There isn't any warranty approved headers is there? - Mustang Evolution
Old 02-12-2012, 08:25 PM   #1
Xofferick's Avatar
Just curious.
Xofferick is offline   Reply With Quote
Old 02-12-2012, 08:27 PM   #2
deadsp0t's Avatar
Doubt it. Haven't herd tell of any.
That's unimpressive
Old 02-13-2012, 03:44 AM   #3
back n a stang's Avatar
Re: There isn't any warranty approved headers is there?
The ones on the 11-12 are a header to a degree....sure better than the average manifolds,but do not think you will find any that ford will like you putting on if thats what you mean.
Old 02-13-2012, 04:40 AM   #4
Labrat's Avatar
I would ask a dealer...if they were dealer installed maybe?
Labrat is offline   Reply With Quote
Old 02-13-2012, 07:35 AM   #5
Headers have no effect on any warranty except, of course, for the headers themselves (If a Hooker header cracks, don't expect Ford to fix it). There's no such thing as warranty-UNapproved headers, so unless Ford makes a set and puts them on the car, no header will be covered by anything but that manufacturer's warranty. They also won't void you new-car warranty unless they or their installation causes a problem.
jbt56 is offline   Reply With Quote
Old 02-13-2012, 07:44 AM   #6
deadsp0t's Avatar
Being that you will likely need a tune with a header change, you'll be voiding the warranty that way. Im pretty sure we've already established that a tune will be required when changing headersz
That's unimpressive
Old 02-13-2012, 08:25 AM   #7
Benzo's Avatar
Shorty header don't need a tune as they will not move ur o2 sensors.
Benzo is offline   Reply With Quote
Old 02-13-2012, 08:34 AM   #8
deadsp0t's Avatar
That's unimpressive
Old 02-13-2012, 08:37 AM   #9
Eturner's Avatar
Needing a tune or not has little to do with the placement of the sensors!.. It actually has to do with the flow of the exahaust and possibly running a lean condition, with out a proper tune!..
---------- Post added at 10:37 AM ---------- Previous post was at 10:35 AM ----------
What year is your car?..
Old 02-13-2012, 05:10 PM   #10
It has to do with the O2 sensors. They are moved back and read different a/f cause of more free flowing exhaust.
BBK LT headers will not need a tune. They will make more power with a tune. But will not throw no codes without a tune. They place sensors in stock positions. A tune just shuts them sensors off.
Old 02-13-2012, 06:45 PM   #11
Eturner's Avatar
A tune in itself will not turn the sensors off!.. You can on the other hand turn them off with a tuner!.. Only recommend doing that if you don't have cats on your car!.. Also if you have an o/r mid pipe, with or without a cat back system, then I would highly recommend getting a tune if your going with LT headers!..
Old 02-13-2012, 08:03 PM   #12
Napoleon85's Avatar
I suspect that doing that would change the checksum in the ECU and Ford would be able to tell you modified it.
Old 02-13-2012, 09:18 PM   #13
Are you really that anal. Yes a tunerwill shut them off. Now 99% of people shut them off in your tune. As it is in the software. Now you do not need a tune with BBK LT headers on a new 5.0. You also do not need to shut the o2 sensors off. How do I know. Cause I owed the car with that set up. Being you don't own one or one with that setup. Well then shut up cause you don't know what you are talking about. You always come to this section compare to your car and what now. They are far from the same.
---------- Post added at 10:18 PM ---------- Previous post was at 10:16 PM ----------
Yes they would. Bbk made their headers so you didn't need a tune for a reason. So it wouldn't void warranty. So you don't have to shut o2 sensors off.
Old 02-13-2012, 09:58 PM   #14
Xofferick's Avatar
Thanks for the info. I will have to look into the BBK headers.
Old 02-13-2012, 10:42 PM   #15
Eturner's Avatar
First off it's not being anal when I'm just giving straight forward facts!.. Which clearly you can not!.. I never said that you need a tune with LT headers!.. Just that it is recommended mostly to keep from running a lean condition!.. And mostly if you also have a o/r mid pipe!.. In other words no cats!.. Running without cats can also cause bit of a lean condition!.. With these two things its best to get a tune to be on the safe side!.. I don't need to own a new 5.0 to know that!.. The principles behind exhaust systems are the same no matter what year, make, and model car you have!.. Clearly some thing you don't know!.. So perhaps you need to shut up!..
And yes you are right that you don't have to turn off your O2 sensors!.. The only reason I recommend doing it is if your running with out cats (what I said earlier in this thread)!.. And that is to just keep your Check Engine Light from popping on!.. Other wise running with the factory cats, or a set of high flow cats, will keep that light from popping off too!..
Old 02-13-2012, 10:53 PM   #16
11stangGT's Avatar
Region: Arkansas
He's right.. Your in the wrong section
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 02-14-2012, 02:24 AM   #17
Benzo's Avatar
I agree with wnt2gofst here. And just to state a fact from personal experience when I installed my SW LT's and o/r x pipe did not have the correct tune at the time was just tuned for cai and boss mani and drove over 250 miles and didn't throw any codes. With out the correct tune the car ran sluggish compared to having the correct tune. Just a lil food for thought
o2 sensor help new headers problem shaloubin Pre-2005 V6 Mustang 11 01-22-2014 09:44 PM
Jba 1 5/8 shorty headers (insight on jba headers) go or no go? Swangin_Stangs 1979-1995 Mustang GT 24 01-13-2012 06:15 PM
Ordered headers today, but.....? WhiteCobra94 1979-1995 Mustang GT 2 01-02-2012 10:29 PM
headers Robbie94gt 1979-1995 Mustang GT 21 12-09-2011 07:59 PM
aftermarket warranty. S197Miller 2005-2010 Mustang GT 5 07-28-2011 10:43 AM
05:37 AM
