Lowering springs - Mustang Evolution
Old 01-31-2012, 10:22 PM   #1
Redstang1's Avatar
Lowering springs
What all is needed other than springs? I have herd everything from nothing to new caster camber plates all the way to just a panhard bar.
Redstang1 is offline   Reply With Quote
Old 01-31-2012, 10:25 PM   #2
Napoleon85's Avatar
Re: Lowering springs
The short answer is, it depends. What are you planning on doing?
Old 01-31-2012, 10:44 PM   #3
Redstang1's Avatar
I want h&r race springs and that was all.
Old 01-31-2012, 11:16 PM   #4
BossFiveOh's Avatar
I used eibach pro-kits on my 2011 5.0 and didn't need anything else. Everything was perfect. Just realignment. I love the drop, just perfect. U don't want to go any lower then the pro-kits. As careful as I am, I scrape everywhere. Good luck
BossFiveOh is offline   Reply With Quote
Old 01-31-2012, 11:17 PM   #5
Redstang1's Avatar
Ok thanks
Old 01-31-2012, 11:17 PM   #6
GT_Man's Avatar
I did the same as Boss. The Prokit is a really good ride height. You might consider getting a panhard bar. Those aren't too expensive.
2012 GT/CS | 3.73's, Raxiom smoked headlights, smoked tail lights, GT500 axlebacks, Steeda CAI, Bama Racing Tune (93), 20% tint |
GT_Man is offline   Reply With Quote
Old 02-01-2012, 07:34 AM   #7
Reinkey's Avatar
I plan on getting k-springs. Don't plan on getting camber plates. While I'm doing the install I'll be doing panhard bar and LCA but that's unrelated.
Reinkey is offline   Reply With Quote
Old 02-01-2012, 07:37 AM   #8
It's not me, it's you.
primer2tone's Avatar
I love the look of being lowered but I hate the ride on harsh roads which is everywhere here in TX.
Old 02-01-2012, 11:45 AM   #9
2012Coyote's Avatar
You will need an adjustable pan hard bar to realign the body are you will have one tire further out on one side then the other. With stock tires it is not as noticeable but with wider tires you will definitely see it.
I have the Eibach Pro-Kit and from what I read several people have had no issues with camber. I bought the camber bolts just to be on the safe side, I will take it in for an alignment after break-in (Roughly 2k miles)
2012Coyote is offline   Reply With Quote
Old 02-01-2012, 12:50 PM   #10
M3to5.0's Avatar
Not unrelated... I did the K springs, Panhard, LCA's and LCA relocation brackets. Kinda need all to make the springs work. Took it to the dealership on monday and they were able to adjust the alignment without the Camber bolts I had bought ... just in case.
"Got to kill.... Captain Stupid"
M3to5.0 is offline   Reply With Quote
Old 02-02-2012, 10:29 AM   #11
Lone Star's Avatar
I also have the Eibach Pro's on mine and love the look, and is the perfect amount of drop. Any lower and you will be scraping everything
Northern Virginia Mustang Club
Silver Mustang Registry #1045
2010 Brilliant Silver 4.0 V6 Traded and will be missed
2011 Performance White Premium GT 5.0 6MT, 19" Machined Wheels, 3.73 gears, GT500 Axle-Backs, Eibach Pro Springs, Dynojet #'s 387rwhp/380 tq.
Lone Star is offline   Reply With Quote
Old 02-02-2012, 10:54 AM   #12
gtstyles2's Avatar
I also have the pro-kit with Eibach dampers... love the ride and height is just right... its low enough too, I can't even stick a regular Jack towards the front part or even on a lift at a shop... I was considering getting the Boss splitter when I get the CS valence, but if I'm having clearance issues now, I'm assuming it'll get worse with the splitter
Lowering Springs jjsg09 1996-2004 Mustang GT 14 02-06-2012 06:11 AM
lowering springs Cantlin01 1996-2004 Mustang GT 8 12-01-2011 02:45 PM
Lowering springs JGeezy44 General Mustang Discussion 5 10-06-2011 02:31 PM
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 09:32 AM
Lowering springs 89white GT AmericanMuscle 1 08-30-2011 04:11 PM
08:52 AM
