Where do i change Trans. Fluid in 2010 mustang?? - Mustang Evolution
Old 02-18-2012, 11:03 AM   #1
Exclamation Where do i change Trans. Fluid in 2010 mustang??
Hi i really need help fast the dealer wants too much to change my trans fluid but where is the dipstick? HELP!!
SonofAnarchy is offline   Reply With Quote
Old 02-18-2012, 11:18 AM   #2
Loc: Austin,TX
Re: Where do i change Trans. Fluid in 2010 mustang??
Do you have a MT?
Old 02-18-2012, 01:45 PM   #3
Not to be a crank but, if you're looking for a dipstick on a manual trans, I'd take it to a Jiffy lube and pay them a case of beer to do it for you.
If it's an automatic, unless you really like a huge mess to clean up, I'd follow the above advice for that as well.
I just pumped in some BG Synchroshift II into my '12 this morning. Quite an improvement over the factory fill. I'll see what the cold morning air brings, as that was when I was most unhappy with my MT.
Old 02-18-2012, 02:00 PM   #4
JimC's Avatar
automatic doesn't have a dipstick. Changing the fluid is a little involved, and not easy to do if you don't have access to a lift. It can be done on jack stands, but isn't a pleasant ordeal.
The drain plug is a two piece - the inner section is where you put the tool to pump fluid UP into the transmission after draining it but taking the entire plug out. You take out the insert and put the tool in and then pump fluid in. When it starts to drain back out, put the center piece in.
But that isn't the end. Now start the car up and run it through the gears. Get it up to operating temperature. Then back under the car that is now up to operating temperature to pump more fluid up into the transmission. When it starts to drain back again - start the car up, put it in gear (so now you have hot exhaust, hot transmission, and a spinning driveshaft) and pump more fluid up until it drains back again.
Cap it off and take it for a drive. If the transmission slips on a shift or is sloppy then you didn't get enough fluid in and have to add again.
That's why you can't get it done at Jiffy Lube, and why the dealer charges so much.
JimC is offline   Reply With Quote
Old 02-20-2012, 04:49 AM   #5
ok jimc i thought so i have a dealer appt today thanks
2010 mustang
What did you do today? Qwik Four Six The Bar 20466 01-14-2017 03:24 PM
New mustang owner V6 powered New Member Introductions & Greetings 29 02-21-2012 05:02 PM
Mustang vs Mustang vinnygt The Bar 4 02-19-2012 10:15 AM
Mustang Pedal Mod GP3GT 1996-2004 Mustang GT 25 02-18-2012 10:26 AM
Cdc liped side skirts for 2010+ Silversky545 2005-2010 Mustang GT 0 02-17-2012 11:11 PM
11:46 AM
