Econo Shift/Skip Shift Rant - Mustang Evolution
Old 01-30-2012, 06:58 AM   #1
michael81's Avatar
I love just about everything about my car. Keyword (My Car) therefore its my transmission as well, And I cant stand being in slow moving traffic or just driving moderatly and my car tells me to shift to fourth gear and locks out second. Usually I know when it will do it and I can just give it alittle gas and shift normally, but sometimes when im not paying attention I shift into forth cause second is not there, and just bog down and that really pisses me off. Why would Ford think that I need to be told how to shift my gears, If I wanted an Automatic I would have bought one. Now that I'm done complaining is there anyway to disable it? Like pulling a fuse or disconnecting something. (without having to purchase a tuner)
michael81 is offline   Reply With Quote
Old 01-30-2012, 07:14 AM   #2
Re: Econo Shift/Skip Shift Rant
No way besides a tune. They did it so you don't pay a gas guzzler tax. And I don't have any issues boging with my auto.
Old 01-30-2012, 07:31 AM   #3
skyline247's Avatar
I haven't heard of a way to disable it without a tune. If you pay attention to what causes it to turn on, you can pretty much avoid skip shift. I haven't encountered it in a while now.
1988 GT - Stock
*SOLD* 2012 GT Premium, Black on Black, 3.55 Axle, HID and Security Package, Pypes Pype Bomb Axle Backs
skyline247 is offline   Reply With Quote
Old 01-30-2012, 07:41 AM   #4
gtstyles2's Avatar
I never understood the skip shift thing.... I do see the prompt on the dash to go 1-4 for less fuel consumption,but never has it locked me out of 2nd gear...
Old 01-30-2012, 07:47 AM   #5
skyline247's Avatar
It could be that you shift right after its disabled again. From my experience, the window in which skip shift is active is small.
1988 GT - Stock
Old 01-30-2012, 08:20 AM   #6
avengnd's Avatar
I'm not sure I understand this. When the computer tells me to shift from 1st to 4th I ignore it and go to second...I don't have a problem doing that. Are you saying you can't shift it into 2nd when skip shift warning comes on?
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 01-30-2012, 08:23 AM   #7
Napoleon85's Avatar
Like others said, you need a tune to disable it. Do your research before buying one, they are not risk-free and may have implications on your factory warranty. (this hasn't stopped most of us btw)
Also, my speculation is that skip-shift is there to boost gas mileage and help Ford meet its CAFE numbers.
---------- Post added at 10:23 AM ---------- Previous post was at 10:22 AM ----------
Correct, when you see that warning it should physically lock you out of 2nd gear. If that's not happening, something might be wrong with the lock-out mechanism ... but I wouldn't take it in for repair lol.
Old 01-30-2012, 08:27 AM   #8
avengnd's Avatar
I will have to pay attention to it when I get home, but I don't recall it locking me out, I just ignored it...I agree...but couldn't that be a sign of something that is wrong?
2014 Shelby GT500
Old 01-30-2012, 08:29 AM   #9
Napoleon85's Avatar
I wouldn't worry about it. I think there's a solenoid or something that blocks the shift ... it might not be working. I doubt it would indicate any other issues though.
Old 01-30-2012, 08:42 AM   #10
michael81's Avatar
Yes there is a lock that prevent you from shifting into second and slides you into fourth.
Old 01-30-2012, 10:19 AM   #11
NuckChorris's Avatar
I usually just go 1-3 in traffic. It won't keep you from going to 3rd.
NuckChorris is offline   Reply With Quote
Old 01-30-2012, 10:24 AM   #12
skyline247's Avatar
It is supposed to lock you out of second. However, the window in which skip shift is active is very small. It's happened to me where the light stays on for a second longer and it doesn't lock me out. Its all dependent on rpm, throttle position, etc. So if it activates and you change any of these parameters significantly enough, it will deactivate and not lock you out. At least that has been my experience with it. I doubt there is anything wrong. But if there is, it shouldn't warrant a visit to the dealer IMO.
---------- Post added at 12:24 PM ---------- Previous post was at 12:23 PM ----------
You can always go this route and avoid it entirely as well.
1988 GT - Stock
Old 01-30-2012, 10:28 AM   #13
that option should be something that can be turned off... I think it causes more harm than good as it annoys the driver so much they probably just spend more gas and raise the rpms more often to keep it from doing it.
Old 01-30-2012, 01:28 PM   #14
mknlegs's Avatar
I can shift into second without any problems. It shows the 1-4 shift on the dash but it doesn't lock out second.
mknlegs is offline   Reply With Quote
Old 01-30-2012, 02:38 PM   #15
DarkHorse_5.0's Avatar
I have never been locked out of second. I do plenty of city driving and the warning comes up and I take it as a suggestion. Sometimes I may do it to fool myself into thinking I am getting better gas mileage but when I am at the gas station two days later; I come to terms with the type of car I bought and love. It's an annoyance, you should be able to disable it.
DarkHorse_5.0 is offline   Reply With Quote
Old 01-30-2012, 03:33 PM   #16
11stangGT's Avatar
Region: Arkansas
It doesn't completely lock it out it just make it harder to get in 2nd
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 01-30-2012, 04:21 PM   #17
gtstyles2's Avatar
I'm glad I never locked out of 2nd ... I only skip shift sometimes when I'm cruising... good thing thing for the variable valve timing to pick it up in any rpm
Old 01-30-2012, 06:52 PM   #18
2012Coyote's Avatar
Unplug the Sensor, there is a "how to" on the web. You get the light but will not force 4th. Or like others have mentioned a tune but unfortunately not everyone wants to void the warranty.
2012Coyote is offline   Reply With Quote
Shift issues Loudmustang 2.3 Mustang 12 01-30-2012 05:06 PM
Shift points Fordhartbreaker Pre-2005 V6 Mustang 14 01-08-2012 05:06 PM
Black Shift Knob skyline247 2011-2014 Mustang GT 13 09-07-2011 11:06 AM
Shift kit Jesse Bach General Car Discussion 1 08-21-2011 02:17 AM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
07:34 PM
