silicone brake grease on them. Made a huge difference on my brakes. A performance set of brales will squeal rather than squeek. Don't run track pads. Those things scream untill they are damn near red hot...
2003 Mach 1
Old 01-21-2012, 08:44 AM   #7
Ravnus's Avatar
I was told to replace the Brembo's with Hawk Ceramic pads. I just hit 9,000 miles and so far so good for me. Minimal squeal
Ravnus is offline   Reply With Quote
Old 01-21-2012, 09:44 AM   #8
Region: Iowa
No noise from my brembos. 3500 miles so far.
2012 RaceRed Mustang GT Premium
401A | MT82 | 3.73 | Brembo Pkg | Elec Pkg | Dual Zone A/C | RR Sns/Sec Pkg | Rear Video | Comfort Pkg
Mods: Roush Axle Backs | JLT Oil Sep | Steeda CAI | Steeda Tune | MGW Shifter
RaceRed12 is offline   Reply With Quote
Old 01-21-2012, 01:08 PM   #9
Mr Sly's Avatar
I have the brembo brakes as well, i do have a little noise here and there. I was told by my mechanic that since the calipers are so huge that may be causing the noise. I havent looked into new ones because it doesnt happen that often.
Mr Sly is offline   Reply With Quote
Old 01-21-2012, 08:07 PM   #10
Benzo's Avatar
Same here rarely do my brakes make noise and I'm at 3000 miles.
Benzo is offline   Reply With Quote
Old 01-21-2012, 08:32 PM   #11
Gibby's Avatar
I have saleen brakes on mine and they squeal all the time unless hot and when I wash her theyll go away for a lil while
Gibby is offline   Reply With Quote
Old 01-21-2012, 08:46 PM   #12
ThatGiRLKriSsiE's Avatar
My car does this also. I talked to the service guy at ford that checked everything and said it was common. He did tell me to try to slam on the brakes and it should stop.... Shame on ford.
ThatGiRLKriSsiE is offline   Reply With Quote
Old 01-21-2012, 08:50 PM   #13
Gibby's Avatar
They are known for squealing. The big surface area of the pad makes it worse. Do you have blank rotors or slotted?
Old 01-21-2012, 10:12 PM   #14
11stangGT's Avatar
Region: Arkansas
Do slotted rotors help?
Old 01-21-2012, 10:15 PM   #15
Musskao's Avatar
Mine only do it when outside temps drop below 50 degrees it seems. Not that worried about it at this point. 1500 miles on her.. Only have a 2 mile commute to work, so not much time for them to warm up...
Musskao is offline   Reply With Quote
Old 01-21-2012, 10:20 PM   #16
Gibby's Avatar
I've heard blanks help? Too expensive to be buyin a bunch of diff rotors. Lol
Old 01-21-2012, 10:56 PM   #17
11stangGT's Avatar
Region: Arkansas
Lol I have no clue.. But if someone does... Full me in!
Old 01-21-2012, 11:05 PM   #18
Gibby's Avatar
Blanks are not slotted or drilled.....
Old 01-21-2012, 11:08 PM   #19
11stangGT's Avatar
Region: Arkansas
Ya I know that.. I meant if blanks make the squealing better or worse..
Old 01-21-2012, 11:10 PM   #20
Gibby's Avatar
Oh.... I hear yuh.
Old 01-22-2012, 03:31 PM   #21
I have the stock brembo rotors. Mine just turned over 2000 miles the other day. Its weird how everyone is saying that it stops when they warm up cause mine is the opposite. They're always quiet until I start driving around a while. And its only at low speeds like going thru a parking lot. I use my e-brake alot cause I hate the squealing!
---------- Post added at 04:31 PM ---------- Previous post was at 04:22 PM ----------
Its weird...I worked for a speed shop last year which also had a race team. I worked on two 2010 camaros that ran in scca world challenge and they had brembos. I never heard one squeak or squeal ever out of those cars. But they also had stop tech pads and slotted rotors.
Old 01-22-2012, 04:21 PM   #22
I have nearly 2,500 miles on mine and no squeak or squeal here. I've had Hawk HP+'s, so I know what squeal is! My BrembOS are quiet.
'12 Mustang GT, black, base, M6, Brembos, 3.73, etc. - DD
'84 911 Carrera, RoW, GP white, Burgundy cloth, etc. - Toy
'05 Mazda 6S GT, black, tan leather, auto, etc. - Wife's
S197 in SC is offline   Reply With Quote
Old 02-12-2012, 10:49 AM   #23
GrayGhost's Avatar
Over 12,500mi. and extremely rare that I may hear a peep out of the Brembo brakes!
On that note, another brake-related post on its way...
2011 Mustang GT Premium 401A Spec- Sterling Gray, aka "Graycie", 6-Speed MT, 3.73, Brembo Brake Package, Current Mods: FRPP-Brakelines/Brake Ducts/Alternator/Radiator/Oil Pan/Oil Cooler/Trans.Scoop/Alum.Axle Cover, Steeda-Sport Springs/3rd Link/Adj.UCA/Alum.LCA/Rel.Brackets/Adj.PHB & Brace/Adj.F&R Swaybars/Adj.Front Endlinks/HD Strut Mounts/X11 Ball Joint/Bumpsteer/CAI, Koni Sport Shocks, ATI Damper, MGW Shifter, Kooks Catback, Wavetrac Diff, Michelin Pilot Super Sport... 93 Octane Performance Tune by VMP
GrayGhost is offline   Reply With Quote
Squeaky suspension deadsp0t 1979-1995 Mustang GT 20 01-12-2012 01:22 PM
Squeaky suspension vinnygt SVT Mustang 2 01-06-2012 12:47 PM
Wish you would have got Brembo's?? wnt2gofst 2011-2014 Mustang GT 1 09-21-2011 09:56 AM
04:16 PM
