MSD two-step - Mustang Evolution
Old 01-25-2012, 11:11 PM   #1
11stangGT's Avatar
Region: Arkansas
MSD two-step
As anyone used one? They work? Worth it? Pros, cons, etc., etc???
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 01-26-2012, 06:59 AM   #2
Napoleon85's Avatar
Re: MSD two-step
I posted a thread about this a while ago and didn't get much response but I'll tell you what I know.
Has anyone used one - certainly, but nobody is speaking up
Do they work - definitely
Are they worth it - Maybe. Do you live at the drag strip and need your launches to be consistent and at a specific RPM? Chances are if you have to ask, it's not worth it for you. If you needed it you would know.
There really are no pros/cons ... it does what it does. Also, MSD makes one specifically for this car, so make sure you get that one and not a normal two step that's designed to be wired into a MSD ignition.
Old 01-26-2012, 09:11 AM   #3
11stangGT's Avatar
Region: Arkansas
Well mine is definitely a DD.. But I make a couple trips to the track a year usually.. Just seems like they would make the launch a lot easier? Not having to worry about getting in it too much or too little..
Old 01-26-2012, 09:26 AM   #4
A 2 step is actually really hard on the drivetrain. You are loading with all this power and dumping it at once. It's also hard on the cats. I also imagine the installation of one would void any warranty.
There is also no slipping the clutch or modulating power off the line. It's all or nothing
Old 01-26-2012, 09:32 AM   #5
11stangGT's Avatar
Region: Arkansas
Wouldnt really be any different than a typical hard launch though correct? I have no cats and a tuner along w other mods so obviously not worried about warranty.. They say that your supposed to ease off the clutch too which leads me to believe that it does slip some.. Otherwise you could just dump the clutch...
Old 01-26-2012, 12:25 PM   #6
Re: MSD two-step
No differnet then any o0ther high rpms launch. Also it helps you hold rpms when shifting. It is a good thing to have when drag racing. You can always have it off on normnal driving just like a line lock.
Old 01-26-2012, 12:45 PM   #7
11stangGT's Avatar
Region: Arkansas
That's what I was thinking.. And I won't be setting it very high until I get a new clutch at least.. Anyone know how they install? Like 5 min install or do I have to take things out to get where it goes?
Old 01-26-2012, 01:12 PM   #8
Napoleon85's Avatar
Re: MSD two-step
The one designed for the 5.0 is pretty much snap in. There's some finagling that has to be done with the switch but it's explained in the instructions that are available on the MSD site.
Old 01-26-2012, 04:26 PM   #9
I know the one I installed on the cobra I had to cut the main coil line and tap into two wires on the ecu harness. Don't know what is required for the newer cars.
Old 01-26-2012, 04:43 PM   #10
11stangGT's Avatar
Region: Arkansas
Looks like it should all be plug and play minus a ground wire and a couple switches
How To: Plasti Dip Your Car (In Depth, 6 pages worth of Microsoft Word) Topless04GT Mustang Paint, Appearance & Detailing 318 05-17-2017 12:40 PM
2 step rpm 94GTx306 1979-1995 Mustang GT 1 12-18-2011 12:53 AM
How To: Paint Your Headlights in 15 Easy Steps (oven bake method) Topless04GT Mustang Paint, Appearance & Detailing 6 12-11-2011 04:46 PM
msd install dreamstang 1979-1995 Mustang GT 2 12-04-2011 05:28 PM
2 step 94GTx306 1979-1995 Mustang GT 6 08-24-2011 10:25 PM
10:29 AM
