Panhard bar - Mustang Evolution
Old 02-07-2012, 11:45 AM   #1
11stangGT's Avatar
Region: Arkansas
Panhard bar
About to order one at work.. J&M or maximum motorsports? Is it worth the extra $50 for the MM or will the j&m be just fine?
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 02-07-2012, 12:41 PM   #2
Napoleon85's Avatar
Re: Panhard bar
I'm a huge fan of UPR, you might want to check theirs out. They have them with poly and spherical ends...
2005-2011 Ford Mustang Pro Street Double Adjustable Pan Hard Bar - UPR Products
05-11 Mustang Pro Series Double Adjustable Pan Hard Bar
Old 02-07-2012, 01:38 PM   #3
Y2E0L0L5OGWT's Avatar
Re: Panhard bar
If you're up for spending the money, a Watts Linkage is a better option than a panhard bar IF you're going to do any heavy road course or autox racing...If it's just a street driver, then it's really not worth the extra money...
Old 02-07-2012, 01:38 PM   #4
I have upr on mine..with upr lca's I have yet to pit in..
Old 02-07-2012, 01:41 PM   #5
11stangGT's Avatar
Region: Arkansas
DD.. I live in Arkansas so there aren't any road courses.. Other than the curvy *** roads we got here.. Only make a couple trips to the drag strip a year..
Old 02-07-2012, 04:47 PM   #6
11stangGT's Avatar
Region: Arkansas
Am I gonna notice much diff between the spherical rod ends vs. poly? I dont what it to be much rougher of a ride being a dd and all..
Old 02-07-2012, 04:57 PM   #7
redstang10's Avatar
I got the j&m adjustable one off AM and it works fine for me. I needed it to re-align the rear after lowering it and that did exactly what I needed for my DD.
redstang10 is offline   Reply With Quote
Old 02-07-2012, 04:59 PM   #8
11stangGT's Avatar
Region: Arkansas
Did you get the poly ends on yours?
Old 02-07-2012, 05:16 PM   #9
redstang10's Avatar
I don't think so. I just got this one
http://www.americanmuscle.com/jm-panhard-0509.html
Old 02-07-2012, 06:02 PM   #10
Re: Panhard bar
The poly ends will be quieter then the Spherical ends. The Solid spherical ends will transmit a lot more noise.
Old 02-07-2012, 06:46 PM   #11
11stangGT's Avatar
Region: Arkansas
So being a dd I prolly wanna go w the poly end right? Would I really even gain anything from having the spherical ends?
---------- Post added at 07:46 PM ---------- Previous post was at 07:44 PM ----------
Those are poly ends..
Old 02-07-2012, 08:20 PM   #12
Re: Panhard bar
With the panhard bar nope. On the LCA's with a stick car you would want th espherical ends. I split a buching in my manual car launching hard.
Old 02-07-2012, 09:43 PM   #13
11stangGT's Avatar
Region: Arkansas
So might as well go with the j&m aluminum bar w poly ends? A lil softer ride than the spherical and quieter.. I assume the only advantage to a spherical end is strength?
Old 02-08-2012, 05:09 AM   #14
Some strength and not as rough ride. All spherical ends on everything gets really rough
Old 02-08-2012, 12:06 PM   #15
11stangGT's Avatar
Region: Arkansas
Ya I already have the Steeda control arms w the poly ends and it's quite a bit rougher and louder when I hit bumps.. I couldn't imagine spherical ends on them.. Roads are too rough here.. Where did yours split at? The poly or the actual end ring?
Old 02-08-2012, 01:02 PM   #16
Scott2's Avatar
Re: Panhard bar
I recommend this J&M panhard bar from American Muscle because it has Zerk grease fittings, poly bushings and the design is easiest to adjust on car (albeit you only need to do this once unless you change the ride height):
J&M Mustang Adjustable Panhard Rod (05-12 All) 23795B - Free Shipping!
Old 02-08-2012, 06:15 PM   #17
2012Coyote's Avatar
I have the BMR from LMR along with 2 friends ( 1 gt and a gt500) i would just make sure the adjustment nuts are not up in the bracket, those are a pain in the A$$ to adjust.
2012Coyote is offline   Reply With Quote
Old 02-08-2012, 06:43 PM   #18
The poly bushing did on the body side.
Old 02-11-2012, 08:51 PM   #19
sixx's Avatar
Re: Panhard bar
hey hey brotha. just got and installed from ford racing. well worth the cash.
Harlequin
sixx is offline   Reply With Quote
Old 02-12-2012, 03:11 AM   #20
11stangGT's Avatar
Region: Arkansas
Where'd you find it cheapest?
Old 02-12-2012, 08:52 AM   #21
sixx's Avatar
Re: Panhard bar
not sure it was the cheapest but ford racing itself. 256ish. again worth the extra cash, as far as im concerned...
Harlequin
Panhard bar needed for lowering? mcvicar04 1996-2004 Mustang GT 3 12-20-2011 08:47 AM
Adjustable panhard bar gtstyles2 2011-2014 Mustang GT 7 10-08-2011 04:05 PM
Panhard Bar Adjustments JonChambers03 2005-2010 Mustang GT 6 07-29-2011 01:59 PM
Adjustment of panhard bar poloka 2011-2014 Mustang GT 9 07-17-2011 01:29 PM
Panhard Bar and Rod Support Suggestions poloka 2011-2014 Mustang GT 22 07-02-2011 07:56 PM
05:55 AM
